- briefly introduce the UCPD peripheral and its main features,
The UCPD peripheral is used to support USB Type-C®/USB Power Delivery interface.
The built-in PHY directly detects Type-C voltage levels and covers the signaling of the USB Power Delivery specification on the CC lines.
The UCPD peripheral is compliant with:
3.1.1. On STM32MP23 unknown microprocessor device and STM32MP25x lines
Domain | Peripheral | Boot time allocation | Comment ![]() | |||
High speed interface | UCPD | UCPD1 | ⬚ | ⬚ |
3.2.1. On STM32MP23 unknown microprocessor device[edit | edit source]
| rowspan="1" | High speed interface | rowspan="1" | UCPD | UCPD1 | ⬚OP-TEE | ⬚ | ⬚ | ☐ | |-
3.2.2. On STM32MP25x lines
Domain | Peripheral | Runtime allocation | Comment ![]() | |||||
Cortex-M33 secure (TF-M) |
Cortex-M0+![]() (STM32Cube) | |||
High speed interface | UCPD | UCPD1 | ⬚OP-TEE | ⬚ | ⬚ | ☐ |
Below are listed the software frameworks and drivers managing the UCPD peripheral for the embedded software components listed in the above tables.
- STM32Cube: STM32_USBPD_Library
- partial device trees (pin control and clock tree) for the OpenSTLinux software components,
- Linux®:
- Linux remoteproc framework allows to start the firmware running on the Arm® Cortex®-M33 (coprocessor).
This firmware configures and controls the UCPD internal peripheral. - Linux RPMsg framework allows the UCSI firmware to communicate with the STM32 UCSI Linux driver
- The link between the USB data controller and the Type-C connector can be configured through the Generic USB Connector Device Tree Bindings [3]. Examples to use the USB3DR internal peripheral can be found in USB3DR device tree configuration.
More information, tips, and tricks related to STM32 USB Type-C® Power Delivery, can be found in STM32 MCU wiki page:
X-CUBE-UCSI Expansion Package running on STM32MP135F-DK board, with STM32G0:
USBPD_DRP_UCSI Application running on STM32MP257x-EV1 board, in the Arm® Cortex®-M33 (coprocessor):
- ↑ USB Type-C specification release 2.2
- ↑ USB Power Delivery specifications revision 2.0 and 3.1
- ↑ Documentation/devicetree/bindings/connector/usb-connector.yaml , Generic USB Connector Device Tree Bindings
