- briefly introduce the RCC peripheral and its main features,
The RCC peripheral is used to manage the clock and reset generation for the complete circuit. The RCC gets several internal and external oscillators. They are used as clock sources for the hardware blocks, either directly or indirectly, via the PLLs that allow to achieve high frequencies.
The different features of RCC could be assigned to the execution contexts of the platform:
- On STM32MP13x lines , each resource/sub-function is allocated either to the secure world or to the non-secure world via bits in the RCC_SECCFGR register.
- On STM32MP15x lines , there are two levels of security, which are controlled via two bits in the RCC_TZCR register (only accessible in secure mode):
- TZEN allows to set some RCC registers in secure mode, in particular registers for configuring PLL1 and PLL2, in order to secure a TrustZone perimeter for the Cortex®-A7 secure core and its peripherals.
- MCKPROT allows extending the TZEN secure clock control perimeter to PLL3 and to the MCU subsystem, so to the Cortex®-M4 and its bus clock.
- On STM32MP2 series, RCC is a RIF-aware peripheral. That means
- Dedicated RCC features are protected by RIF protection embedded in RCC following peripheral firewall rules described in Resource Isolation Framework overview
- Internal peripheral reset and clock gating control inherit from RIFSC configuration
- Note:
- Clock gating registers of system resources (Internal RAM, RIF-aware peripherals) are protected by RCC RIF protection (no RIFSC inheritance). This allows to manage automatic clock gating according to either processor low power state or system low power state. Indeed, when a peripheral is shared, it should always be available to any execution context at any time.
Please note that all RCC registers can be read from any execution context.
3.1.1. On STM32MP1 series[edit | edit source]
The RCC is used by all the boot components: the ROM code, the FSBL, the SSBL and up to the Linux® kernel. Each component is able to reset and gate internal peripherals
FSBL is responsible to make a minimal clock tree initialization for loading the next boot stages. Then the main clock tree initialization step is performed by the OP-TEE secure OS: it consists in configuring all the input clocks, the PLLs and the clock sources that are selected as kernel clocks for all peripherals. The whole clock tree configuration is carried out by the device tree (see STM32MP13 clock tree and STM32MP15 clock tree).
Cortex-A7 secure (TF-A BL2) |
Power & Thermal | RCC | RCC | ✓ | ✓ | ✓ |
3.1.2. On STM32MP21x lines [edit | edit source]
In Cortex-A main processor mode, the RCC is used by all the boot components: the ROM code, the Cortex-A FSBL, the Secure OS, the SSBL and the Linux® kernel. Each SW component is able to reset and gate internal peripherals assigned to it.
ROM code clock tree configuration is fixed, mainly based on HSI internal oscillator. The goal is to configure in a safe mode the platform to load, authenticate and execute the FSBL.
The Cortex-A FSBL is responsible to make a minimal clock tree initialization for loading the next boot stages. Then the main clock tree initialization step is performed by the OP-TEE secure OS: it consists in configuring all the input clocks, the PLLs and the clock sources that are selected as kernel clocks for all peripherals. The whole clock tree configuration is carried out by the device tree (see STM32MP2 clock tree).
Check boxes illustrate the possible peripheral allocations supported by OpenSTLinux BSP:
- ⬚ means that the peripheral can be assigned to the given boot time context, but this configuration is not supported in OpenSTLinux BSP.
- ☑ means that the peripheral is assigned by default to the given boot time context and that the peripheral is mandatory for the OpenSTLinux BSP.
Cortex-A35 nonsecure (U-Boot) | |||
Power & Thermal | RCC | RCC | ☐ | ☐ | ☐ | Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature |
The below table shows the possible boot time allocations for the features of the RCC instance.
