CRC internal peripheral
  • briefly introduce the CRC peripheral and its main features,
The CRC peripheral is used to verify data transmission or storage integrity.
The CRC peripheral is not used at boot time.
3.2.1. On STM32MP13x lines [edit | edit source]
nonsecure
Security CRC CRC
3.2.2. On STM32MP15x lines [edit | edit source]
nonsecure
Cortex-M4
Security CRC CRC1
CRC2
3.2.3. On STM32MP21x lines [edit | edit source]
The tables below are applicable to any TD flavor (A35-TD or M33-TD) .
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Security CRC CRC OP-TEE
3.2.4. On STM32MP23x lines [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
3.2.5. On STM32MP25x lines [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Below are listed the software frameworks and drivers managing the CRC peripheral for the embedded software components listed in the above tables.
