CRYP internal peripheral
  • briefly introduce the CRYP peripheral and its main features,
The CRYP peripheral provides hardware acceleration to encrypt or decrypt data using the DES[1], TDES[2] or AES[3] algorithms. It also supports multiple key sizes and chaining modes.
3.1.1. On STM32MP13x lines More info.png[edit | edit source]
CRYP could be used in ROM code during boot process for FSBL decryption.
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Security CRYP CRYP ROM code allocation is managed with the bit 7 in OTP 9
3.1.2. On STM32MP15x lines More info.png[edit | edit source]
The CRYP peripheral is not used at boot time.
3.1.3. On STM32MP21x lines More info.png[edit | edit source]
3.1.3.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Security CRYP CRYP1 ROM code allocation is managed with the bit 8 in OTP 16
CRYP2
3.1.3.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
CRYP2
3.1.4. On STM32MP23x lines More info.png[edit | edit source]
3.1.4.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
CRYP2
3.1.4.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
CRYP2
3.1.5. On STM32MP25x lines More info.png[edit | edit source]
3.1.5.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
CRYP2
3.1.5.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
CRYP2
nonsecure
Security CRYP CRYP Assignment (single choice)
nonsecure
Cortex-M4
Security CRYP CRYP1 Assignment (single choice)
CRYP2
3.2.3. On STM32MP21x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Security CRYP CRYP1 OP-TEE
CRYP2 OP-TEE
3.2.4. On STM32MP23x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
CRYP2 OP-TEE
3.2.5. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
CRYP2 OP-TEE
Below are listed the software frameworks and drivers managing the CRYP peripheral for the embedded software components listed in the above tables.