Feature | Boot time allocation | Comment | ||
FCALC | ⬚ | |||
SYSRST | ✓ | ⬚ | ||
BOOT_STDB | ✓ | ⬚ | ||
RDCR | ✓ | ⬚ | ||
SYSCLK | ✓ | ⬚ | ||
CPU1_RES | ✓ | ✓ | ⬚ | |
CPU2_RES | ||||
DEBUG_CFGR | ☐ | ⬚ | ||
SYSRAM_CFGR | ✓ | ☑ | ||
RETRAM_CFGR | ⬚ | ⬚ | ||
BKPSRAM_CFGR | ⬚ | ⬚ | ||
SRAM1_CFGR | ⬚ | ⬚ | ||
HPDMA1_CFGR | ⬚ | ⬚ | ||
HPDMA2_CFGR | ⬚ | ⬚ | ||
HPDMA3_CFGR | ⬚ | ⬚ | ||
IPCC1_CFGR | ⬚ | ☐ | ||
GPIOA_CFGR | ☑ | ☐ | ||
GPIOB_CFGR | ☑ | ☐ | ||
GPIOC_CFGR | ☑ | ☐ | ||
GPIOD_CFGR | ☑ | ☐ | ||
GPIOE_CFGR | ☑ | ☐ | ||
GPIOF_CFGR | ☑ | ☐ | ||
GPIOG_CFGR | ☑ | ☐ | ||
GPIOH_CFGR | ☑ | ☐ | ||
GPIOI_CFGR | ☑ | ☐ | ||
GPIOZ_CFGR | ☑ | ☐ | ||
RTC_CFGR | ☐ | ☐ | ||
BSEC_CFGR | ✓ | ☑ | ||
DDRC_CFGR | ☑ | |||
SYSCPU1_CFGR | ✓ | |||
MCO1_CFGR | ⬚ | ⬚ | ||
MCO2_CFGR | ⬚ | ⬚ | ||
OSPI1_CFGR | ☐ | ☐ | ||
FMC_CFGR | ☐ | ☐ | ☐ | |
HSI_MON | ⬚ | ☐ |
3.1.3. On STM32MP23x lines [edit | edit source]
FCALC | ⬚ | |||
SYSRST | ✓ | ⬚ | ||
RDCR | ✓ | ⬚ | ||
SYSCLK | ✓ | ⬚ | ||
CPU2_RES | ||||
VDERAM_CFGR | ⬚ | ⬚ | ||
SRAM2_CFGR | ⬚ | ⬚ | ||
IPCC2_CFGR | ⬚ | ☐ | ||
HSEM_CFGR | ⬚ | ⬚ | ||
GPIOJ_CFGR | ☑ | ☐ | ||
GPIOK_CFGR | ☑ | ☐ | ||
DDRC_CFGR | ☑ | |||
PLL3_CFGR | ⬚ | |||
OSPI2_CFGR | ☐ | ☐ | ||
HSI_MON | ⬚ | ☐ |
3.1.4. On STM32MP25x lines [edit | edit source]
FCALC | ⬚ | |||
SYSRST | ✓ | ⬚ | ||
RDCR | ✓ | ⬚ | ||
SYSCLK | ✓ | ⬚ | ||
CPU2_RES | ||||
CPU3_RES | ☐ | |||
LPSRAM1_CFGR | ⬚ | |||
LPSRAM2_CFGR | ⬚ | |||
LPSRAM3_CFGR | ⬚ | |||
LPDMA_CFGR | ⬚ | ⬚ | ||
DDRC_CFGR | ☑ | |||
PLL3_CFGR | ⬚ | |||
HSI_MON | ⬚ | ☐ |
3.2.1. On STM32MP1 series[edit | edit source]
The Arm® Cortex®-A7 secure core controls all the secure registers through the RCC OP-TEE driver. The access to some secure registers from the Cortex®-A7 non-secure core can be achieved via SCMI requests.
3.2.1.1. On STM32MP13x lines [edit | edit source]
3.2.1.2. On STM32MP15x lines [edit | edit source]
Cortex-M4 (STM32Cube) | |||
3.2.2. On STM32MP21x lines [edit | edit source]
In Cortex-A main processor mode, the Cortex-A secure OS OP-TEE controls all the RCC system resources, i.e. resources which are shared between execution contexts or between different internal peripherals, like oscillators, PLLs, root clocks or reset and clock gating of RIF-aware peripherals. The Cortex-A secure OS OP-TEE provides SCMI services to access system resources. For RIFSC RISUP protected internal peripheral, each SW component can directly access RCC registers to control reset and clock gating.
- ⬚ means that the peripheral can be assigned to the given runtime context, but this configuration is not supported in OpenSTLinux BSP.
- ☑ means that the peripheral is assigned by default to the given runtime context and that the peripheral is mandatory for the OpenSTLinux BSP.
Domain | Peripheral | Runtime allocation | Comment | ||||
Cortex-A35 nonsecure (Linux) |
Cortex-M33 secure (TF-M) |
Cortex-M33 nonsecure (STM32Cube) | |||
Power & Thermal | RCC | RCC | ☐ | ☐ | ☐ | ☐ | Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature |
The below table shows the possible runtime allocations for the features of the RCC instance.
