OCTOSPIM internal peripheral
  • briefly introduce the OCTOSPI I/O manager peripheral and its main features,
The OCTOSPI I/O manager peripheral is a low-level interface that enables an efficient OCTOSPI pin assignment with a full I/O matrix (before alternate function map), and multiplex of single/dual/quad/octal SPI interfaces over the same bus.
STM32MP2 internal peripherals assignment table template
| rowspan="1" | Mass storage | rowspan="1" | OCTOSPIM | OCTOSPIM | | | | TF-A BL2 relies on OCTOSPIM configuration applied by ROM code |-
| rowspan="1" | Mass storage | rowspan="1" | OCTOSPIM | OCTOSPIM | OP-TEE | | | | | |-
Below are listed the software frameworks and drivers managing the OCTOSPI I/O manager peripheral for the embedded software components listed in the above tables.
For Linux kernel configuration, refer to OCTOSPIM device tree configuration.
