This article describes how to get and use the Developer Package of the STM32MPU Embedded Software for any development platform of the STM32MP1 series (STM32MP15 boards and STM32MP13 boards) and STM32MP2 series (STM32MP21 boards, STM32MP23 boards and STM32MP25 boards), in order to modify some of its pieces of software, or to add applications on top of it.
It lists some prerequisites in terms of knowledge and development environment, and gives the step-by-step approach to download and install the STM32MPU Embedded Software components for this Package.
1. Developer Package content[edit | edit source]
If you are not yet familiar with the STM32MPU Embedded Software distribution and its Packages, read the following articles:
- Which STM32MPU Embedded Software Package better suits your needs (and especially the Developer Package chapter)
If you are already familiar with the Developer Package for the STM32MPU Embedded Software distribution, the fast links to essential commands might interest you.
To sum up, this Developer Package provides:
- for the OpenSTLinux distribution (development on Arm® Cortex®-A processor):
- the software development kit (SDK), based on Yocto SDK, for cross-development on a host PC
- the following pieces of software in source code:
- Linux® kernel
- gcnano-driver
- U-Boot
- Trusted Firmware-A (TF-A)
- Open source Trusted Execution Environment (OP-TEE)
- External device tree
- for the Cortex®-M processor firmware development (only for STM32MP15x lines
and STM32MP2 series with both A35-TD flavor
and M33-TD flavor
when supported):
- the integrated development environment (IDE) (STM32CubeIDE)
- the STM32CubeMPU Package including all pieces of software (BSP, HAL, middlewares, and applications) in source code
- the Trusted Firmware-M (TF-M) in source code (for STM32MP2 series only)
Note that the application frameworks for the OpenSTLinux distribution are not available as source code in this Package.
TF-M is available only for STM32MP2 series
2. Developer Package step-by-step overview[edit | edit source]
The steps to get the STM32MPU Embedded Software Developer Package ready for your developments are:
☐ Checking the prerequisites
☐ Installing the Starter Package for your board and the debug symbol files
☐ Installing the components to develop software running on Arm® Cortex®-A (OpenSTLinux distribution)
- ☐ Installing the SDK (mandatory for any development on Arm® Cortex®-A)
- ☐ Installing the OpenSTLinux BSP package (mandatory only if you plan to modify the Linux kernel, to add external out-of-tree Linux kernel modules, to modify U-Boot, TF-A and/or OP-TEE OS)
☐ Installing the components to develop software running Arm Cortex-M (STM32CubeMPU Package)
- ☐ Installing STM32CubeIDE (mandatory for any development on Arm® Cortex®-M)
- ☐ Installing the STM32CubeMPU Package (mandatory only if you plan to modify the STM32Cube firmware)
- develop software running on Arm Cortex-A
- develop software running on Arm Cortex-M (only on STM32MP15x lines
and STM32MP2 series)
3. Checking the prerequisites[edit | edit source]
3.1. Knowledge[edit | edit source]
The STM32MPU Developer Package aims at enriching a Linux-based software for the targeted product: basic knowledge about Linux are recommended to make the most of this Package.
3.2. Development setup[edit | edit source]
- Host PC for cross-compilation and cross-debugging, installed as specified above
- Board assembled and configured as specified in the associated Starter Package article
- Mass storage device (for example, microSD card) to load and update the software images (binaries)
- A serial link between the host PC (through Terminal program) and the board for traces (even early boot traces), and access to the board from the remote PC (command lines)
- An Ethernet link between the host PC and the board for cross-development and cross-debugging through a local network. This is an alternative or a complement to the serial (or USB) link
- A display connected to the board, depending on the technologies available on the board: DSI LCD display, HDMI monitor (or TV) and so on
- A mouse and a keyboard connected through USB ports
4. Installing the Starter Package[edit | edit source]
Before developing with the Developer Package, it is essential to start up your board thanks to its Starter Package. All articles relative to Starter Packages are found in Category:Starter Package: find the one that corresponds to your board, and follow the installation instructions (if not yet done), before going further.
In brief, it means that:
- your board boots successfully
- the flashed image comes from the same release of the STM32MPU Embedded Software distribution as the components that will be downloaded in this article
- the debug symbol files from the flashed image are available in Starter Package image folder
Thanks to the Starter Package,all Flash partitions are populated.
Then, with the Developer Package, it is possible to modify or to upgrade the partitions independently one from the others.
For example, if you only want to modify the Linux kernel (part of bootfs partition), installing the SDK and the Linux kernel are enough; no need to install anything else.
With the debug symbol files, it is also possible to debug the Linux® kernel, U-Boot, OP-TEE, or TF-A with GDB. Especially, the Debug OpenSTLinux BSP components chapter explains how to load the debug symbol files in GDB.
