- briefly introduce the ADC peripheral and its main features,
The ADC peripheral is a successive approximation analog-to-digital converter.
On STM32MP25x lines , there are three physical ADCs distributed between two ADC blocks:
- Each ADC has up to 20 multiplexed channels.
- ADC1 and ADC2 are tightly coupled.
- ADC1 is connected to 18 external channels + 2 internal channels.
- ADC2 is connected to 14 external channels + 6 internal channels.
- ADC3 is controlled independently.
- ADC3 is connected to 14 external channels + 6 internal channels.
- Configurable resolution: 12, 10, 8, 6 bits.
- The conversions can be performed in single, continuous, scan, or discontinuous mode.
- The result can be read in a left-aligned or right-aligned 32-bit data register by using CPU or DMA[1].
- The analog watchdog feature allows the application to detect if the input voltage goes beyond the user-defined high or low thresholds.
- The ADC clock source used for conversions is selected by the RCC[2] independently from the AHB bus clock that is used to access the ADC registers.
- The common reference voltage can be provided by either VREFBUF[3] or any other external regulator[4] wired to VREF+ pin.
Each ADC supports two contexts to manage conversions:
- Regular conversions can be done in sequence, running in the background.
- Injected conversions have a higher priority, and so can interrupt the regular sequence (either triggered in software or hardware). The regular sequence is resumed in case it has been interrupted.
- Each context has its own configurable sequence and trigger: software, TIM[5], LPTIM[6], and EXTI[7].
Refer to the STM32 MPU reference manuals for the complete list of features and to the software frameworks and drivers introduced below to see which features are implemented.
3.1.1. On STM32MP2 series[edit | edit source]
Domain | Peripheral | Boot time allocation | Comment ![]() | |||
Analog | ADC | ADC12 | ⬚ | ☐ | ||
ADC3 | ⬚ | ☐ |
3.2.1. On STM32MP25x lines
Domain | Peripheral | Runtime allocation | Comment ![]() | |||||
Cortex-M33 secure (TF-M) |
Cortex-M0+![]() (STM32Cube) | |||
Analog | ADC | ADC12 | ⬚ | ☐ | ⬚ | ☐ | ||
ADC3 | ⬚ | ☐ | ⬚ | ☑ | ADC3 may be used by the UCSI firmware to measure the Vbus level on the Type-C connector. |
Below are listed the software frameworks and drivers managing the ADC peripheral for the embedded software components listed in the above tables.
- partial device trees (pin control and clock tree) for the OpenSTLinux software components,
For the Linux kernel U-boot and OP-TEE configuration, refer to ADC device tree configuration article.
See application notes:
