QUADSPI internal peripheral
  • briefly introduce the QUADSPI peripheral and its main features,
The QUADSPI peripheral interfaces the processor with serial NOR flash and serial NAND flash memories.
It supports:
  • Single, Dual- or Quad-SPI flash memories
  • A dual-flash mode, allowing to aggregate two flash memories into a virtual-single one
  • Dual data rate and memory-mapped modes.
3.1.1. On STM32MP1 series[edit source]
QUADSPI instance is a boot device that supports serial boot for flash programming with STM32CubeProgrammer.
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Mass storage QUADSPI QUADSPI
3.2.1. On STM32MP13x lines More info.png[edit source]
non-secure
Mass storage QUADSPI QUADSPI Assignment (single choice)
3.2.2. On STM32MP15x lines More info.png[edit source]
non-secure
Cortex-M4
Below are listed the software frameworks and drivers managing the QUADSPI peripheral for the embedded software components listed in the above tables.
For Linux kernel configuration, refer to QUADSPI device tree configuration.