5. Installing the components to develop software running on Arm Cortex-A (OpenSTLinux distribution)[edit | edit source]
5.1. Installing the SDK[edit | edit source]
Optional step: it is mandatory only if you want to modify or add software running on Arm Cortex-A (for example Linux kernel, Linux user space applications...).
The SDK for OpenSTLinux distribution provides a stand-alone cross-development toolchain and libraries tailored to the contents of the specific image flashed in the board. If you want to know more about this SDK, read the SDK for OpenSTLinux distribution article.
For STM32MP1 series
- The STM32MP1 SDK is delivered through a tarball file named : unknown revision
- Download and install the STM32MP1 SDK.
| STM32MP1 Developer Package SDK - STM32MP15-Ecosystem-v2.0.0 release | |
| Download |
You need to be logged on my.st.com before accessing the following link: |
| Installation |
tar xvf unknown revision
$ chmod +x unknown revision/unknown revision
$ ./unknown revision/unknown revision -d <working directory absolute path>/Developer-Package/SDK
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) SDK installer version 3.1-snapshot =========================================================================================== You are about to install the SDK to "<working directory absolute path>/Developer-Package/SDK". Proceed [Y/n]? Extracting SDK................................................................................................................................................................................................................done Setting it up...done SDK has been successfully set up and is ready to be used. Each time you wish to use the SDK in a new shell session, you need to source the environment setup script e.g. $ . <working directory absolute path>/Developer-Package/SDK/environment-setup-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi |
| Release note |
Details about the content of the SDK are available in the associated STM32MP15 ecosystem release note.
- The SDK is in the <SDK installation directory>:
<SDK installation directory> SDK for OpenSTLinux distribution: details in Standard SDK directory structure article ├── environment-setup-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi Environment setup script for Developer Package ├── site-config-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi ├── sysroots │ ├── cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi Target sysroot (libraries, headers, and symbols) │ │ └── [...] │ └── x86_64-ostl_sdk-linux Native sysroot (libraries, headers, and symbols) │ └── [...] └── version-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi
For STM32MP2 series
The STM32MP2 SDK is delivered through two tarball file named :
- SDK-x86_64-stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz for x86_64 host architecture
- SDK-aarch64-stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz for arm64 host architecture
Download and install the STM32MP2 SDK. The software package is provided AS IS, and by downloading it, you agree to be bound to the terms of the software license agreement (SLA0048). The detailed content licenses can be found here.
| STM32MP2 Developer Package SDK - STM32MP2-Ecosystem-v6.1.0 release | |
| Download |
| Installation | For x86_64 host architecture
tar xvf SDK-x86_64-stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz
chmod +x stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/sdk/st-image-weston-openstlinux-weston-stm32mp2.rootfs-x86_64-toolchain-5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.sh
./stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/sdk/st-image-weston-openstlinux-weston-stm32mp2.rootfs-x86_64-toolchain-5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.sh -d <working directory absolute path>/Developer-Package/SDK
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) SDK installer version 5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11 =================================================================================================================================== You are about to install the SDK to "<working directory absolute path>/Developer-Package/SDK". Proceed [Y/n]? Extracting SDK.........................................................................................................................................................................................................................done Setting it up...done SDK has been successfully set up and is ready to be used. Each time you wish to use the SDK in a new shell session, you need to source the environment setup script e.g. $ . <working directory absolute path>/Developer-Package/SDK/environment-setup-cortexa35-ostl-linux |
For arm64 host architecture tar xvf SDK-aarch64-stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz
chmod +x stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/st-image-weston-openstlinux-weston-stm32mp2.rootfs-aarch64-toolchain-5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.sh
./stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/st-image-weston-openstlinux-weston-stm32mp2.rootfs-aarch64-toolchain-5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.sh -d <working directory absolute path>/Developer-Package/SDK
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) SDK installer version 5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11 =================================================================================================================================== You are about to install the SDK to "<working directory absolute path>/Developer-Package/SDK". Proceed [Y/n]? Extracting SDK.........................................................................................................................................................................................................................done Setting it up...done SDK has been successfully set up and is ready to be used. Each time you wish to use the SDK in a new shell session, you need to source the environment setup script e.g. $ . <working directory absolute path>/Developer-Package/SDK/environment-setup-cortexa35-ostl-linux | |
| Release note |
Details about the content of the SDK are available in the associated STM32 MPU ecosystem release note.
