STM32MP13 Discovery kits - Starter Package
This article shows how to start up a STM32MP135x-DK Discovery kit More info green.png (flexible and complete development platform for the STM32MP13x lines More info.png) with the software image for the Yocto-based OpenSTLinux embedded software. It is valid for STM32MP135F-DK Discovery kit More info green.png: the part numbers are specified in the STM32MP13 microprocessor part numbers article.
1. Starter Package content[edit | edit source]
If you are not yet familiar with the Yocto-based OpenSTLinux embedded software and its Packages, please read the following articles:
If you are already familiar with the Starter Package for the Yocto-based OpenSTLinux embedded software, the fast links to essential commands might be of interest.
  • the software image for the Yocto-based OpenSTLinux embedded software, which includes:
    • the binaries for the OpenSTLinux distribution
    • one or more firmware example(s) for the STM32Cube MPU Package
  • the (STM32CubeProgrammer) tool to install this image on the STM32MP135x-DK Discovery kit More info green.png
Components of the Starter Package
2. Starter Package step-by-step overview[edit | edit source]
The steps to get the STM32MP135x-DK Discovery kit More info green.png up and running, are:
Checking the material
Assembling the board
Installing the tools
Downloading the image and flashing it on the board
Booting the board
3. Checking the material[edit | edit source]
Mandatory
PC Linux® or Windows® operating systems. See PC prerequisites for more details on the required configurations.
STM32MP135x-DK Discovery kit Flexible and complete development platform for the STM32MP135 microprocessor device including:
  • an MB1635 mother board
Power supply Including:
  • a USB Type-C® cable (included in the packaging)
  • a USB Type-C® charger (5 V, 3 A) (not included in the packaging)
microSD card Populated with OpenSTLinux distribution (Linux® software), and providing extra storage capacity. A 2-Gbyte minimum microSD card is needed.
USB Micro-B cable To connect the STM32MP135x-DK Discovery kit to the PC through the USB Micro-B (ST-LINK/V2-1) connector.
USB Type-C® cable To connect the STM32MP135x-DK Discovery kit to a USB OTG device through the USB Type-C® connector.
Optional
USB keyboard and mouse Through its USB Type-A connectors, the STM32MP135x-DK Discovery kit can be equipped with a full-size keyboard and mouse.
Ethernet cable To connect the STM32MP135x-DK Discovery kit to a network through the RJ45 connector.
Optional: It is possible to plug more devices and extension boards to the STM32MP135x-DK Discovery kit by means of its expansion connectors such as the GPIO expansion connector.
The following figure shows the optional material (not included in STM32MP135x-DK Discovery kit More info green.png package), that is used with this Starter Package.
Recommended material for this Starter Package
4. Assembling the board[edit | edit source]
The STM32MP135F-DK Discovery kit More info green.png package is composed of the items listed below.
Position Description
1 MB1635 mother board
2 MB1897 camera module (GalaxyCore GC2145 camera sensor)
3 Camera module flat cable
4 microSD™ card
Note that the STM32MP135F-DK Discovery kit More info green.png delivery does not contain a USB cable or a USB charger.
STM32MP135F-DK Discovery kit assembled.
(picture is not contractual)
5. Installing the tools[edit | edit source]
5.1. Installing the STM32CubeProgrammer tool[edit | edit source]
Download
Version v2.20.0
unzip en.stm32cubeprog.zip
Installation
$> ./SetupSTM32CubeProgrammer-2.20.0.linux
User manual
Detailed release note
5.2. Preparing the USB serial link for flashing[edit | edit source]
  • For Windows host PC:
6. Downloading the image and flashing it on the board[edit | edit source]
6.1. Image download[edit | edit source]
  • The STM32MP1 image (binaries) is delivered through one tarball file named
    • en.FLASH-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz for STM32MP135x-DK More info green.png, STM32MP157x-DKx More info green.png and STM32MP157x-EV1 More info green.png
  • Download and install the STM32MP1 image (binaries):
STM32MP1 Starter Package image - STM32MP1-Ecosystem-v6.1.0 release
Download
  • Go on st.com to download the STM32MP1 Starter Package image, en.FLASH-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz file.
