QUADSPI internal peripheral
  • briefly introduce the QUADSPI peripheral and its main features,
The QUADSPI peripheral interfaces the processor with serial NOR flash and serial NAND flash memories.
It supports:
  • Single, Dual- or Quad-SPI flash memories
  • A dual-flash mode, allowing to aggregate two flash memories into a virtual-single one
  • Dual data rate and memory-mapped modes.
QUADSPI instance is a boot device that supports serial boot for flash programming with STM32CubeProgrammer.
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Mass storage QUADSPI QUADSPI
nonsecure
Mass storage QUADSPI QUADSPI Assignment (single choice)
nonsecure
Cortex-M4
Below are listed the software frameworks and drivers managing the QUADSPI peripheral for the embedded software components listed in the above tables.
For Linux kernel configuration, refer to QUADSPI device tree configuration.
