ETZPC internal peripheral
  • briefly introduce the ETZPC peripheral and its main features,
The ETZPC peripheral is used to configure TrustZone security in a STM32 MPU device. That STM32 MPU device has bus masters and slaves with programmable-security attributes (securable resources) such as:
  • On-chip RAM/ROM with programmable secure region size,
  • AHB and APB peripherals to be made secure,
  • AHB masters to be granted secure rights.
Refer to the STM32 MPU reference manuals for the complete list of features, and to the software frameworks and drivers, introduced below, to see which features are implemented. Securable peripherals list varies from one platform to another.
2.1. On STM32MP15x lines More info.png[edit | edit source]
The ETZPC peripheral also allows peripheral isolation. With MCU isolation, some peripherals can be assigned to Cortex-M4 context execution only. Those peripherals will not be accessible for Cortex-A7 contexts (secure and nonsecure).
ETZPC peripheral is write-secure only. TF-A configures it at boot time but its final boot configuration is set by OP-TEE during its initialization and managed by OP-TEE at runtime. Linux kernel and U-Boot supports the ETZPC as a firewall bus. This firewall bus is responsible for checking the ETZPC configuration to determine which hardware resources can be used or not.
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Security ETZPC Any instance ETZPC configuration is set by OP-TEE
non-secure
Security ETZPC ETZPC
non-secure
Cortex-M4
Below are listed the software frameworks and drivers managing the ETZPC peripheral for the embedded software components listed in the above tables.
  • Partial device trees (pin control and clock tree) generation for the OpenSTLinux software components,
This configuration is done in OP-TEE, through device tree.
Refer to ETZPC device tree configuration.
The ETZPC is an STMicroelectronics extension of the Arm® peripheral: TrustZone Protection Controller[1]
