STM32MP215x-DKx - hardware description
Applicable for STM32MP21x lines
Warning DB.png Important
This board is not yet available. It is based on the STM32MP21 microprocessor, that is in preproduction stage, with engineering samples only available for early adopters: thanks to contact your local sales if you want to be part of this Alpha program
STM32MP215F-DK.jpg This article provides an overview of STM32MP215x-DK Discovery kits.
  • How to assemble the different elements provided in the commercial box and additional optional accessories
  • What are the different components on the boards
  • How to connect the boards to external material
  • How to configure the board for boot
  • What are the configurations of the connector pins
This article is valid for the STM32MP215F-DK Info.png Discovery kit: the part numbers are specified in the STM32MP21 microprocessor part numbers article.
This article is an introduction to the STM32MP215x-DK Discovery kit. For more detailed information, refer to the STM32MP215x-DK Discovery kit user manuals.
2. Board assembly and connections[edit | edit source]
The STM32MP215x-DKx Discovery kit package (STM32MP215F-DK Info.png) contains only the MB2059 motherboard.
STM32MP215x-DKx Discovery kit out of the box
STM32MP215F-DK Discovery kit shown here (picture not contractual)
Display and camera are available for purchase to complete this basic setup.
The complete set contains:
STM32MP215F-DK and additional accessories kits shown here (picture is not contractual)
Position Description
1 MB2059 main board
2 MicroSD card
3 4.3" TFT 480*272 pixels with LED Backlight and capacitive touch panel ROCKTECH RK043FN78H-CT661C provided by ROCKTECH (optional)
4 Camera board FFC (provided with the B-CAMS-IMX package) (optional)
5 MB1854 board AI camera provided with the B-CAMS-IMX package (optional)
STM32MP215x-DK Discovery kit assembly
STM32MP215F-DK shown here (picture is not contractual)
2.1. Connecting the display to the board (optional)[edit | edit source]
  • Find the DISPLAY connector (CN8) on the top side of the MB2059 main board
  • Flip the connector’s latch up
Display board assembly - step 1 (picture is not contractual)
Display board assembly - step 2 (picture is not contractual)
  • Insert the LCD’s cable with the exposed contacts facing down
Display board assembly - step 3 (picture is not contractual)
  • Flip the connector’s latch down to secure the cable
Display board assembly - step 4 (picture is not contractual)
2.2. Connecting the MB1854 camera board to the board (optional)[edit | edit source]
Camera board assembly (picture is not contractual)
  • Find the camera ports on the STM32MP215x-DK Discovery kit (CN4) (#1 in the image above) and MB1854 (CN1) (#2 in the image above). The camera box contains one FFC.
  • For each port:
    • Pull the plastic (#1 in the image below) lightly to insert the contact side of the FFC towards the board (#2 in the image below).
    • Push the plastic carefully to hold the FFC (#3 in the image below).
2.3. Connecting USB to TTL serial cables[edit | edit source]
To have 2 consoles on your workstation , one for M33-TD and one for A35-TD, 2 "USB to TTL serial cables" are needed.
2.4. STM32MP215x-DK Discovery kit assembled and connected[edit | edit source]
The picture below presents the recommended board connections for getting started with the STM32MP215x-DKx Discovery kits
To start the board, it is recommended to go through the corresponding Starter Package article first.
As shown in the board overview, other connectors are available for this board (for example, the GPIO expansion connector). </noinclude>
MB2059 motherboard: STM32MP215F 14x14MicroSD<sup>™</sup> card slotReset buttonEthernet (network)USB Power Delivery Type-C (Power) and USB2.0 DRD/OTG Type-C (programmable through STM32CubeProgrammer)CSI cameraLTDC displayUSB to TTL serial cables
STM32MP215x-DKx Discovery kit connections (picture is not contractual)
3. Board overview[edit | edit source]
Main board MB2095, revision B: part of the STM32MP215F-DK Discovery kit Info.png.