<SDK installation directory> SDK for OpenSTLinux distribution: details in Standard SDK directory structure article ├── environment-setup Environment setup script for Developer Package ├── environment-setup-cortexa35-ostl-linux Environment setup script for Developer Package ├── site-config-cortexa35-ostl-linux ├── sysroots │ ├── cortexa35-ostl-linux Target sysroot (libraries, headers, and symbols) │ │ └── [...] │ └── x86_64-ostl_sdk-linux Native sysroot (libraries, headers, and symbols) │ └── [...] └── version-cortexa35-ostl-linux
<SDK installation directory> SDK for OpenSTLinux distribution: details in Standard SDK directory structure article ├── environment-setup Environment setup script for Developer Package ├── environment-setup-cortexa35-ostl-linux Environment setup script for Developer Package ├── site-config-cortexa35-ostl-linux ├── sysroots │ ├── cortexa35-ostl-linux Target sysroot (libraries, headers, and symbols) │ │ └── [...] │ └── aarch64-ostl_sdk-linux Native sysroot (libraries, headers, and symbols) │ └── [...] └── version-cortexa35-ostl-linux
5.1.1. Starting up the SDK[edit | edit source]
The SDK environment setup script must be run once in each new working terminal in which you cross-compile:
For STM32MP1 series
source <SDK installation directory>/environment-setup-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi
- Check the target architecture
echo $ARCH arm
- Check the toolchain binary prefix for the target tools
echo $CROSS_COMPILE arm-ostl-linux-gnueabi-
- Check the C compiler version
$CC --version arm-ostl-linux-gnueabi-gcc (GCC) <GCC version> [...]
- Check that the SDK version is the expected one
echo $OECORE_SDK_VERSION <expected SDK version>
For STM32MP2 series
source <SDK installation directory>/environment-setup-cortexa35-ostl-linux
echo $ARCH arm64
echo $CROSS_COMPILE aarch64-ostl-linux-
$CC --version aarch64-ostl-linux-gcc (GCC) <GCC version> [...]
5.2. Installing the OpenSTLinux BSP packages[edit | edit source]
Optional step: it is mandatory only if you want to modify the BSP (Linux kernel, TF-A, U-Boot, OP-TEE OS), or to add external out-of-tree Linux kernel modules.
OpenSTLinux BSP packages installation instructions:
- The OpenSTLinux BSP package is delivered through a tarball file named en.SOURCES-stm32mp-openstlinux-6.6-yocto-scarthgap-mpu-v25.08.27.tar.gz applicable for all STM32 microprocessor series.
- Download and install the STM32MPU OpenSTLinux BSP package.
| STM32MPU Developer Package - STM32MPU ecosystem v6.1.1 release | |
| Download |
| Installation |
cd <working directory path>/Developer-Package
tar xvf en.SOURCES-stm32mp-openstlinux-6.6-yocto-scarthgap-mpu-v25.08.27.tar.gz |
| Release note |
Details about the content of the OpenSTLinux BSP package are available in the associated STM32 MPU OpenSTLinux release note.
- In sub-directories from <Developer Package installation directory>/stm32mp-openstlinux-6.6-yocto-scarthgap-mpu-v25.08.27/sources/ostl-linux, several tarball archive of the OpenSTLinux BSP components can be found.
- The external device tree directory is named external-dt-<ext-dt version>:
external-dt-6.0-r2 external device tree installation directory ├── external-dt-6.0-r2.tar.xz Tarball file of the external device tree source code ├── README.HOW_TO.txt.stm32mp1 Helper file for external device tree management: reference for stm32mp1 external device tree usage ├── README.HOW_TO.txt.stm32mp2 Helper file for external device tree management: reference for stm32mp2 external device tree usage └── README.HOW_TO.txt.stm32mp2-m33td Helper file for external device tree management: reference for stm32mp2 M33TD flavor external device tree usage
- The Linux kernel installation directory is named linux-stm32mp-<kernel version>:
linux-stm32mp-6.6.78-stm32mp-r2-r0 Linux kernel installation directory ├── [*].patch ST patches to apply during the Linux kernel preparation (see next chapter) ├── fragment-[*].config ST configuration fragments to apply during the Linux kernel configuration (see next chapter) ├── optional-fragment-[*].config Optional ST configuration fragments to apply during the Linux kernel configuration depending on your needs (SMP or not, signature or not, ...) ├── linux-6.6.78.tar.xz Tarball file of the Linux kernel source code ├── README.HOW_TO.txt.stm32mp1 Helper file for Linux kernel management: reference for stm32mp1 Linux kernel build ├── README.HOW_TO.txt.stm32mp2 Helper file for Linux kernel management: reference for stm32mp2 Linux kernel build ├── README.HOW_TO.txt.stm32mp2-m33td Helper file for Linux kernel management: reference for stm32mp2 M33TD flavor Linux kernel build └── series List of all ST patches to apply
