- briefly introduce the BSEC peripheral and its main features,
The BSEC peripheral is used to control an OTP (one time programmable) fuse box, used for on-chip non-volatile storage for device configuration and security parameters.
3.1.1. On STM32MP1 series[edit source]
The BSEC is configured at boot time to set up platform security.
Domain | Peripheral | Boot time allocation | Comment ![]() | |||
Cortex-A7 secure (TF-A BL2) |
Security | BSEC | BSEC | ✓ | ✓ | ☐ |
3.1.2. On STM32MP2 series[edit source]
3.2.1. On STM32MP13x lines
[edit source]
Domain | Peripheral | Runtime allocation | Comment ![]() | ||
Security | BSEC | BSEC | ✓ | ☐ |
3.2.2. On STM32MP15x lines
[edit source]
Domain | Peripheral | Runtime allocation | Comment ![]() | |||
Cortex-M4 (STM32Cube) | |||
Security | BSEC | BSEC | ✓ | ☐ | ⬚ | Cortex-M4 can read BSEC shadow register (BSEC_OTP_DATAx) to read a lower OTP value |
3.2.3. On STM32MP25x lines
[edit source]
Domain | Peripheral | Runtime allocation | Comment ![]() | |||||
Cortex-M33 secure (TF-M) |
Cortex-M0+![]() (STM32Cube) | |||
Security | BSEC | BSEC | ✓OP-TEE ✓TF-A BL31 |
Below are listed the software frameworks and drivers managing the BSEC peripheral for the embedded software components listed in the above tables.
- Linux®: NVMEM framework
- OP-TEE: OP-TEE OTP overview
- TF-A BL2:
- TF-A BSEC2 driver for STM32MP1 series
- TF-A BSEC3 driver for STM32MP2 series
- U-Boot: U-Boot BSEC driver based on OP-TEE BSEC PTA
See also additional information in the BSEC device tree configuration article.