STM32MP215x-DK Discovery kit front side STM32MP215F-DK shown here (picture is not contractual)
Details about the LEDs:
  • The LD1 LED turns yellow when the power cable is inserted into the CN10 connector.
  • The red LED (LD5) is used as a BOOTFAIL indicator and to indicate engineering boot mode.
  • Two general-purpose color LEDs (LD2 and LD3) are available as light indicators:
    • The blue LED (LD2) is used as the Linux® Heartbeat LED, which is blinking as long as Linux® is alive on the Cortex®-A.
    • The orange LED (LD3) is used as a STM32Cube example verdict LED.
  • The green indicator LED (LD4) is connected to the STM32MP215 MPU.
4. Boot switches[edit | edit source]
The STM32MP215x-DK Discovery kit can boot from different flash memory devices (microSD, eMMC) based on ROM code selection; using the microSD card is recommended.
TD flavor Boot 0 Boot 1 Boot 2 Boot 3 The boot-related switches (SW1 and SW2
in the board overview picture)
Storage device used for the Cortex-A35 boot Storage device used for the Cortex-M33 boot
For any TD flavor (A35-TD or M33-TD) More info green.png 0 0 0 0
Forced USB boot for flash memory programming
USB/UART boot
for flash programming
NA
1 1 0 0
Development mode
Development boot NA
A35-TD flavor More info green.png 1 0 0 0
Boot from microSD card
SD card NA
M33-TD flavor More info green.png 1 1 1 0
SD card SD card
When the switch is set to the "ON" position, the BOOTx value is "1"; otherwise it is "0".
5. GPIO mapping[edit | edit source]
5.1. GPIO expansion connector[edit | edit source]
The table below describes the pins of the GPIO expansion connector (CN12 in the board overview picture):
3V3 - 1 2 - 5V
GPIO2 / I3C1.SDA PA2 3 4 - 5V
GPIO3 / I3C1.SCL PG13 5 6 - GND
GPIO4 / MCO1 PF11 7 8 PF13 GPIO14 / USART6.TX
GND - 9 10 PH9 GPIO15 / USART6.RX
GPIO17 / USART6.RTS PC3 11 12 PA9 GPIO18 / SAI2.SCKB
GPIO27/ SDMMC3.D3 PD14 13 14 - GND
GPIO22 / SDMMC3.CK PB13 15 16 PH8 GPIO23 / SDMMC3.CMD
3V3 - 17 18 PB14 GPIO24/SDMMC3.D0
GPIO10 / SPI1.MOSI PI5 19 20 - GND
GPIO9 / SPI1.MISO PD1 21 22 PD13 GPIO25/SDMMC3.D1
GPIO11 / SPI1.SCK PD11 23 24 PD2 GPIO8 / SPI1.NSS
GND - 25 26 PC7 GPIO7
I3C2.SDA   PG0 27 28 PC12 I3C2.SCL
GPIO5 / TIM11.CH1 PH13 29 30 - GND
GPIO6 / TIM13.CH1 PC9 31 32 PC8 GPIO12 / TIM8.CH2
GPIO13 / TIM8.CH4 PC10 33 34 - GND
GPIO19 / SAI2.FSB PA6 35 36 PF15 GPIO16 / USART6.CTS
GPIO26 / SDMMC3.D2 PB12 37 38 PA5 GPIO20 / SAI2.SDB
GND - 39 40 PG1 GPIO21 / SAI2.SDA
5.2. User buttons and LEDs[edit | edit source]
The tables below describe the GPIO assignments for the user buttons and LEDs. Refer to the LEDs and buttons on STM32 MPU boards article and #Board overview chapter for more details.
GPIO for LEDs
LED color and label GPIO
Green LD4 PF10
Red LD5 PH4
Orange LD3 PH12
Blue LD2 PZ3
GPIO for user buttons
Button GPIO
USER1 PC4
USER2 PF7
