- briefly introduce the DCMI peripheral and its main features,
The DCMI (digital camera memory interface) peripheral is used to receive some video data from an external parallel camera sensor device or any other digital video equipment supporting parallel interface.
The DCMI hardware block can receive raw data frames in RGB565 and YUV422 formats as well as JPEG compressed data.
Refer to STM32 DCMI presentation [1] for an overview of DCMI hardware block and its capabilities.
3.1.1. On STM32MP1 series[edit | edit source]
The DCMI peripheral is not used at boot time.
3.1.2. On STM32MP25x lines
3.1.2.1. Cortex-A35 master boot[edit | edit source]
Domain | Peripheral | Boot time allocation | Comment ![]() | |||
Visual | DCMI | DCMI | ⬚ |
3.1.3. On STM32MP23 unknown microprocessor device[edit | edit source]
3.1.3.1. Cortex-A35 master boot[edit | edit source]
3.1.4. On STM32MP21 unknown microprocessor device[edit | edit source]
3.1.4.1. Cortex-A35 master boot[edit | edit source]
3.2.1. On STM32MP15x lines
Domain | Peripheral | Runtime allocation | Comment ![]() | |||
Cortex-M4 (STM32Cube) | |||
Visual | DCMI | DCMI | ☑ | ☐ | Assignment (single choice) |
3.2.2. On STM32MP25x lines
Domain | Peripheral | Runtime allocation | Comment ![]() | |||||
Cortex-M33 secure (TF-M) |
Cortex-M0+![]() (STM32Cube) | |||
Visual | DCMI | DCMI | ⬚OP-TEE | ☑ | ⬚ | ☐ |
3.2.3. On STM32MP23 unknown microprocessor device[edit | edit source]
| rowspan="1" | Visual | rowspan="1" | DCMI | DCMI | ⬚OP-TEE | ☑ | ⬚ | ☐ | |-
3.2.4. On STM32MP21 unknown microprocessor device[edit | edit source]
Below are listed the software frameworks and drivers managing the DCMI peripheral for the embedded software components listed in the above tables.
- Linux®: V4L2 framework
- STM32Cube:
- for STM32MP15x lines
: DCMI HAL driver and header file of DCMI HAL module
- for STM32MP2 series: DCMI HAL driver and header file of DCMI HAL module
See also additional information in the DCMI device tree configuration article for Linux®.
Refer to STM32 DCMI Application Note (AN5020)[2] for a detailed description of the DCMI peripheral and applicable use-cases.
This application note is related to STM32 microcontrollers but it is also applicable to STM32 MPUs. This document can help to better understand stm32-dcmi V4L2 kernel driver and debug camera sensor and DCMI interactions.
