STM32MPU Developer Package
(Redirected from STM32MP1 Developer Package)
Info white.png Trusted domain applicability
This article is not applicable to M33-TD flavor More info green.png of STM32MP2 series
This article describes how to get and use the Developer Package of the STM32MPU Embedded Software for any development platform of the STM32MP1 series (STM32MP15 boards and STM32MP13 boards) and STM32MP2 series (STM32MP21 boards, STM32MP23 boards and STM32MP25 boards), in order to modify some of its pieces of software, or to add applications on top of it.
It lists some prerequisites in terms of knowledge and development environment, and gives the step-by-step approach to download and install the STM32MPU Embedded Software components for this Package.
1. Developer Package content[edit | edit source]
If you are not yet familiar with the STM32MPU Embedded Software distribution and its Packages, read the following articles:
If you are already familiar with the Developer Package for the STM32MPU Embedded Software distribution, the fast links to essential commands might interest you.
To sum up, this Developer Package provides:
  • for the OpenSTLinux distribution (development on Arm® Cortex®-A processor):
    • the software development kit (SDK), based on Yocto SDK, for cross-development on a host PC
    • the following pieces of software in source code:
      • Linux® kernel
      • gcnano-driver
      • U-Boot
      • Trusted Firmware-A (TF-A)
      • Open source Trusted Execution Environment (OP-TEE)
      • External device tree
  • for the Cortex®-M processor firmware development (only for STM32MP15x lines More info.png and STM32MP2 series with both A35-TD flavor More info green.png and M33-TD flavor More info green.png when supported):
    • the integrated development environment (IDE) (STM32CubeIDE)
    • the STM32CubeMPU Package including all pieces of software (BSP, HAL, middlewares, and applications) in source code
    • the Trusted Firmware-M (TF-M) in source code (for STM32MP2 series only)
Note that the application frameworks for the OpenSTLinux distribution are not available as source code in this Package.
Components of the Developer Package
TF-M is available only for STM32MP2 series
2. Developer Package step-by-step overview[edit | edit source]
The steps to get the STM32MPU Embedded Software Developer Package ready for your developments are:
Checking the prerequisites
Installing the Starter Package for your board and the debug symbol files
Installing the components to develop software running on Arm® Cortex®-A (OpenSTLinux distribution)
Installing the SDK (mandatory for any development on Arm® Cortex®-A)
Installing the OpenSTLinux BSP package (mandatory only if you plan to modify the Linux kernel, to add external out-of-tree Linux kernel modules, to modify U-Boot, TF-A and/or OP-TEE OS)
Installing the components to develop software running Arm Cortex-M (STM32CubeMPU Package)
Installing STM32CubeIDE (mandatory for any development on Arm® Cortex®-M)
Installing the STM32CubeMPU Package (mandatory only if you plan to modify the STM32Cube firmware)
3. Checking the prerequisites[edit | edit source]
3.1. Knowledge[edit | edit source]
The STM32MPU Developer Package aims at enriching a Linux-based software for the targeted product: basic knowledge about Linux are recommended to make the most of this Package.
3.2. Development setup[edit | edit source]
4. Installing the Starter Package[edit | edit source]
Before developing with the Developer Package, it is essential to start up your board thanks to its Starter Package. All articles relative to Starter Packages are found in Category:Starter Package: find the one that corresponds to your board, and follow the installation instructions (if not yet done), before going further.
In brief, it means that:
  • the flashed image comes from the same release of the STM32MPU Embedded Software distribution as the components that will be downloaded in this article
  • the debug symbol files from the flashed image are available in Starter Package image folder
Then, with the Developer Package, it is possible to modify or to upgrade the partitions independently one from the others.
For example, if you only want to modify the Linux kernel (part of bootfs partition), installing the SDK and the Linux kernel are enough; no need to install anything else.
With the debug symbol files, it is also possible to debug the Linux® kernel, U-Boot, OP-TEE, or TF-A with GDB. Especially, the Debug OpenSTLinux BSP components chapter explains how to load the debug symbol files in GDB.
5. Installing the components to develop software running on Arm Cortex-A (OpenSTLinux distribution)[edit | edit source]
5.1. Installing the SDK[edit | edit source]
Warning DB.png Important
It is highly recommended to use the SDK provided here and not stuck on the SDK provided during the previous release. Effectively, some major improvements have been made since the previous release
Optional step: it is mandatory only if you want to modify or add software running on Arm Cortex-A (for example Linux kernel, Linux user space applications...).
The SDK for OpenSTLinux distribution provides a stand-alone cross-development toolchain and libraries tailored to the contents of the specific image flashed in the board. If you want to know more about this SDK, read the SDK for OpenSTLinux distribution article.
For STM32MP1 series
The STM32MP1 SDK is delivered through two tarball file named :
  • en.SDK-x86_64-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz for x86_64 host architecture
  • en.SDK-aarch64-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz for arm64 host architecture
Download and install the STM32MP1 SDK. The software package is provided AS IS, and by downloading it, you agree to be bound to the terms of the software license agreement (SLA0048). The detailed content licenses can be found here.
STM32MP1 Developer Package SDK - STM32MP1-Ecosystem-v6.1.0 release
Download
  • Go on st.com to download
    • en.SDK-x86_64-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz file for x86_64 host architecture
    • en.SDK-aarch64-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz file for arm64 host architecture
Installation For x86_64 host architecture
  • Uncompress the tarball file to get the SDK installation script.
tar xvf en.SDK-x86_64-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz
  • If needed, change the permissions on the SDK installation script so that it is executable.
chmod +x stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/sdk/st-image-weston-openstlinux-weston-stm32mp1.rootfs-x86_64-toolchain-5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.sh
  • Run the SDK installation script.
    • Use the -d <SDK installation directory absolute path> option to specify the absolute path to the directory in which you want to install the SDK (<SDK installation directory>).
    • If you follow the proposition to organize the working directory, it means:
./stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/sdk/st-image-weston-openstlinux-weston-stm32mp1.rootfs-x86_64-toolchain-5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.sh -d <working directory absolute path>/Developer-Package/SDK
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) SDK installer version 5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11
You are about to install the SDK to "<working directory absolute path>/Developer-Package/SDK". Proceed [Y/n]?
Extracting
SDK.........................................................................................................................................................................................................................done
Setting it up...done
SDK has been successfully set up and is ready to be used.
Each time you wish to use the SDK in a new shell session, you need to source the environment setup script e.g.
$ . <working directory absolute path>/Developer-Package/SDK/environment-setup-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi
For arm64 host architecture
tar xvf en.SDK-aarch64-stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz
chmod +x stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/st-image-weston-openstlinux-weston-stm32mp1.rootfs-aarch64-toolchain-5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.sh
./stm32mp1-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/st-image-weston-openstlinux-weston-stm32mp1.rootfs-aarch64-toolchain-5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.sh -d <working directory absolute path>/Developer-Package/SDK
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) SDK installer version 4.2.1-openstlinux-6.1-yocto-mickledore-mp1-v23.06.21
Extracting SDK.........................................................................................................................................................................................................................done
Release note
Details about the content of the SDK are available in the associated STM32 MPU ecosystem release note.
Archive box.png If you are interested in older releases, please have a look into the section Archives.
  • The SDK is in the <SDK installation directory>:
<SDK installation directory>                                      SDK for OpenSTLinux distribution: details in Standard SDK directory structure article
├── environment-setup                                             Environment setup script for Developer Package
├── environment-setup-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi  Environment setup script for Developer Package
├── site-config-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi
├── sysroots
│   ├── cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi                Target sysroot (libraries, headers, and symbols)
│   └── x86_64-ostl_sdk-linux                                     Native sysroot (libraries, headers, and symbols)
└── version-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi
├── sysroots
│   └── aarch64-ostl_sdk-linux                                    Native sysroot (libraries, headers, and symbols)
For STM32MP2 series
The STM32MP2 SDK is delivered through two tarball file named :
  • en.SDK-x86_64-stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz for x86_64 host architecture
  • en.SDK-aarch64-stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz for arm64 host architecture
Download and install the STM32MP2 SDK. The software package is provided AS IS, and by downloading it, you agree to be bound to the terms of the software license agreement (SLA0048). The detailed content licenses can be found here.
STM32MP2 Developer Package SDK - STM32MP2-Ecosystem-v6.1.0 release
Download
    • en.SDK-x86_64-stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz file for x86_64 host architecture
    • en.SDK-aarch64-stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz file for arm64 host architecture
tar xvf en.SDK-x86_64-stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz
chmod +x stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/sdk/st-image-weston-openstlinux-weston-stm32mp2.rootfs-x86_64-toolchain-5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.sh
./stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/sdk/st-image-weston-openstlinux-weston-stm32mp2.rootfs-x86_64-toolchain-5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.sh -d <working directory absolute path>/Developer-Package/SDK
Extracting
$ . <working directory absolute path>/Developer-Package/SDK/environment-setup-cortexa35-ostl-linux
tar xvf en.SDK-aarch64-stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz
chmod +x stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/st-image-weston-openstlinux-weston-stm32mp2.rootfs-aarch64-toolchain-5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.sh
./stm32mp2-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/st-image-weston-openstlinux-weston-stm32mp2.rootfs-aarch64-toolchain-5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.sh -d <working directory absolute path>/Developer-Package/SDK
Extracting
Release note
Archive box.png If you are interested in older releases, have a look into the section Archives.
├── environment-setup-cortexa35-ostl-linux	Environment setup script for Developer Package
├── site-config-cortexa35-ostl-linux
├── sysroots
│   ├── cortexa35-ostl-linux			Target sysroot (libraries, headers, and symbols)
└── version-cortexa35-ostl-linux
├── sysroots
Now that the SDK is installed, do not move or rename the <SDK installation directory>.
5.1.1. Starting up the SDK[edit | edit source]
The SDK environment setup script must be run once in each new working terminal in which you cross-compile:
For STM32MP1 series
source <SDK installation directory>/environment-setup-cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi
  • Check the target architecture
echo $ARCH
arm
  • Check the toolchain binary prefix for the target tools
echo $CROSS_COMPILE
arm-ostl-linux-gnueabi-
  • Check the C compiler version
$CC --version
arm-ostl-linux-gnueabi-gcc (GCC) <GCC version>
  • Check that the SDK version is the expected one
echo $OECORE_SDK_VERSION
<expected SDK version>
For STM32MP2 series
source <SDK installation directory>/environment-setup-cortexa35-ostl-linux
echo $ARCH
arm64
echo $CROSS_COMPILE
aarch64-ostl-linux-
$CC --version
aarch64-ostl-linux-gcc (GCC) <GCC version>
5.2. Installing the OpenSTLinux BSP packages[edit | edit source]
Optional step: it is mandatory only if you want to modify the BSP (Linux kernel, TF-A, U-Boot, OP-TEE OS), or to add external out-of-tree Linux kernel modules.
OpenSTLinux BSP packages installation instructions:
  • The OpenSTLinux BSP package is delivered through a tarball file named en.SOURCES-stm32mp-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz applicable for all STM32 microprocessor series.
  • Download and install the STM32MPU OpenSTLinux BSP package.
STM32MPU Developer Package - STM32MPU ecosystem v6.1.0 release
Download
Installation
cd <working directory path>/Developer-Package
tar xvf en.SOURCES-stm32mp-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11.tar.gz
Release note
Details about the content of the OpenSTLinux BSP package are available in the associated STM32 MPU OpenSTLinux release note.
Archive box.png For information on older releases, go to Archives.
  • In sub-directories from <Developer Package installation directory>/stm32mp-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/sources/ostl-linux, several tarball archive of the OpenSTLinux BSP components can be found.
  • The external device tree directory is named external-dt-<ext-dt version>:
external-dt-6.0-r2	external device tree installation directory
├── external-dt-6.0-r2.tar.xz		Tarball file of the external device tree source code
├── README.HOW_TO.txt.stm32mp1		Helper file for external device tree management: reference for stm32mp1 external device tree usage
├── README.HOW_TO.txt.stm32mp2		Helper file for external device tree management: reference for stm32mp2 external device tree usage
└── README.HOW_TO.txt.stm32mp2-m33td	Helper file for external device tree management: reference for stm32mp2 M33TD flavor external device tree usage
  • The Linux kernel installation directory is named linux-stm32mp-<kernel version>:
linux-stm32mp-6.6.78-stm32mp-r2-r0	Linux kernel installation directory
├── [*].patch				ST patches to apply during the Linux kernel preparation (see next chapter)
├── fragment-[*].config			ST configuration fragments to apply during the Linux kernel configuration (see next chapter)
├── optional-fragment-[*].config	Optional ST configuration fragments to apply during the Linux kernel configuration depending on your needs (SMP or not, signature or not, ...)
