HDP internal peripheral
  • briefly introduce the HDP peripheral and its main features,
The HDP peripheral is used to output some internal signals on up to 8 GPIO pins.
Follow the sequence below to connect a GPIO to an internal signal via the HDP:
  • First of all, look for the internal signal you want to monitor in the HDP signal multiplexing table of the STM32MPU reference manuals:
    • Search for the HDP signal on which you can get it among eight possible choices.
    • Note the corresponding HDPx multiplexing value to select.
  • Then, look for the most suitable GPIO pin on which you can output HDPx in the datasheets:
    • Note the GPIO bank and pin.
    • Note the corresponding GPIO alternate function (AF) to select.
The GPIO bank, pin, alternate function and HDPx multiplexing value are the information required to configure each HDP signal.
The HDP peripheral is not used at boot time.
nonsecure
Trace & Debug HDP HDP
nonsecure
Cortex-M4
3.2.3. On STM32MP21x lines More info.png[edit | edit source]
The table below is applicable to any TD flavor (A35-TD or M33-TD) More info green.png.
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Trace & Debug HDP HDP OP-TEE
3.2.4. On STM32MP23x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
3.2.5. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Below are listed the software frameworks and drivers managing the HDP peripheral for the embedded software components listed in the above tables.