Installation
cd <working directory path>/Starter-Package
  • Download the tarball file in this directory
  • Uncompress the tarball file to get the binaries for the different partitions of the image, and the Flash layout files:
tar xvf en.FLASH-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz
Release note
Details of the content of this software package are available in the associated STM32 MPU OpenSTLinux release note.
Archive box.png If you are interested in older releases, please have a look into the section Archives
  • The binaries and the Flash layout files are in the <Starter Package installation directory>/stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/images/stm32mp1/ directory. The most important ones are:
stm32mp1
├── arm-trusted-firmware                                                               TF-A binaries
│   ├── bl2        TF-A binary for FIP binaries creation
│   │   ├── tf-a-<board name>-<boot chain>-<storage>.bin
│   ├── debug        Debug binaries for TF-A
│   │   ├── debug-tf-a-<board name>-<boot chain>-<storage>.stm32                       Debug file for FSBL
│   │   ├── tf-a-bl2-<soc name>-<boot chain>-<storage>.elf                             Debug symbol file for TF-A
│   ├── fwconfig        TF-A device tree for FIP binaries creation
│   │   ├── <board name>-fwconfig-<boot chain>-<storage>.dtb
│   ├── metadata.bin        Meta data binary for METADATA partition for the supported boards
│   ├── tf-a-<board name>-<boot chain>-<storage>.stm32                                 TF-A binary for FSBL partition
├── fip        FIP binaries for FIP partitions and supported boot chains
│   ├── fip-<board name>-<boot chain>-<storage>.bin                                    FIP binary for FIP partition
│   ├── fip-<board name>-<boot chain>-<storage>.txt                                    Configuration file for FIP binary content
├── flashlayout_st-image-weston                                                        Flash layout files (description of the partitions) for the supported boot chains on supported boot devices and boards
│   ├── extensible        Flash layout files for microSD card boot device with no userfs partition but a rootfs partition extended to microSD card size
│   │   ├── FlashLayout_sdcard_<board name>-extensible.tsv                             (recommended setup for package repository service) microSD card boot device with rootfs partition extended to microSD card size
│   ├── fastboot
│   │   ├── FlashLayout_<boot device>_<board name>-fastboot.tsv
│   ├── fastboot-opteemin
│   │   ├── FlashLayout_<boot device>_<board name>-fastboot-opteemin.tsv
│   ├── optee
│   │   ├── FlashLayout_<boot device>_<board name>-optee.tsv
│   └── opteemin
│       ├── FlashLayout_<boot device>_<board name>-opteemin.tsv
├── Kernel        Debug binaries for Linux kernel
│   ├── config-6.6.78        Reference config file for Linux kernel
│   └── vmlinux        Image of the Linux kernel
├── optee        OPTEE-OS binaries
│   ├── debug        Debug binaries for OPTEE-OS
│   │   ├── tee-<board name>-<boot chain>.elf                                           Debug symbol file for OPTEE-OS
│   │   ├── tee-<board name>-<boot chain>-programmer.elf                                Debug symbol file for OPTEE-OS configured for usb/serial
│   ├── tee-header_v2-<board name>-<boot chain>.bin                                   OPTEE-OS binary for FIP binaries creation (FIP partition)
│   ├── tee-header_v2-<board name>-<boot chain>-programmer.bin                        OPTEE-OS binary for FIP binaries creation (FIP-BOOT partition)
│   ├── tee-pageable_v2-<board name>-<boot chain>.bin                                 OPTEE-OS binary for FIP binaries creation (FIP partition)
│   ├── tee-pageable_v2-<board name>-<boot chain>-programmer.bin                      OPTEE-OS binary for FIP binaries creation (FIP-BOOT partition)
│   ├── tee-pager_v2-<board name>-<boot chain>.bin                                    OPTEE-OS binary for FIP binaries creation (FIP partition)