- The gcnano driver installation directory is named gcnano-driver-stm32mp-<gcnano driver version>:
gcnano-driver-stm32mp-6.4.21-r1-r0 gcnano-driver installation directory ├── gcnano-driver-stm32mp-6.4.21-r1-r0.tar.xz Tarball file of the gcnano-driver source code ├── README.HOW_TO.txt.stm32mp1 Helper file for gcnano-driver management: reference for stm32mp1 gcnano-driver build ├── README.HOW_TO.txt.stm32mp2 Helper file for gcnano-driver management: reference for stm32mp2 gcnano-driver build └── README.HOW_TO.txt.stm32mp2-m33td Helper file for gcnano-driver management: reference for stm32mp2 M33TD flavor gcnano-driver build
- The ddr phy installation directory is named stm32mp-ddr-phy-<ddr phy version>:
stm32mp-ddr-phy-A2022.11-r0 ddr-phy installation directory ├── README.HOW_TO.txt.stm32mp2 Helper file for ddr phy management: reference for stm32mp2 ddr-phy use ├── README.HOW_TO.txt.stm32mp2-m33td Helper file for ddr phy management: reference for stm32mp2 M33TD flavor ddr-phy use └── stm32mp-ddr-phy-A2022.11-r0.tar.xz Tarball file of the stm32mp-ddr-phy binaries
- The OP-TEE installation directory is named optee-os-stm32mp-<OP-TEE version>:
optee-os-stm32mp-4.0.0-stm32mp-r2-r0 OP-TEE installation directory ├── [*].patch ST patches to apply during the OP-TEE preparation (see next chapter) ├── fiptool-stm32mp.stm32mp1 Tool for stm32mp1 fip generation ├── fiptool-stm32mp.stm32mp2 Tool for stm32mp2 fip generation ├── fiptool-stm32mp.stm32mp2-m33td Tool for stm32mp2 M33TD flavor fip generation ├── fonts.tar.gz fonts for OPTEE-OS ├── Makefile.sdk.stm32mp1 Makefile for the stm32mp1 OP-TEE compilation ├── Makefile.sdk.stm32mp2 Makefile for the stm32mp2 OP-TEE compilation ├── Makefile.sdk.stm32mp2-m33td Makefile for the stm32mp2 M33TD flavor OP-TEE compilation ├── optee-os-stm32mp-4.0.0-stm32mp-r2-r0.tar.xz Tarball file of the OP-TEE source code ├── README.HOW_TO.txt.stm32mp1 Helper file for OP-TEE management: reference for stm32mp1 OP-TEE build ├── README.HOW_TO.txt.stm32mp2 Helper file for OP-TEE management: reference for stm32mp2 OP-TEE build ├── README.HOW_TO.txt.stm32mp2-m33td Helper file for OP-TEE management: reference for stm32mp2 M33TD flavor OP-TEE build └── series List of all ST patches to apply
- The U-Boot installation directory is named u-boot-stm32mp-<U-Boot version>:
u-boot-stm32mp-v2023.10-stm32mp-r2-r0 U-Boot installation directory ├── [*].patch ST patches to apply during the U-Boot preparation (see next chapter) ├── fiptool-stm32mp.stm32mp1 Tool for stm32mp1 fip generation ├── fiptool-stm32mp.stm32mp2 Tool for stm32mp2 fip generation ├── fiptool-stm32mp.stm32mp2-m33td Tool for stm32mp2 M33TD flavor fip generation ├── fragment-[*].fb_cfg ST configuration fragments to apply during the U-Boot configuration to support fastboot ├── Makefile.sdk.stm32mp1 Makefile for the stm32mp1 U-Boot compilation ├── Makefile.sdk.stm32mp2 Makefile for the stm32mp2 U-Boot compilation ├── Makefile.sdk.stm32mp2-m33td Makefile for the stm32mp2 M33TD flavor U-Boot compilation ├── README.HOW_TO.txt.stm32mp1 Helper file for U-Boot management: reference for stm32mp1 U-Boot build ├── README.HOW_TO.txt.stm32mp2 Helper file for U-Boot management: reference for stm32mp2 U-Boot build ├── README.HOW_TO.txt.stm32mp2-m33td Helper file for U-Boot management: reference for stm32mp2 M33TD flavor U-Boot build ├── series List of all ST patches to apply └── u-boot-stm32mp-v2023.10-stm32mp-r2-r0.tar.xz Tarball file of the U-Boot source code
- The TF-A installation directory is named tf-a-stm32mp-<TF-A version>:
tf-a-stm32mp-v2.10.13-stm32mp-r2-r0 TF-A installation directory ├── [*].patch ST patches to apply during the TF-A preparation (see next chapter) ├── fiptool-stm32mp.stm32mp1 Tool for stm32mp1 fip generation ├── fiptool-stm32mp.stm32mp2 Tool for stm32mp2 fip generation ├── fiptool-stm32mp.stm32mp2-m33td Tool for stm32mp2 M33TD flavor fip generation ├── Makefile.sdk.stm32mp1 Makefile for the stm32mp1 TF-A compilation ├── Makefile.sdk.stm32mp2 Makefile for the stm32mp2 TF-A compilation ├── Makefile.sdk.stm32mp2-m33td Makefile for the stm32mp2 M33TD flavor TF-A compilation ├── README.HOW_TO.txt.stm32mp1 Helper file for TF-A management: reference for stm32mp1 TF-A build ├── README.HOW_TO.txt.stm32mp2 Helper file for TF-A management: reference for stm32mp2 TF-A build ├── README.HOW_TO.txt.stm32mp2-m33td Helper file for TF-A management: reference for stm32mp2 M33TD flavor TF-A build ├── series List of all ST patches to apply └── tf-a-stm32mp-v2.10.13-stm32mp-r2-r0.tar.xz Tarball file of the TF-A source code
- The TF-M-TESTS installation directory is named tf-m-tests-<TF-M-TESTS version>:
tf-m-tests-stm32mp-v2.1.0-stm32mp-r1-r0 TF-M-TESTS installation directory ├── [*].patch ST patches to apply during the TF-M-TESTS preparation (see next chapter) ├── README.HOW_TO.txt.stm32mp2-m33td Helper file for TF-M-TESTS management: reference for stm32mp2 M33TD flavor TF-M-TESTS build ├── series List of all ST patches to apply └── tf-m-tests-stm32mp-v2.1.0-stm32mp-r1-r0.tar.xz Tarball file of the TF-M-TESTS source code
- The TF-M installation directory is named tf-m-<TF-M version>:
tf-m-stm32mp-v2.1.0-stm32mp-r1-r0 TF-M installation directory ├── Makefile.sdk.stm32mp2-m33td Makefile for the stm32mp2 M33TD flavor TF-M compilation ├── README.HOW_TO.txt.stm32mp2-m33td Helper file for TF-M management: reference for stm32mp2 M33TD flavor TF-M build ├── series List of all ST patches to apply ├── tf-m-stm32mp-v2.1.0-stm32mp-r1-r0-diff.gz ST patches applied on top of TF-M community source code reference └── tf-m-stm32mp-v2.1.0-stm32mp-r1-r0.tar.xz Tarball file of the TF-M source code
- The M33TD PROJECTS installation directory is named m33tdprojectst-starter-stm32mp2-<M33TD PROJECTS version>:
m33tdprojects-starter-stm32mp2-1.2.0-r0 M33TD PROJECTS installation directory ├── m33tdprojects-starter-stm32mp2-1.2.0-r0.tar.xz Tarball file of the M33TD PROJECTS source code ├── Makefile.sdk.stm32mp2-m33td Makefile for the stm32mp2 M33TD flavor TF-M compilation └── README.HOW_TO.txt.stm32mp2-m33td Helper file for M33TD PROJECTS management: reference for stm32mp2 M33TD flavor M33TD PROJECTS build
- The sdk infos installation directory is named sdk-infos-<sdk infos version>:
sdk-infos-1.0-r0 sdk infos installation directory ├── generated_build_script-stm32mpx.sh Tool for source code compilation under SDK ├── README.HOW_TO.txt.stm32mp1 Helper file for sdk infos management: reference for stm32mp1 sdk infos use ├── README.HOW_TO.txt.stm32mp2 Helper file for sdk infos management: reference for stm32mp2 sdk infos use └── README.HOW_TO.txt.stm32mp2-m33td Helper file for sdk infos management: reference for stm32mp2 M33TD flavor sdk infos use
5.2.1. Building and deploying OpenSTLinux BSP packages component per component[edit | edit source]
5.2.1.1. Building and deploying the external device tree for the first time[edit | edit source]
Prerequisite: the SDK is installed.
Open the <external device tree installation directory>/README.HOW_TO.txt.<board flavor>[1] helper file, and execute its instructions to:
☐ setup a software configuration management (SCM) system (git) for the external device tree (optional but recommended)
☐ export the path of external device tree directory into the variable EXTDT_DIR
The external device tree is now set-up and can be used during compilation.
5.2.1.2. Building and deploying the ddr firmware for the first time (only on STM32MP2 series)[edit | edit source]
Open the <ddr firmware installation directory>/README.HOW_TO.txt.<board flavor>[1] helper file, and execute its instructions to:
☐ export the path of ddr firmware tree directory into the variable FWDDR_DIR
The ddr firmware path is now set-up and can be used during compilation.
5.2.1.3. Building and deploying the Linux kernel for the first time[edit | edit source]
Prerequisite: the SDK is installed. It is mandatory to execute once the steps specified below before modifying the Linux kernel, or adding external out-of-tree Linux kernel modules.
