Touchscreen hardware components
  • list the touchscreen hardware components that might be integrated in the different boards
  • link these components to the corresponding software framework(s)
  • point to the datasheet(s) of these components
  • explain, when necessary, how to configure these components
2. Software frameworks[edit | edit source]
OP-TEE Linux STM32Cube
Visual and Inputs Goodix GT9147 Inputs framework[1] Touchscreen input driver
Visual and Inputs FocalTech FT6236 Inputs framework[1] Touchscreen input driver
Visual and Inputs Ilitek ILI251x Inputs framework[1] Touchscreen input driver
3. Goodix GT9147[edit | edit source]
The Goodix GT9147 is a single-layer multi-touch capacitive touch controller driver.
For details and the datasheet please contact the GT9147 driver provider.
This touchscreen controller driver can be found on some STM32MP15 Evaluation boards.
3.1. Linux driver[edit | edit source]
Bindings: Documentation/devicetree/bindings/input/touchscreen/goodix.yaml
Sources: drivers/input/touchscreen/goodix.c
Devicetree example: arch/arm/boot/dts/st/stm32mp157d-ev1.dts
&dsi {
	#address-cells = <1>;
	#size-cells = <0>;
	status = "okay";
	ports {
		#size-cells = <0>;
		port@0 {
			reg = <0>;
			dsi_in: endpoint {
				remote-endpoint = <&ltdc_ep0_out>;
		port@1 {
			reg = <1>;
			dsi_out: endpoint {
				remote-endpoint = <&dsi_panel_in>;
	panel_dsi: panel-dsi@0 {
		compatible = "raydium,rm68200";
		reg = <0>;
		reset-gpios = <&gpiof 15 GPIO_ACTIVE_LOW>;
		backlight = <&panel_backlight>;
		power-supply = <&v3v3>;
		status = "okay";
		port {
			dsi_panel_in: endpoint {
				remote-endpoint = <&dsi_out>;
&i2c2 {
	stmfx: stmfx@42 {
		compatible = "st,stmfx-0300";
		reg = <0x42>;
		interrupts = <8 IRQ_TYPE_EDGE_RISING>;
		interrupt-parent = <&gpioi>;
		vdd-supply = <&v3v3>;
		stmfx_pinctrl: pinctrl {
			compatible = "st,stmfx-0300-pinctrl";
			gpio-controller;
			#gpio-cells = <2>;
			interrupt-controller;
			#interrupt-cells = <2>;
			gpio-ranges = <&stmfx_pinctrl 0 0 24>;
			goodix_pins: goodix {
				pins = "gpio14";
				bias-pull-down;
			joystick_pins: joystick-pins {
				pins = "gpio0", "gpio1", "gpio2", "gpio3", "gpio4";
				bias-pull-down;
	gt9147: goodix-ts@5d {
		compatible = "goodix,gt9147";
		reg = <0x5d>;
		panel = <&panel_dsi>;
		pinctrl-0 = <&goodix_pins>;
		pinctrl-names = "default";
		AVDD28-supply = <&v3v3>;
		VDDIO-supply = <&v3v3>;
		status = "okay";
		interrupts = <14 IRQ_TYPE_EDGE_RISING>;
		interrupt-parent = <&stmfx_pinctrl>;
4. FocalTech FT6236[edit | edit source]
The FocalTech FT6236 is a self-capacitive touch panel controller driver.
For details and the datasheet please contact the FT6236 driver provider.
This touchscreen controller driver can be found on some STM32MP15 Discovery kits.