│   ├── tee-pager_v2-<board name>-<boot chain>-programmer.bin                         OPTEE-OS binary for FIP binaries creation (FIP-BOOT partition)
├── scripts
│   └── create_sdcard_from_flashlayout.sh
├── u-boot        U-BOOT binaries
│   ├── debug        Debug binaries for U-BOOT
│   │   ├── u-boot-<soc name>-<u-boot config>.elf                                       Debug symbol file for U-BOOT
│   ├── configuration-<soc name>-<u-boot config>_defconfig                              Reference configuration file for U-Boot
│   ├── u-boot-nodtb-<soc name>-<u-boot config>.bin                                   U-BOOT binary for FIP binaries creation
│   ├── u-boot-<board name>-<u-boot config>.dtb                                         U-BOOT device tree for FIP binaries creation
├── st-image-bootfs-openstlinux-weston-stm32mp1.bootfs.ext4                             Binary for bootfs partition on eMMC and microSD card devices
├── st-image-bootfs-openstlinux-weston-stm32mp1.bootfs.manifest
├── st-image-bootfs-efi-openstlinux-weston-stm32mp1.bootfs.vfat                         Binary for bootfs for EFI partition on eMMC and microSD card devices
├── st-image-bootfs-efi-openstlinux-weston-stm32mp1.bootfs.manifest
├── st-image-userfs-openstlinux-weston-stm32mp1.userfs.ext4                             Binary for userfs partition on eMMC and microSD card devices
├── st-image-userfs-openstlinux-weston-stm32mp1.userfs.manifest
├── st-image-vendorfs-openstlinux-weston-stm32mp1.vendorfs.ext4                         Binary for vendorfs partition on eMMC and microSD card devices
├── st-image-vendorfs-openstlinux-weston-stm32mp1.vendorfs.manifest
├── st-image-weston-openstlinux-weston-stm32mp1.rootfs.ext4                             Binary for rootfs partition on eMMC and microSD card devices
├── st-image-weston-openstlinux-weston-stm32mp1.rootfs.license
├── st-image-weston-openstlinux-weston-stm32mp1.rootfs-license_content.html             License summary for all packages needed to feed all partitions
├── st-image-weston-openstlinux-weston-stm32mp1.rootfs.manifest
├── st-image-weston-openstlinux-weston-stm32mp1.rootfs_nand_4_256_1024_multivolumde.ubi Binary for ubi partition on NAND device
Description:
<board name>:
* stm32mp135f-dk
* stm32mp157a-dk1, stm32mp157a-ev1, stm32mp157c-dk2, stm32mp157c-ed1, stm32mp157c-ev1, stm32mp157d-dk1, stm32mp157d-ev1, ,stm32mp157f-dk2, stm32mp157f-ed1, stm32mp157f-ev1
<soc name>:
* stm32mp13
* stm32mp15
<boot chain>:
* fastboot                  optee boot chain for flashing via fastboot
* fastboot-opteemin         opteemin boot chain for flashing via fastboot
* optee                     optee boot chain
* opteemin                  opteemin boot chain
<boot device>:
* emmc                      Boot via emmc storage
* nor-sdcard                Boot via nor storage for first stage (fsbl, fip) and files system are located on sdcard
* nand-4-256-1024-sdcard    Boot via nand storage for first stage (fsbl, fip) and files system are located on sdcard
* sdcard                    Boot via sdcard storage
* sdcard-EFI                Boot via sdcard storage and bootfs is configurated on EFI
<storage>:
* emmc                      emmc storage
* nor                       nor storage
* nand                      nand storage
* programmer-uart           storage programmation via UART
* programmer-usb            storage programmation via USB
* sdcard                    sdcard storage
<u-boot config>:
* default
* fastboot-emmc             Fastboot config enabled with MMC_DEV Id for emmc
* fastboot-sdcard           Fastboot config enabled with MMC_DEV Id for sdcard
* programmer                Programmer config enabled
6.2. Image flashing[edit | edit source]
The STM32CubeProgrammer tool is used to flash the STM32MP135x-DK Discovery kit More info green.png with the downloaded image. The microSD card, provided in the box, is used as the Flash device: see the STM32 MPU Flash mapping article if you want to know more about the supported Flash memory technologies, and the Flash partitions.
