STM32MP2 VDERAM internal memory
  • briefly introduce the VDERAM internal memory peripheral and its main features,
The VDERAM peripheral is 128-Kbyte wide and located physically close to both the video decoder and the video encoder, for optimized performances from the engines.
By default, this memory is exclusively assigned to video encoder and decoder engines (Configuration is done in SYSCFG by the main processor. In that case, it is not accessible by the rest of the system.
When both the video encoder (only for STM32MP25x lines More info.png) and the video decoder are not used, it is possible to allocate this memory to the rest of the system.
In that case, VDERAM is protected via a RISAB memory firewall allowing to define 4-Kbyte granularity regions with different access rights. Each region could be assigned to different execution contexts. VDERAM also owns automatic clock gating (for power management optimization) which can be linked:
  • either on one processor low power state if bank is only assigned to this processor,
  • or on system low power state if bank is assigned to several processors.
VDERAM content is preserved in (LPLV)Stop1/2 low power mode but it is lost in Standby low power mode as not supplied.
VDERAM is not used at boot time and during low power exit sequence. Bootloaders do not have information about the VDERAM product assignment between the video encoder (only for STM32MP25x lines More info.png), the video decoder, and other system components.
3.1.1.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Core/RAM VDERAM VDERAM
3.1.1.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
3.2.1. On STM32MP23x lines More info.png[edit | edit source]
In STM32MPU Embedded Software, when video decoder isavailable depending on part number, they are activated by default to demonstrate the platform capabilities. When video decoder is not available, VDERAM is free for the rest of the system.
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Core/RAM VDERAM VDERAM OP-TEE
BL31
Free for any use if video decoder not used.
3.2.2. On STM32MP25x lines More info.png[edit | edit source]
In STM32MPU Embedded Software, when video encoder and video decoder are available depending on part number, they are activated by default to demonstrate the platform capabilities. When video encoder and video decoder are not available, VDERAM is free for the rest of the system.
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
BL31
Free for any use if video encoder and video decoder not used.
Below are listed the software frameworks and drivers using the VDERAM peripheral for the embedded software components listed in the above tables.
The default assignment set in STMicroelectronics distribution is in line with the platform memory mapping that can be adapted by the platform user.
