DMAMUX internal peripheral
  • briefly introduce the DMAMUX peripheral and its main features,
The DMAMUX peripheral is used to perform requestor line (or device controller) selection for each channel from DMA instances:
  • In STM32MP13x lines More info.png, there is a first DMAMUX instance to cover both DMA1 and DMA2, and second DMAMUX instance to cover DMA3.
  • In STM32MP15x lines More info.png, there is a single DMAMUX instance to cover both DMA1 and DMA2.
The DMAMUX peripheral is not used at boot time.
nonsecure
Core/DMA DMAMUX DMAMUX1 Assignment (single choice)
DMAMUX2 Assignment (single choice)
nonsecure
Cortex-M4
Core/DMA DMAMUX DMAMUX Shareable (multiple choices supported)
Below are listed the software frameworks and drivers managing the DMAMUX peripheral for the embedded software components listed in the above tables.