As explained in the boot chain overview, the optee boot chain is the default solution delivered by STMicroelectronics. Thus, the steps below use the image for the optee boot chain.
  • Set the boot switches to the boot from USB position.
  • Connect the USB Type-C (OTG) port (9) to the host PC that contains the downloaded image
  • Insert the delivered microSD card into the dedicated slot ('4)
  • Connect the delivered power supply to the USB Type-C port (8)
  • Press the reset button (12) to reset the board
MB1635 mother board :STM32MP135F 11x11, PMIC, DDR3MB1897 camera moduleCamera module flat cablemicroSD™ card slotEthernet 2 → NetworkEthernet 1 → NetworkUSB Micro-B (STLINK-V3E) → PC Virtual COM port and debugUSB Type-C™ (power 5V-3A)USB Type-C™ (DRP)1st dual USB Type-A (host) → keyboard, mouse or USB driver2nd dual USB Type-A (host) → keyboard, mouse or USB driverReset button
STM32MP135F-DK Discovery kit connections. (picture is not contractual)
cd <Starter Package installation directory>/stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/images/stm32mp1
If you have followed the the proposition to organize the working directory, the command is
 cd Starter-Package/stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/images/stm32mp1
The commands below are for a Linux host PC; however, they are similar for a Windows host PC except that STM32_Programmer_CLI is replaced by STM32_Programmer_CLI.exe.
  • Check that the STM32CubeProgrammer tool is installed and accessible; if not, go to the installation procedure (installing the tools)
STM32_Programmer_CLI --h
STM32_Programmer_CLI -l usb
  Device Index           : USB1
  USB Bus Number         : 002
  USB Address Number     : 002
  Serial number          : 000000000000
  Firmware version       : 0x011a
  • Flash the microSD card with the image for the trusted boot chain
STM32_Programmer_CLI -c port=usb1 -w flashlayout_st-image-weston/optee/FlashLayout_sdcard_stm32mp135f-dk-optee.tsv
This operation takes several minutes (mainly depending of the rootfs size). A successful flashing outputs the following log:
Please note that the logs that you will obtain, might be slightly different, especially if you use a different software release or a different STM32 MPU.
 Product ID  : DFU in HS Mode @Device ID /0x501, @Revision ID /0x1001
 SN          : 800280163530510838343532
 DFU protocol: 1.1
 Board       : --
 Device ID   : 0x0501
 Device name : STM32MP13xx
 Device type : MPU
 Revision ID : --
 Device CPU  : Cortex-A7
 Start Embedded Flashing service
 Memory Programming ...
 Opening and parsing file: tf-a-stm32mp135f-dk-optee-programmer-usb.stm32
   File          : tf-a-stm32mp135f-dk-optee-programmer-usb.stm32
   Partition ID  : 0x01
 Download in Progress:
 File download complete
 Time elapsed during download operation: 00:00:00.450
 RUNNING Program ...
   PartID:      :0x01
 Start operation done successfully at partition 0x01
 Opening and parsing file: fip-stm32mp135f-dk-optee-programmer-usb.bin
   File          : fip-stm32mp135f-dk-optee-programmer-usb.bin
   Partition ID  : 0x03
 Time elapsed during download operation: 00:00:01.437
 RUNNING Program ...
   PartID:      :0x03
 Reconnecting the device ...
 Start operation done successfully at partition 0x03
 Opening and parsing file: tf-a-stm32mp135f-dk-optee-sdcard.stm32
   File          : tf-a-stm32mp135f-dk-optee-sdcard.stm32
   Partition ID  : 0x04
 Time elapsed during download operation: 00:00:00.041
 RUNNING Program ...
   PartID:      :0x04
 Start operation done successfully at partition 0x04
   Partition ID  : 0x05
 Time elapsed during download operation: 00:00:00.040
 RUNNING Program ...
