Linux Mailbox framework overview
<noinclude
Applicable for STM32MP15x lines, STM32MP21x lines, STM32MP23x lines, STM32MP25x lines
> This article gives information about the Linux® mailbox framework. The mailbox framework is involved in interprocessor communication in heterogeneous multicore systems.
The mailbox framework is used in interprocessor communication to exchange messages or signals between Arm®Cortex®-A and Cortex®-M. The mailbox framework is based on:
  • A mailbox controller that is platform dependent:
    • It is in charge of configuring and handling IRQ from the IPCC peripheral.
    • It provides a generic API to the mailbox client.
  • A mailbox client that is in charge of the message to send or receive.
A general presentation of the mailbox framework is available in the Linux mailbox documentation [1].
The stm32_m0_rproc driver is specifically designed for the Cortex®-M0+ for use with STM32MP25x lines
  • Mailbox controller
The mailbox controller is the stm32_ipcc. It configures and controls the IPCC peripheral
  • Mailbox client
The user can define their own mailbox client.
A mailbox client character device driver is provided as an example to demonstrate communication using a mailbox and shared memory ([2]).
Another example is the RPMsg framework, which uses a mailbox for interprocessor communication. In this case, the mailbox client is the remoteproc driver that forwards services from/to the RPMsg framework.
The APIs are described in the Mailbox client API [3]
3.1. Kernel Configuration[edit | edit source]
The following kernel configurations can be enabled using the Linux Menuconfig tool: Menuconfig or how to configure kernel :
  • Activate STM32 IPCC mailbox controller driver
Device drivers  --->
    -*- Mailbox Hardware Support  --->
        <*> STM32 IPCC Mailbox
  • Activate MAILBOX CDEV mailbox client driver
Device drivers  --->
        <*> mailbox client char device
Please refer to the IPCC device tree configuration.
The Linux mailbox documentation [1] provides with a very simple example of use.
5.1. How to trace[edit | edit source]
Dynamic debug traces can be added using the following commands:
echo -n 'file stm32-ipcc.c +p' > /sys/kernel/debug/dynamic_debug/control
echo -n 'file mailbox.c +p' > /sys/kernel/debug/dynamic_debug/control