├── linux-6.6.78.tar.xz                 Tarball file of the Linux kernel source code
├── README.HOW_TO.txt.stm32mp1		Helper file for Linux kernel management: reference for stm32mp1 Linux kernel build
├── README.HOW_TO.txt.stm32mp2		Helper file for Linux kernel management: reference for stm32mp2 Linux kernel build
├── README.HOW_TO.txt.stm32mp2-m33td	Helper file for Linux kernel management: reference for stm32mp2 M33TD flavor Linux kernel build
└── series                              List of all ST patches to apply
  • The gcnano driver installation directory is named gcnano-driver-stm32mp-<gcnano driver version>:
gcnano-driver-stm32mp-6.4.21-r1-r0	gcnano-driver installation directory
├── gcnano-driver-stm32mp-6.4.21-r1-r0.tar.xz	Tarball file of the gcnano-driver source code
├── README.HOW_TO.txt.stm32mp1			Helper file for gcnano-driver management: reference for stm32mp1 gcnano-driver build
├── README.HOW_TO.txt.stm32mp2			Helper file for gcnano-driver management: reference for stm32mp2 gcnano-driver build
└── README.HOW_TO.txt.stm32mp2-m33td		Helper file for gcnano-driver management: reference for stm32mp2 M33TD flavor gcnano-driver build
  • The ddr phy installation directory is named stm32mp-ddr-phy-<ddr phy version>:
stm32mp-ddr-phy-A2022.11-r0	ddr-phy installation directory
├── README.HOW_TO.txt.stm32mp2		Helper file for ddr phy management: reference for stm32mp2 ddr-phy use
├── README.HOW_TO.txt.stm32mp2-m33td	Helper file for ddr phy management: reference for stm32mp2 M33TD flavor ddr-phy use
└── stm32mp-ddr-phy-A2022.11-r0.tar.xz	Tarball file of the stm32mp-ddr-phy binaries
  • The OP-TEE installation directory is named optee-os-stm32mp-<OP-TEE version>:
optee-os-stm32mp-4.0.0-stm32mp-r2-r0	OP-TEE installation directory
├── [*].patch						ST patches to apply during the OP-TEE preparation (see next chapter)
├── fiptool-stm32mp.stm32mp1				Tool for stm32mp1 fip generation
├── fiptool-stm32mp.stm32mp2				Tool for stm32mp2 fip generation
├── fiptool-stm32mp.stm32mp2-m33td			Tool for stm32mp2 M33TD flavor fip generation
├── fonts.tar.gz					fonts for OPTEE-OS
├── Makefile.sdk.stm32mp1				Makefile for the stm32mp1 OP-TEE compilation
├── Makefile.sdk.stm32mp2				Makefile for the stm32mp2 OP-TEE compilation
├── Makefile.sdk.stm32mp2-m33td				Makefile for the stm32mp2 M33TD flavor OP-TEE compilation
├── optee-os-stm32mp-4.0.0-stm32mp-r2-r0.tar.xz		Tarball file of the OP-TEE source code
├── README.HOW_TO.txt.stm32mp1				Helper file for OP-TEE management: reference for stm32mp1 OP-TEE build
├── README.HOW_TO.txt.stm32mp2				Helper file for OP-TEE management: reference for stm32mp2 OP-TEE build
├── README.HOW_TO.txt.stm32mp2-m33td			Helper file for OP-TEE management: reference for stm32mp2 M33TD flavor OP-TEE build
  • The U-Boot installation directory is named u-boot-stm32mp-<U-Boot version>:
u-boot-stm32mp-v2023.10-stm32mp-r2-r0	U-Boot installation directory
├── [*].patch						ST patches to apply during the U-Boot preparation (see next chapter)
├── fragment-[*].fb_cfg					ST configuration fragments to apply during the U-Boot configuration to support fastboot
├── Makefile.sdk.stm32mp1				Makefile for the stm32mp1 U-Boot compilation
├── Makefile.sdk.stm32mp2				Makefile for the stm32mp2 U-Boot compilation
├── Makefile.sdk.stm32mp2-m33td				Makefile for the stm32mp2 M33TD flavor U-Boot compilation
├── README.HOW_TO.txt.stm32mp1				Helper file for U-Boot management: reference for stm32mp1 U-Boot build
├── README.HOW_TO.txt.stm32mp2				Helper file for U-Boot management: reference for stm32mp2 U-Boot build
├── README.HOW_TO.txt.stm32mp2-m33td			Helper file for U-Boot management: reference for stm32mp2 M33TD flavor U-Boot build
├── series						List of all ST patches to apply
└── u-boot-stm32mp-v2023.10-stm32mp-r2-r0.tar.xz	Tarball file of the U-Boot source code