   PartID:      :0x05
 Start operation done successfully at partition 0x05
 Opening and parsing file: metadata.bin
   File          : metadata.bin
   Partition ID  : 0x06
 Time elapsed during download operation: 00:00:00.005
 RUNNING Program ...
   PartID:      :0x06
 Start operation done successfully at partition 0x06
   File          : metadata.bin
   Partition ID  : 0x07
 Time elapsed during download operation: 00:00:00.006
 RUNNING Program ...
   PartID:      :0x07
 Start operation done successfully at partition 0x07
 Opening and parsing file: fip-stm32mp135f-dk-optee-sdcard.bin
   File          : fip-stm32mp135f-dk-optee-sdcard.bin
   Partition ID  : 0x08
 Time elapsed during download operation: 00:00:00.585
 RUNNING Program ...
   PartID:      :0x08
 Start operation done successfully at partition 0x08
 Opening and parsing file: st-image-bootfs-openstlinux-weston-stm32mp1.ext4
   File          : st-image-bootfs-openstlinux-weston-stm32mp1.ext4
   Partition ID  : 0x10
 Time elapsed during download operation: 00:00:30.666
 RUNNING Program ...
   PartID:      :0x10
 Start operation done successfully at partition 0x10
 Opening and parsing file: st-image-vendorfs-openstlinux-weston-stm32mp1.ext4
   File          : st-image-vendorfs-openstlinux-weston-stm32mp1.ext4
   Partition ID  : 0x11
 Time elapsed during download operation: 00:00:07.560
 RUNNING Program ...
   PartID:      :0x11
 Start operation done successfully at partition 0x11
 Opening and parsing file: st-image-weston-openstlinux-weston-stm32mp1.ext4
   File          : st-image-weston-openstlinux-weston-stm32mp1.ext4
   Partition ID  : 0x12
 Time elapsed during download operation: 00:05:01.702
 RUNNING Program ...
   PartID:      :0x12
 Start operation done successfully at partition 0x12
 Opening and parsing file: st-image-userfs-openstlinux-weston-stm32mp1.ext4
   File          : st-image-userfs-openstlinux-weston-stm32mp1.ext4
   Partition ID  : 0x13
 Time elapsed during download operation: 00:01:18.324
 RUNNING Program ...
   PartID:      :0x13
 Start operation done successfully at partition 0x13
Go to the STM32CubeProgrammer article:
  • to know more about the flashing operation
7. Booting the board[edit | edit source]
Once the firmware image is programmed on the STM32MP135x-DK Discovery kit, it is possible to finalize the system configuration:
  • Step 1: check the configuration of the switches
    • The figure below shows the position of the boot switches to boot from the microSD™ card.
Boot from microSD™ card
  • Step 2: (optional) connect a USB keyboard and/or a USB mouse (not provided) using the USB Type-A ports (10 and 11)
  • Step 3: (optional) connect an Ethernet cable (not provided) to the dedicated connectors (5 or 6)
  • Step 4: check that the microSD™ card is inserted into the dedicated slot (4)
  • Step 5: connect the provided power supply (5 V, 3 A) to the USB Type-C® connector (8)
  • Step 6: (optional) connect the ST-LINK/V2-1 USB Micro-B port (7) to a host PC that runs a terminal program with ST-LINK/V2-1 Virtual COM port (such as Minicom on Ubuntu® Linux® PC or Tera Term on Windows® PC)
  • Step 7: press the reset button (12) to reset the board
The board boots and the system is available after few seconds.
The information displayed below might differ from that on your own application, and should just be considered as an example.
