How to configure U-Boot to support Fastboot mode
This article explains how to configure U-Boot to support Fastboot mode.
1. Fastboot[edit | edit source]
Fastboot is a protocol that was originally created for Android™ and is primarily used to modify the flash filesystem via a USB connection from a host computer, see U-Boot Documentation android/fastboot.rst for details.
2. Configure U-Boot to support Fastboot mode[edit | edit source]
Fastboot is supported in U-Boot but it is not necessarily enabled by default with configuration symbols defined in fastboot Kconfig file .
A U-Boot binary, and so a fip, can support only one mass storage device for Fastboot, defined in the used defconfig file.
For instance, if a U-Boot is configured to support Fastboot on eMMC, it cannot be used to program the SD card with Fastboot.
U-Boot configuration must be done according to the mass storage boot device, for STMicroelectronics boards we have:
  • SD card is on mmc0.
  • eMMC is on mmc1.
Refer to STM32CubeProgrammer flashlayout for more information.
To enable Fastboot or to modify the Fastboot configuration, the U-Boot configuration must be modified. This can be done with the SDK.
2.1. With menuconfig[edit | edit source]
U-Boot configuration for Fastboot can be done by using make menuconfig in the U-Boot source code.
Follow these steps to enable Fastboot support on SD card on STM32MP157F-EV1 More info green.png:
  • Identify the mmc device number. Information can be seen here.
    For the STM32MP157F-EV1 Evaluation board More info green.png, SD card is on mmc0.
  • Generate the configuration for the board:
make stm32mp15_defconfig
  • Configure Fastboot
make menuconfig
For mmc0 (SD card)
For mmc1 (eMMC)
  • Build u-boot
make DEVICE_TREE=stm32mp157f-ev1 all
  • Generate the fip
fiptool update \
   --nt-fw u-boot-nodtb.bin  \
    --hw-config u-boot.dtb \
    <FIP location>/fip-stm32mp157c-ev1-optee.bin
2.2. With fragments[edit | edit source]
U-Boot configuration for Fastboot can be done by adding a fragment to the default configuration.
The fragment is different depending on the chosen boot storage:
  • If the SD card is on mmc0, then it is the fragment fragment-04-fastboot_mmc0.fb_cfg
  • If eMMC is on mmc1, then it is the fragment fragment-05-fastboot_mmc1.fb_cfg
Fragments are delivered in the STM32 MPU Embedded Software Developer Package. They are also available on GitHub:
For the STM32MP157F-EV1 Evaluation board More info green.png SD card is on mmc0.
  • Append the corresponding fragment to the default configuration:
cat ../fragment-04-fastboot_mmc0.fb_cfg >> configs/stm32mp15_defconfig
  • Build U-Boot using the SDK:
make -f $PWD/../Makefile.sdk UBOOT_DEFCONFIG=stm32mp15_defconfig DEVICETREE=stm32mp157f-ev1 all