  • The TF-A installation directory is named tf-a-stm32mp-<TF-A version>:
tf-a-stm32mp-v2.10.13-stm32mp-r2-r0	TF-A installation directory
├── [*].patch					ST patches to apply during the TF-A preparation (see next chapter)
├── Makefile.sdk.stm32mp1			Makefile for the stm32mp1 TF-A compilation
├── Makefile.sdk.stm32mp2			Makefile for the stm32mp2 TF-A compilation
├── Makefile.sdk.stm32mp2-m33td			Makefile for the stm32mp2 M33TD flavor TF-A compilation
├── README.HOW_TO.txt.stm32mp1			Helper file for TF-A management: reference for stm32mp1 TF-A build
├── README.HOW_TO.txt.stm32mp2			Helper file for TF-A management: reference for stm32mp2 TF-A build
├── README.HOW_TO.txt.stm32mp2-m33td		Helper file for TF-A management: reference for stm32mp2 M33TD flavor TF-A build
└── tf-a-stm32mp-v2.10.13-stm32mp-r2-r0.tar.xz	Tarball file of the TF-A source code
  • The TF-M-TESTS installation directory is named tf-m-tests-<TF-M-TESTS version>:
tf-m-tests-stm32mp-v2.1.0-stm32mp-r1-r0	TF-M-TESTS installation directory
├── [*].patch						ST patches to apply during the TF-M-TESTS preparation (see next chapter)
├── README.HOW_TO.txt.stm32mp2-m33td			Helper file for TF-M-TESTS management: reference for stm32mp2 M33TD flavor TF-M-TESTS build
└── tf-m-tests-stm32mp-v2.1.0-stm32mp-r1-r0.tar.xz	Tarball file of the TF-M-TESTS source code
  • The TF-M installation directory is named tf-m-<TF-M version>:
tf-m-stm32mp-v2.1.0-stm32mp-r1-r0	TF-M installation directory
├── Makefile.sdk.stm32mp2-m33td			Makefile for the stm32mp2 M33TD flavor TF-M compilation
├── README.HOW_TO.txt.stm32mp2-m33td		Helper file for TF-M management: reference for stm32mp2 M33TD flavor TF-M build
├── tf-m-stm32mp-v2.1.0-stm32mp-r1-r0-diff.gz	ST patches applied on top of TF-M community source code reference
└── tf-m-stm32mp-v2.1.0-stm32mp-r1-r0.tar.xz	Tarball file of the TF-M source code
  • The M33TD PROJECTS installation directory is named m33tdprojectst-starter-stm32mp2-<M33TD PROJECTS version>:
m33tdprojects-starter-stm32mp2-1.2.0-r0	M33TD PROJECTS installation directory
├── m33tdprojects-starter-stm32mp2-1.2.0-r0.tar.xz	Tarball file of the M33TD PROJECTS source code
└── README.HOW_TO.txt.stm32mp2-m33td			Helper file for M33TD PROJECTS management: reference for stm32mp2 M33TD flavor M33TD PROJECTS build
  • The sdk infos installation directory is named sdk-infos-<sdk infos version>:
sdk-infos-1.0-r0	sdk infos installation directory
├── generated_build_script-stm32mpx.sh	Tool for source code compilation under SDK
├── README.HOW_TO.txt.stm32mp1		Helper file for sdk infos management: reference for stm32mp1 sdk infos use
├── README.HOW_TO.txt.stm32mp2		Helper file for sdk infos management: reference for stm32mp2 sdk infos use
└── README.HOW_TO.txt.stm32mp2-m33td	Helper file for sdk infos management: reference for stm32mp2 M33TD flavor sdk infos use
5.2.1. Building and deploying the external device tree for the first time[edit | edit source]
Prerequisite: the SDK is installed.
Open the <external device tree installation directory>/README.HOW_TO.txt.<board flavor>[1] helper file, and execute its instructions to:
setup a software configuration management (SCM) system (git) for the external device tree (optional but recommended)
export the path of external device tree directory into the variable EXTDT_DIR
The external device tree is now set-up and can be used during compilation.
5.2.2. Building and deploying the ddr firmware for the first time (only on STM32MP2 series)[edit | edit source]
Open the <ddr firmware installation directory>/README.HOW_TO.txt.<board flavor>[1] helper file, and execute its instructions to:
export the path of ddr firmware tree directory into the variable FWDDR_DIR
The ddr firmware path is now set-up and can be used during compilation.
