Arm Cortex-M33
  • briefly introduce the Arm® Cortex®-M33 and its main features,
The Arm® Cortex®-M33 Arm® is a Armv8-M 32-bit processor. Among a wide range of features, it includes:
  • a memory protection unit (MPU)
  • a single-precision floating point unit (FPU)
  • a DSP extension
  • TrustZone security
The Cortex-M33 supports a nonsecure mode and a secure mode thanks to TrustZone that define two hardware execution contexts, named Cortex-M33 nonsecure and Cortex-M33 secure.
The Cortex-M33 is present across all the STM32MP2 series.
In A35-TD flavor , the Cortex-M33 is seen as a coprocessor controlled by Arm® Cortex®-A35 Arm® . In M33-TD flavor , the Cortex-M33 is directly started by the ROM code after a power on reset. It is the principal processor and doesn't depend on the Cortex-A35 for its execution.
3.1.1.1. For A35-TD flavor [edit | edit source]
The Cortex-M33 can be startup at boot time by U-Boot SSBL (see boot chain) , as explained in the How to start the Cortex-M coprocessor from U-Boot article.
Thanks to a specific OP-TEE trusted application (TA) running on the Arm® TrustZone and to the Resource Isolation Framework, it is possible to authenticate the Cortex®-M33 firmware and install it on isolated memory region to ensure its integrity during the execution. For details, refer to How to protect the Cortex-M coprocessor firmware article.
Domain Peripheral Boot time allocation Comment
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Core/Processors Arm® Cortex®-M33 Arm® Cortex®-M33 How to start the Cortex-M coprocessor from U-Boot
3.1.1.2. For M33-TD flavor [edit | edit source]
The Cortex-M33 is directly started by the ROM code after a power on reset. It is the principal processor and doesn't depend on the Cortex-A35 for its execution.
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
For A35-TD flavor : The Cortex-M33 can be started and stopped at runtime by the Linux remoteproc framework.
Thanks to a specific OP-TEE trusted application (TA) running on the Arm® TrustZone and to the ETZPC peripheral, it is possible to authenticate the Cortex-M33 firmware and to install it on isolated memory region to ensure its integrity during the execution. For details, refer to How to protect the Cortex-M coprocessor firmware article.
Once started, the Cortex-M33 executes the STM32CubeMP2 firmware, which controls the Cortex-M33 internal resources (MPU, WFI,...)
3.2.1. On STM32MP21x lines [edit | edit source]
3.2.1.1. For A35-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Core/Processors Arm® Cortex®-M33 Arm® Cortex®-M33 OP-TEE Controlled by LInux or OP-TEE.
Running the STM32CubeMP2 firmware.
3.2.1.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
3.2.2. On STM32MP23x lines [edit | edit source]
3.2.2.1. For A35-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
3.2.2.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
3.2.3. On STM32MP25x lines [edit | edit source]
3.2.3.1. For A35-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
3.2.3.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Core/Processors Arm® Cortex®-M33 (coprocessor) Arm® Cortex®-M33 (coprocessor)
Below are listed the software frameworks and drivers managing the Arm® Cortex®-M33 (coprocessor) for the embedded software components listed in the above tables.
  • The Cortex-M33 runs applications developed using to the STM32CubeMP2 distribution package.
  • STM32CubeMP2 distribution package could be associated to TF-M for security services management.
  • The Cortex-M33 can be startup at boot time or at runtime, with or without firmware authentication, using the remoteproc frameworks available in different components of the OpenSTLinux distribution:
  • The Cortex-M33 operates as a coprocessor, either autonomously as any external microcontroller, or communicating with the Cortex-A35 processor via the RPMsg communication pipe.
The Cortex-M33 assignment can be done via the STM32CubeMX graphical tool (and manually completed if needed).
This tool also helps to configure two aspects:
  • Which Cortex-A35 software component is in charge of Cortex-M33 management
  • Which peripherals are assigned to Cortex-M33
STM32CubeMX allows generating:
  • partial device trees (pin control and clock tree and firewall configuration) for the OpenSTLinux software components,
Refer to the Arm website[1] for more detailed information on this core.
