STM32MP2 ADC internal peripheral
(Redirected from STM32MP25 ADC internal peripheral)
  • briefly introduce the ADC peripheral and its main features,
The ADC peripheral is a successive approximation analog-to-digital converter.
On STM32MP2 series, there are up to three physical ADCs distributed between two ADC blocks:
  • Each ADC has up to 20 multiplexed channels.
SoC ADCs External channels Internal channels
STM32MP21x lines  ADC1 18 2
ADC2 14 5
STM32MP23x lines  ADC1 18 2
ADC2 14 6
ADC3 14 6
STM32MP25x lines  ADC1 18 2
ADC2 14 6
ADC3 14 6
Information
ADC1 and ADC2 are tightly coupled on STM32MP23x lines  and STM32MP25x lines  but ADC3 is controlled independently.
  • Configurable resolution: 12, 10, 8, 6 bits.
  • The conversions can be performed in single, continuous, scan, or discontinuous mode.
  • The result can be read in a left-aligned or right-aligned 32-bit data register by using CPU or DMA[1].
  • The analog watchdog feature allows the application to detect if the input voltage goes beyond the user-defined high or low thresholds.
  • The ADC clock source used for conversions is selected by the RCC[2] independently from the AHB bus clock that is used to access the ADC registers.
  • The common reference voltage can be provided by either VREFBUF[3] or any other external regulator[4] wired to VREF+ pin.
Each ADC supports two contexts to manage conversions:
  • Regular conversions can be done in sequence, running in the background.
  • Injected conversions have a higher priority, and so can interrupt the regular sequence (either triggered in software or hardware). The regular sequence is resumed in case it has been interrupted.
  • Each context has its own configurable sequence and trigger: software, TIM[5], LPTIM[6], and EXTI[7].
Refer to the STM32 MPU reference manuals for the complete list of features and to the software frameworks and drivers introduced below to see which features are implemented.
3.1.1. On STM32MP21x lines [edit | edit source]
3.1.1.1. For A35-TD flavor [edit | edit source]
Domain Peripheral Boot time allocation Comment
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Analog ADC ADC1
ADC2
3.1.1.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Analog ADC ADC1
ADC2
3.1.2. On STM32MP23x lines [edit | edit source]
3.1.2.1. For A35-TD flavor [edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Analog ADC ADC12
ADC3
3.1.2.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Analog ADC ADC12
ADC3
3.1.3. On STM32MP25x lines [edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Analog ADC ADC12
ADC3
3.1.3.1. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Cortex-M33
(MCUboot)
Analog ADC ADC12
ADC3
3.2.1. On STM32MP21x lines [edit | edit source]
The tables below are applicable to any TD flavor (A35-TD or M33-TD) .
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Analog ADC ADC1 OP-TEE
ADC2 OP-TEE
3.2.2. On STM32MP23x lines [edit | edit source]
3.2.2.1. For A35-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Analog ADC ADC12 OP-TEE
ADC3 OP-TEE ADC3 may be used by the UCSI firmware to measure the Vbus level on the Type-C connector.
3.2.2.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
ADC3 OP-TEE
3.2.3. On STM32MP25x lines [edit | edit source]
3.2.3.1. For A35-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
3.2.3.2. For M33-TD flavor [edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
ADC3 OP-TEE
Below are listed the software frameworks and drivers managing the ADC peripheral for the embedded software components listed in the above tables.
For the Linux kernel U-boot and OP-TEE configuration, refer to ADC device tree configuration article.
See application notes:
  • How to get the best ADC accuracy in STM32[8].
