STM32MP23 U-Boot
This article briefly describes the STM32MP23x lines More info.png support in U-Boot.
1. STM32MP23x lines More info.png support[edit | edit source]
For detailed information, read the file in the delivered U-Boot code: doc/board/st/stm32mp2.rst or the documentation generated by make htlmdocs: board/st/stm32mp2.html.
Code:
Configuration files:
2. Selecting targets: choose defconfig and device tree[edit | edit source]
The U-Boot configuration with defconfig is stm32mp23_defconfig.
The boards are supported with the associated device tree (same name as kernel):
Board part number Device tree Description
STM32MP257F-DK Discovery kit More info green.png for STM32MP23x lines evaluation Info.png stm32mp235f-dk MB1605
3. Compilation[edit | edit source]
See U-Boot_overview#U-Boot_build, with installed aarch64 cross-compiler.
For STM32MP257F-DK Discovery kit More info green.png for STM32MP23x lines evaluation Info.png, the device tree is already selected in defconfig stm32mp23_defconfig
 make stm32mp23_defconfig
 make all
For other boards, you need to select the correct device tree.
 make DEVICE_TREE=<Device tree> all
The supported variables are:
  • DEVICE_TREE: Select in arch/arm/dts or in EXT_DTS the device tree that is used.
  • KBUILD_OUTPUT: Change the destination directory for the build
  • EXT_DTB: Select external device tree.
  • EXT_DTS: Select the path of the external device tree source. By default, the sub-directory "arch/arm/dts/external-dt" is used to allow sub-module.
The output files u-boot.dtb and u-boot-nodtb.bin are integrated in TF-A FIP.
Note: All the compiled device trees are available in $KBUILD_OUTPUT/arch/arm/dts/*.dtb.
4. Examples[edit | edit source]
4.1. STM32MP257F-DK Discovery kit More info green.png for STM32MP23x lines evaluation Info.png[edit | edit source]
 make DEVICE_TREE=stm32mp235f-dk all
and
 fiptool --verbose update --nt-fw u-boot-nodtb.bin  --hw-config u-boot.dtb \
                        fip-stm32mp235f-dk.bin
4.2. STM32MP257F-DK Discovery kit More info green.png for STM32MP23x lines evaluation Info.png with export[edit | edit source]
 export KBUILD_OUTPUT=../build/stm32mp23
 export DEVICE_TREE=stm32mp235f-dk
 make  all
and
 fiptool --verbose update --nt-fw $KBUILD_OUTPUT/u-boot-nodtb.bin  \
                        --hw-config $KBUILD_OUTPUT/u-boot.dtb \
4.3. Custom board with external device tree[edit | edit source]
 make EXT_DTB=stm32mp235f-myboard.dtb all
 fiptool --verbose update --nt-fw u-boot-nodtb.bin \
             fip-stm32mp235f-myboard.bin
