TZC internal peripheral
  • briefly introduce the TZC peripheral and its main features,
The TZC peripheral is used to filter read/write accesses to the DDR controller according to TrustZone access rights, and according to Non-Secure master Address ID (NSAID) on up to 9 programmable regions.
The TZC is configured at boot time to setup DDR accesses. It is initially configured thanks to TF-A FW Configuration. OP-TEE redefined the TZC regions based on device tree.
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Security TZC TZC
nonsecure
Security TZC TZC
nonsecure
Cortex-M4
Security TZC TZC
Below are listed the software frameworks and drivers managing the TZC peripheral for the embedded software components listed in the above tables.
See also additional information in the OP-TEE overview article.
The TZC is an Arm® peripheral: TZC-400 TrustZone Address Space Controller[1]
