This article explains how to configure the CEC [1] when the peripheral is assigned to the Linux® OS.
The configuration is performed using the device tree mechanism [2].
The Device tree provides a hardware description of the CEC [1] used by the STM32 CEC Linux driver.
The CEC is represented by the STM32 CEC device tree bindings in the file Documentation/devicetree/bindings/media/cec/st,stm32-cec.yaml [3].
The CEC device tree node is declared in arch/arm/boot/dts/st/stm32mp151.dtsi [4]. It describes the hardware register address, clocks, interrupts and power domains.
etzpc: bus@5c007000 {
cec: cec@40016000 {
compatible = "st,stm32-cec";
reg = <0x40016000 0x400>;
interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&rcc CEC_K>, <&rcc CEC>;
clock-names = "cec", "hdmi-cec";
access-controllers = <&etzpc 38>;
status = "disabled";
The CEC device tree node contains the pinctrl description and the "okay" status:
&cec {
pinctrl-names = "default";
pinctrl-0 = <&cec_pins_a>;
status = "okay";
You can find a full example of the STM32MP15 Evaluation board device tree in arch/arm/boot/dts/st/stm32mp157f-ev1.dts [5].
You can find a full example of the CEC pins [6] in the arch/arm/boot/dts/st/stm32mp15-pinctrl.dtsi [7]
cec_pins_a: cec-0 {
pins {
pinmux = <STM32_PINMUX('A', 15, AF4)>;
bias-disable;
drive-open-drain;
slew-rate = <0>;
cec_sleep_pins_a: cec-sleep-0 {
pins {
pinmux = <STM32_PINMUX('A', 15, ANALOG)>; /* HDMI_CEC */
cec_pins_b: cec-1 {
pins {
pinmux = <STM32_PINMUX('B', 6, AF5)>;
bias-disable;
drive-open-drain;
slew-rate = <0>;
cec_sleep_pins_b: cec-sleep-1 {
pins {
pinmux = <STM32_PINMUX('B', 6, ANALOG)>; /* HDMI_CEC */
- ↑ 1.0 1.1 CEC internal peripheral
- ↑ Device tree
- ↑ st,stm32-cec.yaml Linux kernel bindings
- ↑ Linux kernel STM32MP15x device tree (stm32mp151.dtsi)
- ↑ Linux kernel STM32MP157 Evaluation board device tree (stm32mp157f-ev1.dts)
- ↑ Pinctrl device tree configuration
- ↑ Linux kernel STM32MP15x pinctrl device tree (stm32mp15-pinctrl.dtsi)
