- Briefly introduce the RNG peripheral and its main features.
- List the software frameworks and drivers managing the peripheral.
- Explain how to configure the peripheral.
2. Peripheral overview
The RNG peripheral is used to provide 32-bit random numbers.
3. Peripheral usage
This chapter is applicable in the scope of the OpenSTLinux BSP running on the Arm® Cortex®-A processor, and the STM32CubeMPU Package running on the Arm® Cortex®-M processor.
Refer to the wiki article Hardware random overview to learn more on the possible usages of this peripheral.
3.1. Boot time assignment
3.1.1. On STM32MP13x lines
Domain | Peripheral | Boot time allocation | Comment ![]() | |||
Cortex-A7 secure (TF-A BL2) |
Security | RNG | RNG | ✓ | ☑ | ☐ | Required for DPA peripheral protection |
3.1.2. On STM32MP15x lines
Security | RNG | RNG1 | ☑ | ☐ |
3.1.3. On STM32MP21 unknown microprocessor device
Security | RNG | RNG1 | ✓ | ☑ | ⬚ | |
RNG2 | ✓ | ☐ | ⬚ |
3.1.4. On STM32MP23 unknown microprocessor device
Security | RNG | RNG | ✓ | ☑ | ⬚ |
3.1.5. On STM32MP25x lines
3.2. Runtime assignment
If the Arm® Cortex®-A processor hardware RNG peripheral is assigned to OP-TEE, then the Linux kernel can request random numbers through the hardware random framework, which is interfaced with the OP-TEE RNG Linux driver .
If the Arm® Cortex®-A processor hardware RNG peripheral is assigned to the Linux kernel, then the Linux kernel can access it through the hardware random framework, which is interfaced with the Linux RNG driver .
3.2.1. On STM32MP13x lines
Domain | Peripheral | Runtime allocation | Comment ![]() | ||
Security | RNG | RNG | ☐ | ☐ | Assignment (single choice) |
3.2.2. On STM32MP15x lines
Domain | Peripheral | Runtime allocation | Comment ![]() | |||
Cortex-M4 (STM32Cube) | |||
Security | RNG | RNG1 | ☐ | ☐ | Assignment (single choice) | |
RNG2 | ☐ |
3.2.3. On STM32MP21 unknown microprocessor device
| rowspan="2" | Security | rowspan="2" | RNG | RNG1 | ☑OP-TEE | ⬚ | ☐ | ⬚ | |- | RNG2 | ☐OP-TEE | ⬚ | ☐ | ⬚ | |-
3.2.4. On STM32MP23 unknown microprocessor device
| rowspan="1" | Security | rowspan="1" | RNG | RNG | ☑OP-TEE | ⬚ | ☐ | ⬚ | |-
3.2.5. On STM32MP25x lines
Domain | Peripheral | Runtime allocation | Comment ![]() | |||||
Cortex-M33 secure (TF-M) |
Cortex-M0+![]() (STM32Cube) | |||
Security | RNG | RNG | ☑OP-TEE | ⬚ | ☐ | ⬚ |
Below are listed the software frameworks and drivers managing the RNG peripheral for the embedded software components listed in the above tables.
- Linux®: hardware random framework, Linux RNG driver , and OP-TEE RNG Linux driver when random number generation is managed by OP-TEE (default behavior)
- U-Boot: U-Boot RNG driver and OP-TEE RNG U-Boot driver
- OP-TEE: OP-TEE RNG driver and RNG PTA
- STM32Cube: RNG HAL driver and header file of RNG HAL module
- Partial device trees (pin control and clock tree) generation for the OpenSTLinux software components.
This configuration is done in OP-TEE through the device tree.
For more information, refer to the wiki article RNG device tree configuration.
6. References
