- briefly introduce the TZC peripheral and its main features
- explain how it can be allocated to the runtime contexts and linked to the corresponding software components
- explain, when necessary, how to configure the TZC peripheral.
The TZC peripheral is used to filter read/write accesses to the DDR controller according to TrustZone access rights, and according to Non-Secure master Address ID (NSAID) on up to 9 programmable regions.
Refer to the STM32MP13 reference manuals or STM32MP15 reference manuals for the complete list of features, and to the software components, introduced below, to see which features are implemented.
The TZC is a secure peripheral.
3. Peripheral usage and associated software[edit | edit source]
The TZC is configured at boot time to setup DDR accesses. It is initially configured thanks to TF-A FW Configuration. OP-TEE redefined the TZC regions based on device tree.
The TZC is a system peripheral and is controlled by the Arm® Cortex®-A7 secure.
3.2.2.1. On STM32MP13x lines [edit | edit source]
OP-TEE | Linux | |||
Security | TZC | OP-TEE TZC driver |
3.2.2.2. On STM32MP15x lines [edit | edit source]
The configuration is applied by the firmware running in the secure context.
This configuration is done in OP-TEE.
3.2.4.1. On STM32MP13x lines [edit | edit source]
Security | TZC | TZC | ✓ |
3.2.4.2. On STM32MP15x lines [edit | edit source]
Cortex-M4 (STM32Cube) | |||
4. How to go further[edit | edit source]
The TZC is an Arm® peripheral: TZC-400 TrustZone Address Space Controller[1]
