VENC device tree configuration
This article explains how to configure the VENC [1] when the peripheral is assigned to the Linux® OS.
The configuration is performed using the device tree mechanism [2].
The Device tree provides a hardware description of the VENC [1] used by the STM32 VENC Linux driver.
The VENC is represented by the STM32 VDEC device tree bindings file: st,stm32mp25-video-codec.yaml .
3.1. DT configuration (STM32/SoC level)[edit | edit source]
The VENC node is located in the device tree file for the software components, supporting the peripheral and listed in the above DT bindings documentation paragraph.
For STM32MP25x lines More info.png, the VENC device tree node is declared in arch/arm64/boot/dts/st/stm32mp255.dtsi :
&rifsc {
	venc: venc@480e0000 {
		compatible = "st,stm32mp25-venc";
		reg = <0x480e0000 0x800>;
		resets = <&rcc VENC_R>;
		interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>;
		clocks = <&rcc CK_BUS_VENC>;
		access-controllers = <&rifsc 90>;
		power-domains = <&CLUSTER_PD>;
For STM32MP25x lines More info.png, the STM32 VENC is already enabled by default in stm32mp255.dtsi , so there is no need to enable it at board level.