4.1. Linux driver[edit | edit source]
Bindings: Documentation/devicetree/bindings/input/touchscreen/edt-ft5x06.yaml
Sources: drivers/input/touchscreen/edt-ft5x06.c
Devicetree example: arch/arm/boot/dts/st/stm32mp157f-dk2.dts
&dsi {
	status = "okay";
	ports {
		port@0 {
			reg = <0>;
			dsi_in: endpoint {
				remote-endpoint = <&ltdc_ep1_out>;
		port@1 {
			reg = <1>;
			dsi_out: endpoint {
				remote-endpoint = <&panel_in>;
	panel_otm8009a: panel-otm8009a@0 {
		compatible = "orisetech,otm8009a";
		reg = <0>;
		reset-gpios = <&gpioe 4 GPIO_ACTIVE_LOW>;
		status = "okay";
		port {
&i2c1 {
	touchscreen@2a {
		compatible = "focaltech,ft6236";
		reg = <0x2a>;
		interrupts = <2 2>;
		interrupt-parent = <&gpiof>;
		touchscreen-size-x = <480>;
		touchscreen-size-y = <800>;
		panel = <&panel_otm8009a>;
		vcc-supply = <&v3v3>;
		iovcc-supply = <&v3v3>;
		status = "okay";
	touchscreen@38 {
		reg = <0x38>;
		interrupts = <2 2>;
		status = "okay";
&ltdc {
	status = "okay";
	port {
		ltdc_ep1_out: endpoint@1 {
			reg = <1>;
			remote-endpoint = <&dsi_in>;
5. Ilitek ILI251x[edit | edit source]
The Ilitek ILI251x is a multi-touch capacitive touch controller driver.
For details and the datasheet please contact the ILI251x driver provider.
This touchscreen controller driver can be found on some STM32MP257F EV1 Evaluation boards.
5.1. Linux driver[edit | edit source]
Bindings: Documentation/devicetree/bindings/input/touchscreen/ilitek_ts_i2c.yaml
Sources: drivers/input/touchscreen/ilitek_ts_i2c.c
Devicetree example: arch/arm64/boot/dts/st/stm32mp257f-ev1.dts
	panel_dsi_backlight: panel-dsi-backlight {
		compatible = "gpio-backlight";
		gpios = <&gpioi 5 GPIO_ACTIVE_LOW>;
		default-on;
		default-brightness-level = <0>;
		status = "disabled";
	panel_lvds: panel-lvds {
		compatible = "edt,etml0700z9ndha", "panel-lvds";
		enable-gpios = <&gpiog 15 GPIO_ACTIVE_HIGH>;
		backlight = <&panel_lvds_backlight>;
		status = "okay";
		width-mm = <156>;
		height-mm = <92>;
		data-mapping = "vesa-24";
		panel-timing {
			clock-frequency = <54000000>;
			hactive = <1024>;
			vactive = <600>;
			hfront-porch = <150>;
			hback-porch = <150>;
			hsync-len = <21>;
			vfront-porch = <24>;
			vback-porch = <24>;
			vsync-len = <21>;
		port {
			lvds_panel_in: endpoint {
				remote-endpoint = <&lvds_out0>;
	panel_lvds_backlight: panel-lvds-backlight {
		gpios = <&gpioi 5 GPIO_ACTIVE_HIGH>;
		default-on;
		status = "okay";
&i2c2 {
	ili2511: ili2511@41 {
		compatible = "ilitek,ili251x";
		reg = <0x41>;
		interrupts = <13 IRQ_TYPE_EDGE_FALLING>;
		reset-gpios = <&gpiog 14 GPIO_ACTIVE_LOW>;
		status = "okay";
&ltdc {
	rotation-memory = <&ltdc_sec_rotation>;
	status = "okay";
	port {
		#size-cells = <0>;
		ltdc_ep0_out: endpoint@0 {
			reg = <0>;
			reg = <1>;
			remote-endpoint = <&lvds_in>;
&lvds {
	status = "okay";
	ports {
		#size-cells = <0>;
		port@0 {
			reg = <0>;
			lvds_in: endpoint {
		port@1 {
			reg = <1>;
			lvds_out0: endpoint {
				remote-endpoint = <&lvds_panel_in>;
6. To go further[edit | edit source]
Related articles:
  1. 1.0 1.1 1.2 Linux Input Subsystem kernel API and userspace API