First information scrolled on the remote Terminal during boot
Last information scrolled on the remote Terminal during boot
In parallel, a U-Boot splash screen picture is displayed on the DSI display (if one is connected to the board).DSI U-Boot splash screen.png
A user space graphical boot splash screen (PSplash) picture is then briefly displayed on the HDMI monitor if one is connected to the board, or otherwise on the DSI display (if one is connected to the board).DSI user splash screen.png
9. Mouse, keyboard and Ethernet hot-plugs[edit | edit source]
[  926.786326] usb 2-1.1: new low-speed USB device number 3 using ehci-platform
[  926.961413] input: Logitech Optical USB Mouse as /devices/platform/soc/5800d000.usbh-ehci/usb2/2-1/2-1.1/2-1.1:1.0/0003:046D:C016.0001/input/input2
[  926.975098] hid-generic 0003:046D:C016.0001: input: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-5800d000.usbh-ehci-1.1/input0
[ 1215.356377] stm32-dwmac 5800a000.ethernet end0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 1215.363377] IPv6: ADDRCONF(NETDEV_CHANGE): end0: link becomes ready
or on STM32MP13x lines More info.png for the second Ethernet interface
[  117.370989] stm32-dwmac 5800e000.eth2 end1: Link is Up - 100Mbps/Full - flow control rx/tx
[  117.377950] IPv6: ADDRCONF(NETDEV_CHANGE): end1: link becomes ready
10. Remote and local Terminal programs[edit | edit source]
The remote Terminal on your host PC can be used to enter command lines, as shown below with the ip command to query the network interface parameters:
Example of command (ip) executed on the remote Terminal program
Icon to launch a local Terminal program
Wayland Terminal program
Example of command (ip addr) executed on the Wayland Terminal program
11. Executing basic commands[edit | edit source]
The outputs of the commands executed below are examples; the outputs obtained might differ.
11.1. Having a look at the OpenSTLinux directory structure[edit | edit source]
11.2. Identifying the software running on board[edit | edit source]
Obviously, what you obtain might differ from what is displayed on the Output example column.
Software How to get its version Output example
TF-A TF-A Version number
NOTICE: BL2: v2.10-stm32mp-r2(debug):lts-v2.10.x-dirty
U-Boot See the version displayed in the console
2023.10-stm32mp-r2 [...]
Linux kernel
cat /proc/version
Linux version 6.6.78 (xxxx@yyyy) (arm-ostl-linux-gnueabi-gcc (GCC) 13.3.0 ) [...]
GCC
cat /proc/version
Linux version 6.6.78 (xxxx@yyyy) (arm-ostl-linux-gnueabi-gcc (GCC) 13.3.0) [...]
Yocto Project
grep DISTRO_CODENAME /etc/build
DISTRO_CODENAME = Scarthgap
Weston
weston --version
weston 13.0.1
GStreamer
gst-play-1.0 --version
GStreamer 1.22.12
GPU (only on STM32MP15x lines More info.png)
6.4.21.x.xxxxxx built [...]
11.3. Configuration tips[edit | edit source]
11.4. Getting board IP address[edit | edit source]
ip addr show end0
3: end0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    inet xx.xx.xx.xx/xx brd xx.xx.xx.xx scope global dynamic end0
    inet6 xxxx::xx:xx:xx:xx/xx scope link
  • Get the IP address of your board with the ifconfig Linux command line (a deprecated but well-known command):
ifconfig end0
end0      Link encap:Ethernet  HWaddr xx:xx:xx:xx:xx:xx
          inet addr:xx.xx.xx.xx  Bcast:xx.xx.xx.xx  Mask:255.255.252.0
          inet6 addr: xxxx::xx:xx:xx:xx/xx Scope:Link
          RX packets:2619 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1311 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:353250 (344.9 KiB)  TX bytes:118305 (115.5 KiB)
          Interrupt:247
11.5. Copying a file from your host PC to your board (and reciprocally)[edit | edit source]
11.6. Miscellaneous commands[edit | edit source]
The outputs of the commands executed below are examples; the outputs that you obtain might differ.
