STM32MP2 VREFBUF internal peripheral
(Redirected from STM32MP25 VREFBUF internal peripheral)
  • briefly introduce the VREFBUF peripheral and its main features,
The VREFBUF is supplied via the VDDA pin. When enabled, it can provide a reference voltage in the range of: 1,21V or 1,5V. The VREFBUF can be used to provide an analog voltage reference for:
3.1.1.1. For A35-TD flavor [edit | edit source]
Domain Peripheral Boot time allocation Comment
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Analog VREFBUF VREFBUF OP-TEE offers SCMI regulator service to manage VREFBUF
3.1.1.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Analog VREFBUF VREFBUF TF-M offers SCMI regulator service to manage VREFBUF
Information
As soon as VREFBUF client peripherals (ADC1 or ADC2 or ADC3) are assigned to different execution contexts, the VREFBUF should be assigned to main processor secure context with RIFSC.
OpenSTlinux offers only VREFBUF support by secure OS on main processor through SCMI even if all ADC are assigned to a unique execution context:
  • for A35-TD flavor , by OP-TEE secure OS
  • for M33-TD flavor , by TF-M secure OS.
3.2.1. On STM32MP21x lines  and STM32MP23x lines [edit | edit source]
3.2.1.1. For A35-TD flavor [edit | edit source]
The present chapter describes STMicroelectronics recommendations or choice of implementation. Additional possibilities might be described in STM32MP21 reference manuals and in STM32MP23 reference manuals.
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Power & Thermal VREFBUF VREFBUF OP-TEE OP-TEE offers SCMI regulator service to manage VREFBUF
3.2.1.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
3.2.2. On STM32MP25x lines [edit | edit source]
3.2.2.1. For A35-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
3.2.2.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
Analog VREFBUF VREFBUF T-FM offers SCMI regulator service to manage VREFBUF
Below are listed the software frameworks and drivers managing the VREFBUF peripheral for the embedded software components listed in the above tables.
5.1. DT configuration example for A35-TD flavor [edit | edit source]
 &rifsc {
	st,protreg = <
 		RIFPROT(STM32MP25_RIFSC_VREFBUF_ID, RIF_UNUSED, RIF_UNLOCK, RIF_SEC, RIF_PRIV, RIF_CID1, RIF_SEM_DIS, RIF_CFEN)
  • Export the VREF regulator to Linux with SCMI (VOLTD_SCMI_VREFBUF)
For STM32MP25, with VOLTD_SCMI_VREFBUF value defined in core/include/dt-bindings/regulator/st,stm32mp25-regulator.h
#define VOLTD_SCMI_VREFBUF		9
In you board device tree, you can export the regualtor with
 &scmi_regulator {
	regulator@9 {
		reg = <VOLTD_SCMI_VREFBUF>;
		voltd-supply = <&vrefbuf>;
  • In Linux device tree
    • Define the SCMI regulator:
For STM32MP25, with VOLTD_SCMI_VREFBUF value defined in include/dt-bindings/regulator/st,stm32mp25-regulator.h
AddIn in the board device tree this regulator in OP-TEE SCMI server configuration with
 &scmi_regu {
 	scmi_vrefbuf: regulator@9 {
 		regulator-name = "vrefbuf";
 		regulator-min-microvolt = <1500000>;
 		regulator-max-microvolt = <1500000>;
  • Use this regulator as vref supply in the ADC node,
    for example:
 &adc_12 {
 	vref-supply = <&scmi_vrefbuf>;
 	status = "okay";
5.2. DT configuration example for M33-TD flavor [edit | edit source]
not supported, no VREFBUF driver present in TF-M