The partitions related to the Linux kernel are:
- the bootfs partition that contains the Linux kernel U-Boot image (uImage) and device tree
- the rootfs partition that contains the Linux kernel modules
The Linux kernel might be cross-compiled, either in the source code directory, or in a dedicated directory different from the source code directory.
This last method is recommended as it clearly separates the files generated by the cross-compilation from the source code files.
Open the <Linux kernel installation directory>/README.HOW_TO.txt.<board flavor>[1] helper file, and execute its instructions to:
☐ setup a software configuration management (SCM) system (git) for the Linux kernel (optional but recommended)
☐ prepare the Linux kernel (applying the ST patches)
☐ configure the Linux kernel (applying the ST fragments)
☐ cross-compile the Linux kernel
☐ deploy the Linux kernel (that is, update the software on board)
The Linux kernel is now installed: let's modify the Linux kernel.
5.2.1.4. Building and deploying the gcnano-driver for the first time (only on STM32MP15x lines
, STM32MP23x lines
and STM32MP25x lines
Prerequisite:
- the SDK is installed.
- the Linux kernel is built as explained here
It is mandatory to execute once the steps specified below before modifying gcnano-driver.
A kernel module depends on the Linux kernel version. If kernel module is not built with the correct Linux kernel, the kernel could refuse the module to be loaded.
Open the <gcnano-driver installation directory>/README.HOW_TO.txt.<board flavor>[1] helper file, and execute its instructions to:
☐ setup a software configuration management (SCM) system (git) for the gcnano-driver (optional but recommended)
☐ cross-compile the gcnano-driver
☐ deploy the gcnano-driver (that is, update the software on board)
The gcnano-driver is now installed.
5.2.1.5. Building and deploying the U-Boot for the first time[edit | edit source]
Prerequisite: the SDK is installed. It is mandatory to execute once the steps specified below before modifying the U-Boot.
As explained in the boot chain overview, the trusted boot chain is the default solution delivered by STMicroelectronics.
Within this scope, the partition related to the U-Boot is the ssbl one that contains the U-Boot and its device tree blob.
Open the <U-Boot installation directory>/README.HOW_TO.txt.<board flavor>[1] helper file, and execute its instructions to:
☐ setup a software configuration management (SCM) system (git) for the U-Boot (optional but recommended)
☐ prepare the U-Boot (applying the ST patches)
☐ cross-compile the U-Boot
☐ deploy the U-Boot (that is, update the software on board)
The U-Boot is now installed: let's modify the U-Boot.
5.2.1.6. Building and deploying the TF-A for the first time[edit | edit source]
Prerequisite: the SDK is installed. It is mandatory to execute once the steps specified below before modifying the TF-A.
Within this scope, the partition related to the TF-A is the fsbl one.
Open the <TF-A installation directory>/README.HOW_TO.txt.<board flavor>[1] helper file, and execute its instructions to:
☐ setup a software configuration management (SCM) system (git) for the TF-A (optional but recommended)
☐ prepare the TF-A (applying the ST patches)
☐ cross-compile the TF-A
☐ deploy the TF-A (that is, update the software on board)
The TF-A is now installed: let's modify the TF-A.
5.2.1.7. Building and deploying the OP-TEE for the first time[edit | edit source]
Prerequisite: the SDK is installed. It is mandatory to execute once the steps specified below before modifying the OP-TEE.
As explained in the boot chain overview, the trusted boot chain is the default solution delivered by STMicroelectronics. Within this scope, the partition related to the OP-TEE is the fsbl one.
Open the <OP-TEE installation directory>/README.HOW_TO.txt.<board flavor>[1] helper file, and execute its instructions to:
☐ setup a software configuration management (SCM) system (git) for the OP-TEE (optional but recommended)
☐ prepare the OP-TEE (applying the ST patches)
☐ cross-compile the OP-TEE
☐ deploy the OP-TEE (that is, update the software on board)
The OP-TEE is now installed: let's modify the OP-TEE.
5.2.2. Building and deploying the OpensSTLinux BSP packages using SDK-info utilities[edit | edit source]
SDK-infos is an optional component (on top of above ones) that facilitates the extraction, configuration and build of the OpensSTLinux BSP packages. This directory provides a script and README to help to generate a build environment adapted to your needs and to manage OpensSTLinux components diversity.
Prerequisite: the SDK is installed. It is mandatory to execute the build steps specified below.
5.2.2.1. How to use SDK-infos[edit | edit source]
The script "generated_build_script-stm32mpx.sh" uses the whole "README.HOW_TO.txt" files to generate a helper script to compile the component needed for your target.
