HSEM internal peripheral
  • briefly introduce the HSEM peripheral and its main features,
The HSEM (hardware spinlock) peripheral is used to provide synchronization and mutual exclusion between heterogeneous processors.
  • 32 hardware semaphores are available on the platform.
  • semaphores could be accessed by the Arm® Cortex®-A7 core and the Arm® Cortex®-M4
3.1.1. On STM32MP15x lines More info.png[edit | edit source]
The hardware semaphore is used at boot time for GPIO access protection between the Arm® Cortex®-A7 and Cortex®-M4 cores. See Protecting GPIO and EXTI system resources by hardware semaphores for details.
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
Coprocessor HSEM HSEM
3.2.1. On STM32MP15x lines More info.png[edit | edit source]
It does not make sense to allocate HSEM to a single runtime execution context, that is why it is enabled by default for both cores in the STM32CubeMX.
The hardware semaphore is used at runtime for GPIO and EXTI access protection between the Arm® Cortex®-A7 and Cortex®-M4 cores. See Protecting GPIO and EXTI system resources by hardware semaphores for details.
nonsecure
Cortex-M4
Below are listed the software frameworks and drivers managing the HSEM peripheral for the embedded software components listed in the above tables.
The HSEM peripheral is shared between the Cortex-A and Cortex-M contexts, so a particular attention must be paid to have a complementary configuration on both contexts.