Feature | Runtime allocation | Comment | |||
FCALC | ☑OP-TEE | ⬚ | ☐ | ⬚ | |
SYSRST | ✓OP-TEE ✓TF-A BL31 |
BOOT_STDB | ✓OP-TEE ✓TF-A BL31 |
RDCR | ✓OP-TEE ✓TF-A BL31 |
SYSCLK | ✓OP-TEE ✓TF-A BL31 |
CPU1_RES | ✓OP-TEE ✓TF-A BL31 |
CPU2_RES | ☐ if TZ_EN | ☐ if TZ_DIS | |||
DEBUG_CFGR | ☑OP-TEE | ☐ | ☐ | ☐ | |
SYSRAM_CFGR | ☑OP-TEE ☑TF-A BL31 |
RETRAM_CFGR | ☐OP-TEE ☑TF-A BL31 |
BKPSRAM_CFGR | ☑OP-TEE ☑TF-A BL31 |
SRAM1_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | |
HPDMA1_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | |
HPDMA2_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | |
HPDMA3_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | |
IPCC1_CFGR | ☑OP-TEE | ☐ | ☐ | ☐ | |
GPIOA_CFGR | ☑OP-TEE ☑TF-A BL31 |
GPIOB_CFGR | ☑OP-TEE ☑TF-A BL31 |
GPIOC_CFGR | ☑OP-TEE ☑TF-A BL31 |
GPIOD_CFGR | ☑OP-TEE ☑TF-A BL31 |
GPIOE_CFGR | ☑OP-TEE ☑TF-A BL31 |
GPIOF_CFGR | ☑OP-TEE ☑TF-A BL31 |
GPIOG_CFGR | ☑OP-TEE ☑TF-A BL31 |
GPIOH_CFGR | ☑OP-TEE ☑TF-A BL31 |
GPIOI_CFGR | ☑OP-TEE ☑TF-A BL31 |
GPIOZ_CFGR | ☑OP-TEE ☑TF-A BL31 |
RTC_CFGR | ☐OP-TEE ☐TF-A BL31 |
BSEC_CFGR | ☑OP-TEE ☑TF-A BL31 |
DDRC_CFGR | ☑OP-TEE ☑TF-A BL31 |
SYSCPU1_CFGR | ✓OP-TEE ✓TF-A BL31 |
MCO1_CFGR | ☐OP-TEE | ⬚ | ☐ | ⬚ | |
MCO2_CFGR | ☐OP-TEE | ⬚ | ☐ | ⬚ | |
OSPI1_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | |
FMC_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | |
HSI_MON | ☑OP-TEE | ☐ | ☐ | ☐ |
3.2.3. On STM32MP23x lines [edit | edit source]
VDERAM_CFGR | ☐OP-TEE | ☐ | ⬚ | ☐ | |
SRAM2_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | |
IPCC2_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | |
HSEM_CFGR | ☑OP-TEE | ☐ | ⬚ | ☐ | |
GPIOJ_CFGR | ☑OP-TEE ☑TF-A BL31 |
GPIOK_CFGR | ☑OP-TEE ☑TF-A BL31 |
PLL3_CFGR | ☑OP-TEE | ⬚ | ☐ | ⬚ | |
OSPI2_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | |
3.2.4. On STM32MP25x lines [edit | edit source]
Cortex-M0+ (STM32Cube) | |||
Power & Thermal | RCC | RCC | ☐ | ☐ | ☐ | ☐ | ☐ | Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature |
Feature | Runtime allocation | Comment | ||||
FCALC | ☑OP-TEE | ⬚ | ☐ | ⬚ | ||
CPU2_RES | ☐ if TZ_EN | ☐ if TZ_DIS | ||||
CPU3_RES | ☐OP-TEE | ☐ | ☐ | ☐ | ||
DEBUG_CFGR | ☑OP-TEE | ☐ | ☐ | ☐ | ||
VDERAM_CFGR | ☐OP-TEE | ☐ | ⬚ | ☐ | ||
SRAM1_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | ||
SRAM2_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | ||
LPSRAM1_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | ||
LPSRAM2_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | ||
LPSRAM3_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | ||
HPDMA1_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | ||
HPDMA2_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | ||
HPDMA3_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | ||
LPDMA_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | ||
IPCC1_CFGR | ☑OP-TEE | ☐ | ☐ | ☐ | ||
IPCC2_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | ||
HSEM_CFGR | ☑OP-TEE | ☐ | ⬚ | ☐ | ||
PLL3_CFGR | ☑OP-TEE | ⬚ | ☐ | ⬚ | ||
MCO1_CFGR | ☐OP-TEE | ⬚ | ☐ | ⬚ | ||
MCO2_CFGR | ☐OP-TEE | ⬚ | ☐ | ⬚ | ||
OSPI1_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | ||
OSPI2_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | ||
FMC_CFGR | ☐OP-TEE | ☐ | ☐ | ☐ | ||
Below are listed the software frameworks and drivers managing the RCC peripheral for the embedded software components listed in the above tables.
- Linux®: Reset framework and Clock framework
- OP-TEE: drivers in core/drivers/clk/
- TF-A: drivers in drivers/st/clk/
- U-Boot: drivers in drivers/clk/stm32/
- STM32Cube: HAL RCC drivers
See also the SCMI overview.
For configuration of reset part of RCC, refer to Reset device tree configuration.
For configuration of clock part of RCC, the STM32CubeMX tool allows configuring the clock tree and integrates all the information documented in the STM32 MPU reference manuals. It is highly recommended to use it to generate your device tree as explained in:
On STM32MP15x lines , the RCC security level differs for each boards and is defined by RCC compatible in OP-TEE device tree:
- "st,stm32mp1-rcc-secure": sets TZEN to 1 and MCKPROT to 0
- "st,stm32mp1-rcc": sets TZEN to 0 and MCKPROT to 0
The STMicroelectronics STM32MP15x lines boards use TZEN=1.
The RCC is interfaced with the HDP internal peripheral, thus offering the flexibility to monitor the main RCC state signals on the debug pins.
Please refer to the STM32MPU reference manuals for the full list of signals that can be monitored.
