IPCC device tree configuration
Applicable for STM32MP15x lines, STM32MP21x lines, STM32MP23x lines, STM32MP25x lines
This article explains how to configure the IPCC internal peripheral controlled by the Linux Mailbox framework.
The configuration is performed using the device tree mechanism that provides a hardware description of the IPCC peripheral, used by the STM32 IPCC Linux driver.
The IPCC internal peripheral is represented by:
  • The Generic mailbox device tree bindings[1]
  • The STM32 IPCC device tree bindings[2]
This hardware description is a combination of the STM32 microprocessor device tree files (.dtsi extension) and the board device tree files (.dts extension). See the Device tree for an explanation of the device tree file split.
  • On STM32MP15x lines More info.png the IPCC peripheral node is located in stm32mp151.dtsi [3] file.
  • On STM32MP21x lines More info.png the IPCC1 peripheral node is located in stm32mp211.dtsi [4] file.
  • On STM32MP23x lines More info.png the IPCC1 peripheral node is located in stm32mp231.dtsi [5] file.
  • On STM32MP25x lines More info.png the IPCC1 and IPCC2 peripheral nodes are located in stm32mp251.dtsi [6] file.
The st,proc-id property specifies the ID of the IPCC processor interface assigned to the Cortex-A processor, according to the Processor interface assignment
  • st,proc-id = <0>; indicates that the IPCC processor interface 1 (PROC1) is used,
  • st,proc-id = <1>; indicates that the IPCC processor interface 2 (PROC2) is used.
This device tree part is related to STM32 microprocessors. It must be kept as it is, without being modified by the end-user.
This part is used to enable the IPCC hardware on a board:
&ipcc {
	status = "okay";
Below is an example of the remoteproc client using three mailbox channels:
&m4_rproc {
	mboxes = <&ipcc 0>, <&ipcc 1>, <&ipcc 2>;
	mbox-names = "vq0", "vq1", "shutdown";
Using the IPCC ID parameter, it is possible to specify whether the mailbox client is notified in an interrupt context or in a normal context:
  • ID i, with i in the range [0, IPCC channel - 1], is used for notification in a normal context.
  • ID 0x100 + i, with i in the range [0, IPCC channel - 1], is used for notification in an interrupt context.
For instance, to declare "vq0" and "vq1" notifications under an interrupt context, the previous example becomes:
&m4_rproc {
	mboxes = <&ipcc 0x100>, <&ipcc 0x101>, <&ipcc 2>;
The STM32CubeMX may not support all the properties described in the above DT bindings documentation paragraph. In such a case, the tool inserts user sections in the generated device tree. These sections can then be edited to add some properties and they are preserved from one generation to another. Refer to STM32CubeMX user manual for more information.
