Netstat
This article provides the basic information needed to start using the Linux tool: netstat [1].
netstat Monitoring tools netstat[1] prints network connections, routing tables, interface statistics, masquerade connections, and multicast membership information. Yes Yes Yes Yes Yes Yes
netstat is installed by default and ready to be used with all STM32MPU Embedded Software Packages.
It comes through the busybox:
which netstat | xargs ls -la
/bin/netstat -> /bin/busybox.nosuid
3.2. Using the STM32MPU Embedded Software distribution for Android™[edit | edit source]
netstat is installed by default and ready to be used with all STM32MPU Embedded Software Packages for Android™.
It comes with the toybox:
/system/bin/netstat -> toybox
Here are basic commands to start with netstat:
  • Display kernel routing information
netstat -rn
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
0.0.0.0         10.99.3.254     0.0.0.0         UG        0 0          0 end0
10.99.0.0       0.0.0.0         255.255.252.0   U         0 0          0 end0
10.99.3.254     0.0.0.0         255.255.255.255 UH        0 0          0 end0
  • List out listening-only connections
netstat -tnl
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 0.0.0.0:19999           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN
tcp        0      0 10.99.1.237:53          0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:1534            0.0.0.0:*               LISTEN
tcp        0      0 :::19999                :::*                    LISTEN
tcp        0      0 :::5355                 :::*                    LISTEN
tcp        0      0 :::53                   :::*                    LISTEN
tcp        0      0 :::22                   :::*                    LISTEN
Additional documentation is available on Internet about netstat. See References.
Refer to Linux® man page[1] for more details on command options.
  • Useful external links
netstat (wikipedia.org) Standard wikipedia.org
netstat examples User Guide binarytides.com
netstat main commands User Guide geekflare.com
