Pages in category "How to customize software"
The following 35 pages are in this category, out of 35 total.
H
- How to add a customer application
 - How to add a new parallel or serial NAND flash memory device in Yocto
 - How to adjust USBPHYC settings using USB Eye Diagram
 - How to assign an internal peripheral to an execution context
 - How to avoid proxy issues
 - How to change the CPU frequency
 - How to change the GPU frequency
 - How to compile the device tree with the Distribution Package
 - How to configure a 256MB DDR mapping from STM32 MPU Distribution Package
 - How to configure system resources
 - How to configure U-Boot for your board
 - How to configure UEFI boot with the Distribution Package
 - How to configure uniprocessor mode
 - How to create a new open embedded layer
 - How to create your board device tree
 - How to create your own distribution
 - How to create your own image
 - How to customize the Linux kernel
 - How to develop an OP-TEE Trusted Application
 - How to disable one CPU
 - How to enable secure boot on STM32 MPU
 - How to install X-TouchGFX MPU Addon
 - How to optimize the boot time
 - How to perform Secure Boot from Distribution Package
 - How to protect the Cortex-M coprocessor firmware
 - How to setup the DDR configuration
 - How to tune RGMII GTX clock delay
 - How to use LTDC layers from CM33 and CA35 simultaneously
 - How to use the DCMIPP ISP
 - How to use the secure display feature
 - How to write a display panel or bridge driver
 - How to write a low resolution and slow interface display panel driver
