DCMIPP internal peripheral
Applicable for STM32MP13x lines, STM32MP21x lines, STM32MP23x lines, STM32MP25x lines
  • briefly introduce the DCMIPP peripheral and its main features,
The DCMIPP (digital camera memory interface pixel processor) peripheral is used to receive video data from an external camera sensor device, or from any other digital video equipment supporting its interfaces.
2.1. On STM32MP13x lines [edit | edit source]
The DCMIPP peripheral main features are:
  • Parallel input interface: up to 16 bits in parallel
  • Pipe0 (for data dump): for a direct dump from the camera to the memory without processing
    • Input pixel format: RGB565, RGB888, YUV422, raw Bayer/Mono 8/10/12/14, and ByteStream (JPEG)
    • Output pixel format: any data as-is, Y/Rb: 8/10/12/14 statistics, bit streams
    • Flow selection and frame control: Capture mode in Continuous vs. Snapshot mode
    • Crop and basic decimation
2.2. On STM32MP23x lines  and STM32MP25x lines [edit | edit source]
The DCMIPP peripheral main features are the same as on STM32MP13x lines , with the following extra ones:
  • CSI-2 host input interface: MIPI CSI-2 v1.3, Interleaved packets, four virtual channels. Please refer to CSI internal peripheral for more details
  • Flow selection and frame control: CSI-2 interleaved packets supported, Capture mode in Continuous vs. Snapshot mode
  • Pipe1 (for main usage): with ISP, crop, downsize, ColorConv, decimation, multi-planar
    • Statistic removal
    • Bad pixel removal
    • Integrated image signal processing (ISP) block, which makes possible to connect very low cost camera modules without any embedded ISP: Black level calibration, Statistics extraction, Exposure control, Raw Bayer to RGB conversion (demosaicing), Color conversion to adapt to the sensor and tune the illumination, Contrast enhancement
    • Byte-to-pixel conversion
    • Output pixel format: 888, 565, 422-1, Y8, ARGB and RGBA (coplanar) and 422-2 / 420-2 / 420-3 (multi-planar)
  • Pipe2 (for ancillary usage): with crop, downsize, decimation, coplanar
    • Output pixel format: 888, 565, 422-1, Y8, ARGB and RGBA (coplanar only)
  • Test pattern generator: Color bar or square pattern, up to 16k x 16k, YUV, raw, or Mono
2.3. On STM32MP21x lines [edit | edit source]
The DCMIPP peripheral main features are the same as on STM32MP23x lines  and STM32MP25x lines , with the following extra ones:
    • Integrated image signal processing (ISP) block: Statistics extraction supports the histogram extraction
The DCMIPP peripheral is not used at boot time.
3.2.1. On STM32MP13x lines [edit | edit source]
nonsecure
Visual DCMIPP DCMIPP
3.2.2. On STM32MP21x lines [edit | edit source]
The table below is applicable to any TD flavor (A35-TD or M33-TD) .
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Visual DCMIPP DCMIPP OP-TEE
3.2.3. On STM32MP23x lines [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
3.2.4. On STM32MP25x lines [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Below are listed the software frameworks and drivers managing the DCMIPP peripheral for the embedded software components listed in the above tables.
See also additional information in the DCMIPP device tree configuration article for Linux®.
