PCIe internal peripheral
  • briefly introduce the PCIe peripheral and its main features,
The PCIe internal peripheral is based on the Synopsys DesignWare® PCIe controller. It's a PCIe Gen2 controller, hence allowing to communicate by using the PCIe Gen1 or Gen2 protocol. It features a single lane with bidirectional transfer rate of 250MB/s or 500MB/s. The peripheral is a dual role controller, it can operate as a root complex (RC) or as an endpoint (EP). The peripheral is connected to the ComboPHY internal peripheral in PCIe mode, which can provide the 100Mhz reference clock.
The PCIe peripheral main features are the following:
  • Clock 100MHz: External (with SSC), Internal (wo SSC), common clock (bus), core or auxiliary internal clock
  • ASPM: L0s, L1, L1.1
  • AER
  • Max read request size 1K
  • MPS: 256 (Max paquet size) so, 128, 256.
  • Single Virtual channel
  • Single function
  • PTM: Precise Time Measurement
3.1.1. On STM32MP25x lines More info.png[edit | edit source]
3.1.1.1. For A35-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
High speed interface PCIE PCIE The PCIe and the USB3DR running at USB3 speed are mutually exclusive. Both require using the ComboPHY.
3.1.1.2. For M33-TD flavor More info green.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
High speed interface PCIE PCIE OP-TEE The PCIe and the USB3DR running at USB3 speed are mutually exclusive. Both require using the ComboPHY.
Below are listed the software frameworks and drivers managing the PCIe peripheral for the embedded software components listed in the above tables:
For the Linux kernel, please refer to the PCIe device tree configuration
