SPDIFRX internal peripheral
  • briefly introduce the SPDIFRX peripheral and its main features
  • explain how to configure the SPDFIRX peripheral.
The SPDIFRX peripheral, is designed to receive an S/PDIF flow compliant with IEC-60958 and IEC-61937. The SPDIFRX receiver provides two separated paths to retrieve the audio data and the user and channel information.
Refer to the STM32MP15 reference manuals for the complete feature list, and to the software components, introduced below, to see which features are implemented.
The SPDFIRX is a non secure peripheral.
3. Peripheral usage and associated software[edit | edit source]
The SPDFIRX is not used at boot time.
The SPDIFRX instance can be allocated to:
Chapter #Peripheral assignment exposes which instance can be assigned to which context.
| Audio
| SPDIFRX
| ALSA framework
| STM32Cube SPDIFRX driver
3.2.3.1. Configuration in Cortex-A7 non-secure software[edit | edit source]
When the Arm® Cortex®-A7 core operates in non-secure access mode, the SPDIFRX is controlled by the Linux kernel framework. Refer to the SPDIFRX Linux driver to drive the SPDIFRX through Linux kernel ALSA framework. Refer to Soundcard configuration and SPDIFRX device tree configuration to configure the SPDIFRX through Linux kernel device tree[1].
3.2.3.2. Arm® Cortex®-M4 software configuration[edit | edit source]
| rowspan="1" | Audio
| rowspan="1" | SPDIFRX
| SPDIFRX
| Assignment (single choice)
4. How to go further[edit | edit source]
The STM32H7 SPDIFRX training [2], introduces the STM32 S/PDIF Receiver interface on the STM32H7. This training also applies to the STM32 MPU SPDIFRX internal peripheral.