11.6.1. Printing distribution specific information[edit | edit source]
cat /etc/os-release
ID=openstlinux-weston
NAME="ST OpenSTLinux - Weston - (A Yocto Project Based Distro)"
VERSION="5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11 (Scarthgap)"
VERSION_ID=5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11
VERSION_CODENAME="scarthgap"
PRETTY_NAME="ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11 (Scarthgap)"
CPE_NAME="cpe:/o:openembedded:openstlinux-weston:5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11"
Where:
ID A lower-case string identifying the operating system
NAME A string identifying the operating system
VERSION A string identifying the operating system version, including a release code name
VERSION_ID A lower case string identifying the operating system version
VERSION_CODENAME Code name for the distribution
PRETTY_NAME A full pretty name of the release
CPE_NAME A CPE name for the operating system, following the Common Platform Enumeration Specification[1]
11.6.2. Printing system information[edit | edit source]
uname -a
Linux stm32mp1-XX-XX-XX 6.6.78 #1 SMP PREEMPT Thu Aug 29 15:33:59 UTC 2024 armv7l GNU/Linux
Where:
Linux Kernel name
stm32mp1-XX-XX-XX Network node hostname
6.6.78 Kernel release
#1 SMP PREEMPT Thu Aug 29 15:33:59 UTC 2024 Kernel version
armv7l Machine hardware name
GNU/Linux Operating system
11.6.3. Printing Linux kernel and GCC versions[edit | edit source]
cat /proc/version
Linux version 6.6.78 (oe-user@oe-host) (arm-ostl-linux-gnueabi-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240716) #1 SMP PREEMPT Thu Aug 29 15:33:59 UTC 2024
Where:
Linux Kernel name
version 6.6.78 Kernel release
(xxxx@yyyy) Person (xxxx) who compiled the kernel, and machine (yyyy) where it happened
(arm-ostl-linux-gnueabi-gcc (GCC) 13.3.0 ) Version of the GCC compiler used to compile the kernel
#1 SMP PREEMPT Thu Aug 29 15:33:59 UTC 2024 Kernel version; type of kernel (SMP) and date and time of the kernel compilation
11.6.4. Printing the amount of disk space available on all mounted file systems[edit | edit source]
df -h
Filesystem       Size  Used Avail Use% Mounted on
devtmpfs         126M     0  126M   0% /dev
/dev/mmcblk0p10  3.8G  505M  3.1G  14% /
tmpfs            194M     0  194M   0% /dev/shm
tmpfs             78M  8.8M   69M  12% /run
tmpfs            194M  4.0K  194M   1% /tmp
/dev/mmcblk0p8    55M   18M   33M  35% /boot
tmpfs            194M   20K  194M   1% /var/volatile
/dev/mmcblk0p9    14M  6.7M  6.0M  53% /vendor
/dev/mmcblk0p11  9.8G   47M  9.2G   1% /usr/local
tmpfs             39M  8.0K   39M   1% /run/user/1000
tmpfs             39M  4.0K   39M   1% /run/user/0
Where:
Filesystem Source of the mount point, usually a device
Size Total size in human readable format (e.g. 1K, 234M, 2G)
Used Used size in human readable format
Available Available size in human readable format
Use% Percentage of used size divided by the total size
Mounted on Mount point
12. Examples[edit | edit source]
12.1. Examples running on Cortex-A7[edit | edit source]
Link to the example
Playing an audio/video local file
Playing an audio/video stream
Displaying an image
Running a simple 3D example (GPU usage)
Setting up a WLAN connection
Setting up a Bluetooth connection
Displaying on the HDMI monitor (or TV)
If you are already familiar with the Starter Package for the Yocto-based OpenSTLinux embedded software, fast links to the essential commands are listed below.
With the links below, you will be redirected to other articles; use the back button of your browser to come back to these fast links
Link to the command
Download and install the latest image
Set boot switches
Flash the image on the microSD card
Start a remote Terminal with Minicom
Get the board IP address
Start a remote Terminal over Ethernet
Copy a file from the host PC to the board over Ethernet
14. How to go further?[edit | edit source]
Now that the image is flashed on the STM32MP135x-DK Discovery kit More info green.png, you might want to switch to the STM32MPU Developer Package, in order to modify or tune the Yocto-based OpenSTLinux embedded software with your own developments.