5.2.3. Building and deploying the Linux kernel for the first time[edit | edit source]
Prerequisite: the SDK is installed. It is mandatory to execute once the steps specified below before modifying the Linux kernel, or adding external out-of-tree Linux kernel modules.
The partitions related to the Linux kernel are:
  • the bootfs partition that contains the Linux kernel U-Boot image (uImage) and device tree
  • the rootfs partition that contains the Linux kernel modules
The Linux kernel might be cross-compiled, either in the source code directory, or in a dedicated directory different from the source code directory.
This last method is recommended as it clearly separates the files generated by the cross-compilation from the source code files.
The SDK must be started
Open the <Linux kernel installation directory>/README.HOW_TO.txt.<board flavor>[1] helper file, and execute its instructions to:
setup a software configuration management (SCM) system (git) for the Linux kernel (optional but recommended)
prepare the Linux kernel (applying the ST patches)
configure the Linux kernel (applying the ST fragments)
cross-compile the Linux kernel
deploy the Linux kernel (that is, update the software on board)
The Linux kernel is now installed: let's modify the Linux kernel.
5.2.4. Building and deploying the gcnano-driver for the first time (only on STM32MP15x lines More info.png, STM32MP23x lines More info.png and STM32MP25x lines More info.png)[edit | edit source]
Prerequisite:
It is mandatory to execute once the steps specified below before modifying gcnano-driver.
A kernel module depends on the Linux kernel version. If kernel module is not built with the correct Linux kernel, the kernel could refuse the module to be loaded.
Open the <gcnano-driver installation directory>/README.HOW_TO.txt.<board flavor>[1] helper file, and execute its instructions to:
setup a software configuration management (SCM) system (git) for the gcnano-driver (optional but recommended)
cross-compile the gcnano-driver
deploy the gcnano-driver (that is, update the software on board)
The gcnano-driver is now installed.
5.2.5. Building and deploying the U-Boot for the first time[edit | edit source]
Prerequisite: the SDK is installed. It is mandatory to execute once the steps specified below before modifying the U-Boot.
As explained in the boot chain overview, the trusted boot chain is the default solution delivered by STMicroelectronics.
Within this scope, the partition related to the U-Boot is the ssbl one that contains the U-Boot and its device tree blob.
Open the <U-Boot installation directory>/README.HOW_TO.txt.<board flavor>[1] helper file, and execute its instructions to:
setup a software configuration management (SCM) system (git) for the U-Boot (optional but recommended)
prepare the U-Boot (applying the ST patches)
cross-compile the U-Boot
deploy the U-Boot (that is, update the software on board)
The U-Boot is now installed: let's modify the U-Boot.
5.2.6. Building and deploying the TF-A for the first time[edit | edit source]
Prerequisite: the SDK is installed. It is mandatory to execute once the steps specified below before modifying the TF-A.
Within this scope, the partition related to the TF-A is the fsbl one.
Open the <TF-A installation directory>/README.HOW_TO.txt.<board flavor>[1] helper file, and execute its instructions to:
setup a software configuration management (SCM) system (git) for the TF-A (optional but recommended)
prepare the TF-A (applying the ST patches)
cross-compile the TF-A
deploy the TF-A (that is, update the software on board)
The TF-A is now installed: let's modify the TF-A.
5.2.7. Building and deploying the OP-TEE for the first time[edit | edit source]
Prerequisite: the SDK is installed. It is mandatory to execute once the steps specified below before modifying the OP-TEE.
As explained in the boot chain overview, the trusted boot chain is the default solution delivered by STMicroelectronics. Within this scope, the partition related to the OP-TEE is the fsbl one.
Open the <OP-TEE installation directory>/README.HOW_TO.txt.<board flavor>[1] helper file, and execute its instructions to:
setup a software configuration management (SCM) system (git) for the OP-TEE (optional but recommended)
prepare the OP-TEE (applying the ST patches)
cross-compile the OP-TEE
deploy the OP-TEE (that is, update the software on board)
The OP-TEE is now installed: let's modify the OP-TEE.
6. Installing the components to develop software running on Arm Cortex-M (STM32CubeMPU Package) ( only on STM32MP15x lines More info.png and STM32MP2 series)[edit | edit source]
6.1. Installing STM32CubeIDE[edit | edit source]
Optional step: it is needed if you want to modify or add software running on Arm Cortex-M.
