The purpose of this article is to explain how to configure the USB2PHY internal peripheral using the device tree mechanism, relying on the bindings documentation, that is the description of the required and optional device-tree properties.
It is used by:
- the USB2PHY Linux driver[1] which registers the relevant information in PHY framework.
- the USB2PHY U-Boot driver[2]
The peripheral can be assigned to different contexts or software components, depending on the final product needs. Refer to How to assign an internal peripheral to an execution context for guidelines on this configuration.
The device tree binding documents are stored in the Linux® kernel repository:
- STM32 USB2PHY device tree bindings: Documentation/devicetree/bindings/phy/st,stm32-usb2phy.yaml
The USB2PHY nodes, one for each instance, are declared in:
- stm32mp211.dtsi[3] on STM32MP21x lines
. - stm32mp231.dtsi[4] on STM32MP23x lines
. - stm32mp251.dtsi[5] on STM32MP25x lines
Below is the template for each node:
/* For STM32MP21 */ usb2_phyX: usb2-phyX { compatible = "st,stm32mp21-usb2phy"; ... /* usb2phy resources: registers, clocks, resets and supplies */ };
/* For STM32MP23 */ usb2_phyX: usb2-phyX { compatible = "st,stm32mp25-usb2phy"; ... /* usb2phy resources: registers, clocks, resets and supplies */ };
/* For STM32MP25 */ usb2_phyX: usb2-phyX { compatible = "st,stm32mp25-usb2phy"; ... /* usb2phy resources: registers, clocks, resets and supplies */ };
Follow the sequences described in the below chapters to configure and enable the USB2PHY on your board.
The usb2phyX root node must be filled in:
- Enable the USB2PHY instance by setting status = "okay".
- Configure the USB2PHY 3V3 regulator[6] by setting vdd33-supply = <&your_regulator>.
| The USB2PHY requires an external 3.3V power supply to be provided at the VDD33USB pin.
It may be necessary to adjust the PHY settings to compensate for parasitics, which can be due to the USB connector or receptacle, routing, and ESD protection components. An optional list of tuning parameters is available in the USB2PHY device tree bindings[7]. |
- Optionally configure the USB2PHY 1V8 regulator by setting vdda18-supply = <&your_regulator>.
- Optionally, the VBUS 5V regulator[6] can be added, under a connector subnode with vbus-supply = <&your_regulator> as specified in usb-connector.yaml[8] bindings.
3.3. DT configuration example[edit | edit source]
The example below shows how to enable and configure USB2PHY instances in the board file.
&usb2_phy1 {
vdd33-supply = <&scmi_vdd3v3_usb>;
status = "okay"; /* enable USB2PHY1 controller */
connector {
compatible = "usb-a-connector";
vbus-supply = <&vbus>;
&usb2phy2 {
status = "okay"; /* enable USB2PHY2 controller */
Static assignment of usb2phy(s) is done by the PHY user node[9]:
- ↑ drivers/phy/st/phy-stm32-usb2phy.c , STM32 USB2PHY Linux driver,
- ↑ drivers/phy/phy-stm32-usb2phy.c , STM32 USB2PHY U-Boot driver
- ↑ arch/arm64/boot/dts/st/stm32mp211.dtsi , STM32MP211 device tree file
- ↑ arch/arm64/boot/dts/st/stm32mp231.dtsi , STM32MP231 device tree file
- ↑ arch/arm64/boot/dts/st/stm32mp251.dtsi , STM32MP251 device tree file
- ↑ 6.0 6.1 Regulator overview
- ↑ Documentation/devicetree/bindings/phy/st,stm32-usb2phy.yaml , USB2PHY device tree bindings
- ↑ Documentation/devicetree/bindings/connector/usb-connector.yaml , Generic USB Connector Device Tree Bindings
- ↑ Documentation/devicetree/bindings/phy/phy-bindings.txt ,PHY generic bindings
