2. Audio record overview[edit | edit source]
The application audio streams are routed by default through the PulseAudio sound server. PulseAudio exposes audio profiles, which are mapped on the ALSA sound card audio devices. The PulseAudio server provides a command line interface to list audio profiles and to select one, in order to record from a specific audio interface.
3. Examples[edit | edit source]
3.1. Audio record from headset microphone input[edit | edit source]
3.1.1. Record from ALSA device[edit | edit source]
'record_codec' is an alias defined in /etc/asound.conf, for headset microphone input device. |
arecord -D record_codec -f S16_LE -d 10 /tmp/rec.wav
3.1.2. Record via PulseAudio[edit | edit source]
3.1.2.1. For ecosystem release ≥ v1.2.0[edit | edit source]
- Configure Pulseaudio :
Change Pulseaudio default input source to 'analog_input':
The Pulseaudio analog_input is defined in /etc/pulse/system.pa configuration file. |
pacmd set-default-source analog_input
- Start audio record :
The Pulseaudio device is the default one, so "-D pulse" option can be omitted in the record command. |
arecord -d 10 /tmp/rec.wav
3.1.2.2. For ecosystem release ≤ v1.1.0[edit | edit source]
3.2. Audio record from digital microphone input[edit | edit source]
3.2.1. Record from ALSA device[edit | edit source]
'record_dfsdm0' is an alias defined in /etc/asound.conf, for digital microphone U1 input device. |
arecord -D record_dfsdm0 -r 16000 -f S32_LE -c 1 -d 10 /tmp/rec.wav
3.2.2. Record multiple digital microphones from a virtual ALSA device[edit | edit source]
Start stereo audio record from 'multi' ALSA device:
'multi' device, based on ALSA multi plugin[1], has to be defined in /etc/asound.conf file. |
arecord -D multi -r 16000 -f S32_LE -c 2 -d 10 /tmp/rec.wav
3.2.3. Record via PulseAudio[edit | edit source]
The record via Pulseaudio is only available for ecosystem release ≥ v1.2.0 .
Change Pulseaudio default input source to 'dmic1_input':
The Pulseaudio dmic1_input is defined in /etc/pulse/system.pa configuration file. |
pacmd set-default-source dmic1_input
arecord -r 48000 -f S32_LE -c 2 -d 10 /tmp/rec.wav
3.3. Audio record from S/PDIF input[edit | edit source]
3.3.1. Get IEC958 status bits[edit | edit source]
amixer -c STM32MP1EV cget iface=PCM,name='IEC958 Capture Default'
3.3.2. Record from ALSA device[edit | edit source]
'record_spdif' is an alias defined in /etc/asound.conf, for S/PDIF input device. |
A S/PDIF signal must be available on S/PDIF RCA input connector before starting the record command. The record rate must be set according to S/PDIF signal sampling rate. |
arecord -D record_spdif -f S32_LE -c 2 -r 48000 -d 10 /tmp/rec.wav
3.3.3. Record via PulseAudio[edit | edit source]
Change Pulseaudio default input source to 'iec958_input':
The Pulseaudio iec958_input is defined in /etc/pulse/system.pa configuration file. |
pacmd set-default-source iec958_input