The table below explains how to download and install STM32CubeIDE which addresses STM32 MCU, and also provides support for Cortex-M inside STM32 MPU.
Download
Version 1.19.0
  • Download the preferred all-in-one Linux installer from st.com
    • RPM Linux Installer - STM32CubeIDE-RPM
    • Debian Linux Installer - STM32CubeIDE-DEB
Version 1.19.0
  • Download the all-in-one Windows installer from st.com
Installation guide
  • Refer to STM32CubeIDE installation guide (UM2563) available on st.com.
User manual
  • When the installation is completed, see additional information about STM32CubeIDE in st.com:
Detailed release note
  • Details about the content of this tool version are available in the STM32CubeIDE release v1.19.0 release note from st.com
Errata
  • STM32CubeIDE errata (This page is available in the stm32mcu wiki, be aware that, visiting this page, you will leave the stm32mpu wiki)
6.2. Installing the STM32CubeMPU Package[edit | edit source]
Optional step: it is mandatory only if you want to modify the STM32CubeMPU Package.
For STM32MP1 series:
  • The STM32CubeMP1 Package is delivered through an archive file named en.STM32Cube_FW_MP1_V1.7.0.zip.
  • Download and install the STM32CubeMP1 Package
The software package is provided AS IS, and by downloading it, you agree to be bound to the terms of the software license agreement (SLA0048). The detailed content licenses can be found here..
STM32MP1 Developer Package STM32CubeMP1 Package - v6.1.0 release
Download
  • Go on st.com to download the en.STM32Cube_FW_MP1_V1.7.0.zip file.
Installation
  • Download the archive file in this directory
  • Uncompress the archive file to get the STM32CubeMP1 Package:
unzip en.STM32Cube_FW_MP1_V1.7.0.zip
Release note
Details about the content of the STM32CubeMP1 Package are available in the STM32Cube_FW_MP1_V1.7.0/Release_Notes.html file.
  • The STM32CubeMP1 Package installation directory is in the <Developer Package installation directory> directory, and is named STM32Cube_FW_MP1_V1.7.0:
STM32Cube_FW_MP1_V1.7.0			STM32CubeMP1 Package: details in STM32CubeMP15 Package content article
├── Drivers
│   ├── BSP				BSP drivers for the supported STM32MP1 boards
│   ├── CMSIS
│   └── STM32MP1xx_HAL_Driver		HAL drivers for the supported STM32MP1 devices
├── _htmresc
├── License.md
├── Middlewares
├── package.xml
├── Projects
│   ├── STM32CubeProjectsList.html	List of examples and applications for STM32CubeMP1 Package
│   ├── STM32MP157C-DK2			Set of examples and applications → STM32MP15 Discovery kits
│   └── STM32MP157C-EV1			Set of examples and applications → STM32MP15 Evaluation boards
├── Readme.md
├── Release_Notes.html			Release note for STM32CubeMP1 Package
└── Utilities
For STM32MP2 series:
  • The STM32CubeMP2 Package is delivered through an archive file named en.STM32Cube_FW_MP2_V1.2.0.zip.
  • Download and install the STM32CubeMP2 Package
STM32MP2 Developer Package STM32CubeMP2 Package - v6.1.0 release
Download
  • Go on st.com to download the en.STM32Cube_FW_MP2_V1.2.0.zip file.
Installation
  • Uncompress the archive file to get the STM32CubeMP2 Package:
unzip en.STM32Cube_FW_MP2_V1.2.0.zip
Release note
Details about the content of the STM32CubeMP2Package are available in the STM32CubeMP2/Release_Notes.html file.
