NVIC internal peripheral
  • briefly introduce the NVIC and its main features
  • explain how the NVIC can be configured.
The NVIC is the Arm® Cortex®-M4 interrupt controller. As a result, it cannot be accessed by the Arm Cortex-A7 core.
The NVIC is a non-secure peripheral.
3. Peripheral usage and associated software[edit | edit source]
The NVIC can be configured through the STM32Cube. Refer to the STM32MP15 interrupts article for more information on the interrupt configuration strategy.
The NVIC can be allocated only to the Arm Cortex-M4 core to be controlled in the STM32Cube by the NVIC HAL driver.
non-secure
Cortex-M4
Core/Interrupts NVIC STM32Cube NVIC driver
Internal peripherals
non-secure
Cortex-M4
Core/Interrupts NVIC NVIC
