- briefly introduce the VREFBUF peripheral and its main features,
The VREFBUF is supplied via the VDDA pin. When enabled, it can provide a reference voltage in the range of: 1,21V or 1,5V. The VREFBUF can be used to provide an analog voltage reference for:
- ADC internal peripheral
- External components through the dedicated VREF+ pin.
3.1.1. On STM32MP2 series[edit | edit source]
- ☑ means that the peripheral is assigned by default to the given boot time context and that the peripheral is mandatory for the Yocto-based OpenSTLinux Embedded Software.
- ⬚ means that the peripheral can be assigned to the given boot time context, but this configuration is not supported in Yocto-based OpenSTLinux Embedded Software.
Cortex-A35 nonsecure (U-Boot) | |||
Analog | VREFBUF | VREFBUF | ⬚ | OP-TEE offers SCMI regulator service to manage VREFBUF |
Information |
As soon as VREFBUF client peripherals (ADC1 or ADC2 or ADC3) are assigned to different execution contexts, the VREFBUF should be assigned to main processor secure context with RIFSC. In Cortex-A35 main processor mode, OpenSTlinux offers only VREFBUF support by OP-TEE secure OS through SCMI even if all ADC are assigned to a unique execution context. |
3.2.1. On STM32MP21x lines [edit | edit source]
Check boxes illustrate the possible peripheral allocations supported by Yocto-based OpenSTLinux Embedded Software:
- ☑ means that the peripheral is assigned by default to the given runtime context and that the peripheral is mandatory for the Yocto-based OpenSTLinux Embedded Software.
- ⬚ means that the peripheral can be assigned to the given runtime context, but this configuration is not supported in Yocto-based OpenSTLinux Embedded Software.
Domain | Peripheral | Runtime allocation | Comment | ||||
Cortex-A35 nonsecure (Linux) |
Cortex-M33 secure (TF-M) |
Cortex-M33 nonsecure (STM32Cube) | |||
Power & Thermal | VREFBUF | VREFBUF | ☑OP-TEE | ⬚ | ⬚ | ⬚ | OP-TEE offers SCMI regulator service to manage VREFBUF |
3.2.2. On STM32MP23x lines [edit | edit source]
3.2.3. On STM32MP25x lines [edit | edit source]
Cortex-M0+ (STM32Cube) | |||
Below are listed the software frameworks and drivers managing the VREFBUF peripheral for the embedded software components listed in the above tables.
- SCMI
- OP-TEE driver: core/drivers/regulator/stm32_vrefbuf.c
- partial device trees (pin control and clock tree) for the OpenSTLinux software components,
- For the Linux kernel configuration, please refer to device internal regulator. An example can be found also in ADC DT configuration examples
5.1. DT configuration example[edit | edit source]
In OP-TEE device tree:
&etzpc { st,decprot = < DECPROT(STM32MP1_ETZPC_VREFBUF_ID, DECPROT_S_RW, DECPROT_UNLOCK) >; }; &scmi_regu { scmi_vrefbuf: voltd-vrefbuf { reg = <VOLTD_SCMI_VREFBUF>; voltd-supply = <&vrefbuf>; }; }; &vrefbuf { vdda-supply = <&vdd>; status = "okay"; };
In Linux device tree:
&adc_1 { ... vref-supply = <&scmi_vrefbuf>; status = "okay"; };
&scmi_regu {
regulator-name = "vrefbuf";
regulator-min-microvolt = <1500000>;
regulator-max-microvolt = <1500000>;