  • The STM32CubeMP2 Package installation directory is in the <Developer Package installation directory> directory, and is named STM32Cube_FW_MP2_V1.2.0:
STM32Cube_FW_MP2_V1.2.0			STM32CubeMP2 Package: details in STM32CubeMP2 Package content article
├── _htmresc
├── Drivers
│   ├── BSP				BSP drivers for the supported STM32MP2 boards
│   ├── CMSIS
│   └── STM32MP2xx_HAL_Driver		HAL drivers for the supported STM32MP2 devices
├── Middlewares
├── Projects
│   ├── _htmresc
│   ├── STM32MP215F-DK			Set of examples and applications → STM32MP21 Discovery boards
│   ├── STM32MP235F-DK			Set of examples and applications → STM32MP23 Discovery boards
│   ├── STM32MP257F-DK			Set of examples and applications → STM32MP25 Discovery boards
│   ├── STM32MP257F-EV1			Set of examples and applications → STM32MP25 Evaluation boards
│   ├── Release_Notes.html
│   └── STM32CubeProjectsList.html	List of examples and applications for STM32CubeMP2 Package
├── Utilities
├── CODE_OF_CONDUCT.md
├── CONTRIBUTING.md
├── License.md
├── package.xml
├── Package_license.html
├── Package_license.md
├── README.md
├── Release_Notes.html			Release note for STM32CubeMP2 Package
├── sbom_cdx.json
└── SECURITY.md
The STM32CubeMPU Package is now installed: let's develop software running on Arm Cortex-M.
7. Developing software running on Arm Cortex-A[edit | edit source]
7.1. Modifying the Linux kernel[edit | edit source]
Prerequisites:
The <Linux kernel installation directory>/README.HOW_TO.txt helper file gives the commands to:
You can refer to the following simple examples:
7.2. Adding Linux user space applications[edit | edit source]
Prerequisites:
Once a suitable cross-toolchain (OpenSTLinux SDK) is installed, it is easy to develop a project outside of the OpenEmbedded build system.
There are different ways to use the SDK toolchain directly, among which Makefile and Autotools.
Whatever the method, it relies on:
  • the sysroot that is associated with the cross-toolchain, and that contains the header files and libraries needed for generating binaries (see target sysroot)
  • the environment variables created by the SDK environment setup script (see SDK startup)
You can refer to the following simple example:
7.3. Modifying the U-Boot[edit | edit source]
Prerequisites:
The <U-Boot installation directory>/README.HOW_TO.txt helper file gives the commands to:
7.4. Modifying the TF-A[edit | edit source]
Prerequisites:
The <TF-A installation directory>/README.HOW_TO.txt helper file gives the commands to:
7.5. Modifying the OP-TEE[edit | edit source]
Prerequisites:
The <OP-TEE installation directory>/README.HOW_TO.txt helper file gives the commands to:
8. Developing software running on Arm Cortex-M[edit | edit source]
This chapters are valid only for STM32MP15x lines More info.png and STM32MP2 series.
Refer to FwST-M_Packages articles to create a STM32CubeMPU project from scratch or open/modify an existing one from STM32CubeMPU package.
9. Fast links to essential commands[edit | edit source]
If you are already familiar with the Developer Package for the STM32MPU Embedded Software distribution, fast links to the essential commands are listed below.
With the links below, you will be redirected to other article; use the back button of your browser to come back to these fast links
Link to the command
Starter Packages
Essential commands of the STM32MP25 Evaluation board Starter Package
Essential commands of the STM32MP25 Discovery kit Starter Package
Essential commands of the STM32MP21 Discovery kit Starter Package
Essential commands of the STM32MP15 Evaluation board Starter Package
Essential commands of the STM32MP15 Discovery kit Starter Package
Essential commands of the STM32MP13 Discovery kit Starter Package
SDK
Download and install the latest SDK for STM32MP1 series
Download and install the latest SDK for STM32MP2 series
Start the SDK
Linux kernel
Download and install the latest Linux kernel
gcnano-driver
Download and install the latest gcnano-driver
U-Boot
Download and install the latest U-Boot
TF-A
Download and install the latest TF-A
OP-TEE
Download and install the latest OP-TEE
Linux user space
Simple user space application
STM32CubeMPU Package only for STM32MP15x lines More info.png and STM32MP2 series
Download and install the latest STM32CubeMP1 Package
Create or modify a STM32CubeMP1 project
Download and install the latest STM32CubeMP2 Package
Create or modify a STM32CubeMP2 project
10. How to go further?[edit | edit source]
Now that your developments are ready, you might want to switch to the STM32MPU Distribution Package, in order to create your own distribution and to generate your own SDK and image.
11. References[edit | edit source]
  1. 1.0 1.1 1.2 1.3 1.4 1.5 1.6 The helper file name might be "README.HOW_TO.txt.stm32mp1" for the STM32MP1 series, "README.HOW_TO.txt.stm32mp2" for the A35-TD flavor More info green.png of the STM32MP2 series, or "README.HOW_TO.txt.stm32mp2-m33td" for the M33-TD flavor More info green.png of the STM32MP2 series