- Different options are supported and can be accessed through script help:
$> ./generated_build_script-stm32mpx.sh help
generated_build_script <machine name>
<machine name>: name of the machine which can be use for sdk compilation
- stm32mp1 or stm32mp1-mx: to compile STM32MP1 series' boards
either
- via device tree from components themselves or external-dt source
- or via device tree from components themselves or external board provided by STM32CubeMX
- stm32mp2 or stm32mp2-mx: to compile STM32MP2 series' boards
for A35-TD flavor
either
- stm32mp2-m33td or stm32mp2-m33td-mx: to compile STM32MP2 series' boards
for M33-TD flavor
either
- To generate a helper script for ST board (ex.: stm32mp257f-dk):
$> ./sdk-infos/generated_build_script-stm32mpx.sh stm32mp2
This command generates a script on root directory for all source codes from Developer Package: sources/*/sdk_compilation-stm32mp2-my-custom-board.sh
- To generate a helper script for board with Cube MX device tree(ex.: stm32mp157f-mx-dk):
$> ./sdk-infos/generated_build_script-stm32mpx.sh stm32mp1-mx
This command generates a script, sources/*/sdk_compilation-stm32mp1-mx-my-custom-board.sh, on root directory for all source codes from Developer Package.
After the helper script was correctly filled with your configuration (see SDK-infos README for examples and explanation), you can start to use it.
Usage helper script, way of working (here we use a helper script named sdk_compilation-stm32mp-xxx.sh as example)
- To extract the sources codes of components
$> ./sdk_compilation-stm32mp-xxx.sh extract
- To generate boot stage of Cortex-A
$> ./sdk_compilation-stm32mp-xxx.sh compile-for-fip $> ./sdk_compilation-stm32mp-xxx.sh deploy-for-fip
This command generates bl2 and fip binaries for Cortex-A
- To generate binary to flashing via Cortex-A
$> ./sdk_compilation-stm32mp-xxx.sh programmer
This command generates bl2 and fip binaries for flashing on Cortex-A
- To generate kernel and kernel modules:
$> ./sdk_compilation-stm32mp-xxx.sh linux-stm32mp-configure $> ./sdk_compilation-stm32mp-xxx.sh linux-stm32mp-compile $> ./sdk_compilation-stm32mp-xxx.sh linux-stm32mp-deploy
This command generates the kernel image and device tree and exports kernel modules. The Kernel modules can be found stripped and not stripped on deploy directory.
$> ./sdk_compilation-stm32mp-xxx.sh gcnano-driver-stm32mp-compile $> ./sdk_compilation-stm32mp-xxx.sh gcnano-driver-stm32mp-deploy
5.2.2.2. Known restrictions[edit | edit source]
| Coming soon |
6. Installing the components to develop software running on Arm Cortex-M (only on STM32MP15x lines
and STM32MP2 series)[edit | edit source]
6.1. Installing STM32CubeIDE[edit | edit source]
Optional step: it is needed if you want to modify or add software running on Arm Cortex-M.
The table below explains how to download and install STM32CubeIDE which addresses STM32 MCU, and also provides support for Cortex-M inside STM32 MPU.
| STM32CubeIDE for Linux® host PC | STM32CubeIDE for Windows® host PC | |
| Download |
Version 2.0.0
Version 2.0.0
| Installation guide | ||
| User manual | ||
| Detailed release note |
| Restrictions |
6.2. Installing the STM32CubeMPU Package[edit | edit source]
Optional step: it is mandatory only if you want to modify the STM32CubeMPU Package.
For STM32MP1 series:
- The STM32CubeMP1 Package is delivered through an archive file named stm32cubemp1-v1-7-0.zip.
- Download and install the STM32CubeMP1 Package
The software package is provided AS IS, and by downloading it, you agree to be bound to the terms of the software license agreement (SLA0048). The detailed content licenses can be found here..
| STM32MP1 Developer Package STM32CubeMP1 Package - v6.1.0 release | |
| Download |
| Installation |
unzip stm32cubemp1-v1-7-0.zip |
| Release note |
Details about the content of the STM32CubeMP1 Package are available in the STM32Cube_FW_MP1_V1.7.0/Release_Notes.html file.
- The STM32CubeMP1 Package installation directory is in the <Developer Package installation directory> directory, and is named STM32Cube_FW_MP1_V1.7.0:
STM32Cube_FW_MP1_V1.7.0 STM32CubeMP1 Package: details in STM32CubeMP15 Package content article ├── Drivers │ ├── BSP BSP drivers for the supported STM32MP1 boards │ │ └── [...] │ ├── CMSIS │ │ └── [...] │ └── STM32MP1xx_HAL_Driver HAL drivers for the supported STM32MP1 devices │ └── [...] ├── _htmresc │ └── [...] ├── License.md ├── Middlewares │ └── [...] ├── package.xml ├── Projects │ ├── STM32CubeProjectsList.html List of examples and applications for STM32CubeMP1 Package │ ├── STM32MP157C-DK2 Set of examples and applications → STM32MP15 Discovery kits │ │ └── [...] │ └── STM32MP157C-EV1 Set of examples and applications → STM32MP15 Evaluation boards │ └── [...] ├── Readme.md ├── Release_Notes.html Release note for STM32CubeMP1 Package └── Utilities └── [...]
