VENC internal peripheral
  • briefly introduce the VENC peripheral and its main features,
The VENC (Video ENCoder) peripheral is an hardware accelerator for video compressed content encoding such as H264 or VP8 bitstream and for still-image content encoding such as JPEG or WebP bitstream.
The VENC peripheral is not used at boot time.
The table below is applicable to any TD flavor (A35-TD or M33-TD) More info green.png.
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Visual VENC VENC OP-TEE
Below are listed the software frameworks and drivers managing the VENC peripheral for the embedded software components listed in the above tables.
See also additional information in the VENC device tree configuration article for Linux®.
