- briefly introduce the TZC peripheral and its main features,
The TZC peripheral is used to filter read/write accesses to the DDR controller according to TrustZone access rights, and according to Non-Secure master Address ID (NSAID) on up to 9 programmable regions.
3.1.1. On STM32MP1 Series[edit | edit source]
The TZC is configured at boot time to setup DDR accesses. It is initially configured thanks to TF-A FW Configuration. OP-TEE redefined the TZC regions based on device tree.
- ☐ means that the peripheral can be assigned (☑) to the given boot time context.
Cortex-A7 secure (TF-A BL2) |
Security | TZC | TZC | ✓ |
3.2.1. On STM32MP13x lines [edit | edit source]
3.2.2. On STM32MP15x lines [edit | edit source]
Cortex-M4 (STM32Cube) | |||
Below are listed the software frameworks and drivers managing the TZC peripheral for the embedded software components listed in the above tables.
- OP-TEE: TZC driver
- TF-A BL2: TF-A FW Configuration
See also additional information in the OP-TEE overview article.
The TZC is an Arm® peripheral: TZC-400 TrustZone Address Space Controller[1]
