How to debug OP-TEE
  • There are two main ways to debug OP-TEE core: using embedded traces, or using JTAG/SWD to access the secure world.
  • The OP-TEE trusted applications and libraries provide debug support relying on embedded traces only.
This article focuses on OP-TEE debug.
Refer to STM32 MPU Platform trace and debug environment overview article for more generic information.
2. Debugging OP-TEE core[edit | edit source]
2.1. OP-TEE Version number[edit | edit source]
I/TC: OP-TEE version:<tag> #<buildcount> <date> <arch>
that is:
I/TC: OP-TEE version: openstlinux-19-01-11-10-g56ef3b0 #1 Wed Jan 30 09:12:56 UTC 2019 arm
2.2. Embedded assertions[edit | edit source]
   assert(argument > 0);
   return argument - 1;
2.3. Debug with traces[edit | edit source]
Value Name Description with related macros
0 - All trace messages are disabled
1 Error trace level Only non-tagged and error trace messages are embedded: MSG(), MSG_RAW(), EMSG(), EMSG_RAW()
2 Info trace level + info trace messages: IMSG(), IMSG_RAW()
3 Debug trace level + debug trace messages: DMSG(), DMSG_RAW()
4 Flow trace level + flow trace messages: FMSG(), FMSG_RAW()
Concurrent enabling of all debug supports may not be possible due to the internal memory size constraint. If required, change some DMSG() into MSG() to force messages to output even at a low verbosity level.
chosen {
2.4. Stack unwind support[edit | edit source]
2.5. Debug with GDB[edit | edit source]
2.5.1. Debug boot sequence[edit | edit source]
Linker script and memory map
                0x000000002ffc0000                . = 0x2ffc0000
                0x0000000000000001                ASSERT (0x1, text start should align to 32bytes)
                0x000000002ffc0000                __text_start = .
                0x000000002ffc0000                __flatmap_unpg_rx_start = ((__text_start / 0x1000) * 0x1000)
.text           0x000000002ffc0000     0xc538
 *(SORT_BY_ALIGNMENT(.text._start))
 .text._start   0x000000002ffc0000       0x98 out/stm32mp157c-ev1/core/arch/arm/kernel/entry_a32.o
                0x000000002ffc0000                _start  -> OP-TEE Load address
(gdb) hb _start
OP-TEE symbols may override the FSBL one, so you cannot load both TF-A and OP-TEE symbols at the same time.
2.5.2. Debugging during runtime execution[edit | edit source]
(gdb) hb stm32_sip_service
(gdb) continue
3. Debugging OP-TEE trusted applications[edit | edit source]
3.1. Embedded assertions[edit | edit source]
3.2. Debug with traces[edit | edit source]
3.3. Stack unwind support[edit | edit source]
  1. 1.0 1.1 debug/abort_dumps.html optee.readthedocs.io