For STM32MP2 series:
- The STM32CubeMP2 Package is delivered through an archive file named stm32cubemp2-v1-2-0.zip.
- Download and install the STM32CubeMP2 Package
| STM32MP2 Developer Package STM32CubeMP2 Package - v6.1.0 release | |
| Download |
| Installation |
unzip stm32cubemp2-v1-2-0.zip |
| Release note |
Details about the content of the STM32CubeMP2Package are available in the STM32CubeMP2/Release_Notes.html file.
- The STM32CubeMP2 Package installation directory is in the <Developer Package installation directory> directory, and is named STM32Cube_FW_MP2_V1.2.0:
STM32Cube_FW_MP2_V1.2.0 STM32CubeMP2 Package: details in STM32CubeMP2 Package content article ├── _htmresc │ └── [...] ├── Drivers │ ├── BSP BSP drivers for the supported STM32MP2 boards │ │ └── [...] │ ├── CMSIS │ │ └── [...] │ └── STM32MP2xx_HAL_Driver HAL drivers for the supported STM32MP2 devices │ └── [...] ├── Middlewares │ └── [...] ├── Projects │ ├── _htmresc │ │ └── [...] │ ├── STM32MP215F-DK Set of examples and applications → STM32MP21 Discovery boards │ │ └── [...] │ ├── STM32MP235F-DK Set of examples and applications → STM32MP23 Discovery boards │ │ └── [...] │ ├── STM32MP257F-DK Set of examples and applications → STM32MP25 Discovery boards │ │ └── [...] │ ├── STM32MP257F-EV1 Set of examples and applications → STM32MP25 Evaluation boards │ │ └── [...] │ ├── Release_Notes.html │ └── STM32CubeProjectsList.html List of examples and applications for STM32CubeMP2 Package ├── Utilities │ └── [...] ├── CODE_OF_CONDUCT.md ├── CONTRIBUTING.md ├── License.md ├── package.xml ├── Package_license.html ├── Package_license.md ├── README.md ├── Release_Notes.html Release note for STM32CubeMP2 Package ├── sbom_cdx.json └── SECURITY.md
The STM32CubeMPU Package is now installed: let's develop software running on Arm Cortex-M.
7. Developing software running on Arm Cortex-A[edit | edit source]
7.1. Modifying the Linux kernel[edit | edit source]
Prerequisites:
The <Linux kernel installation directory>/README.HOW_TO.txt helper file gives the commands to:
You can refer to the following simple examples:
- Modification of the kernel configuration
- Modification of the device tree
- Modification of a built-in device driver
- Modification of an external in-tree module
- Adding an external out-of-tree Linux kernel module
7.2. Adding Linux user space applications[edit | edit source]
Prerequisites:
- the SDK is started up
Once a suitable cross-toolchain (OpenSTLinux SDK) is installed, it is easy to develop a project outside of the OpenEmbedded build system.
There are different ways to use the SDK toolchain directly, among which Makefile and Autotools.
Whatever the method, it relies on:
- the sysroot that is associated with the cross-toolchain, and that contains the header files and libraries needed for generating binaries (see target sysroot)
- the environment variables created by the SDK environment setup script (see SDK startup)
You can refer to the following simple example:
7.3. Modifying the U-Boot[edit | edit source]
Prerequisites:
The <U-Boot installation directory>/README.HOW_TO.txt helper file gives the commands to:
7.4. Modifying the TF-A[edit | edit source]
Prerequisites:
The <TF-A installation directory>/README.HOW_TO.txt helper file gives the commands to:
7.5. Modifying the OP-TEE[edit | edit source]
Prerequisites:
The <OP-TEE installation directory>/README.HOW_TO.txt helper file gives the commands to:
8. Developing software running on Arm Cortex-M[edit | edit source]
This chapters are valid only for STM32MP15x lines
and STM32MP2 series.
Refer to FwST-M_Packages articles to create a STM32CubeMPU project from scratch or open/modify an existing one from STM32CubeMPU package.
9. Fast links to essential commands[edit | edit source]
If you are already familiar with the Developer Package for the STM32MPU Embedded Software distribution, fast links to the essential commands are listed below.
| With the links below, you will be redirected to other article; use the back button of your browser to come back to these fast links |
10. How to go further?[edit | edit source]
Now that your developments are ready, you might want to switch to the STM32MPU Distribution Package, in order to create your own distribution and to generate your own SDK and image.
11. References[edit | edit source]
