- briefly introduce the TAMP peripheral and its main features,
The TAMP peripheral is a secure peripheral.
The TAMP peripheral is used to prevent any attempt by an attacker to perform an unauthorized physical or electronic action against the device. It also includes the backup registers that remain powered-on when the platform is switched off.
The TAMP peripheral control the access to the backup registers.
It is important to notice that a tamper event can erase the following secrets:
- On STM32MP13x lines
- the backup registers
- the SRAM3
- the BKPSRAM internal memory
- the OTP upper fuses are forced to 0 and BSEC mode switch to OTP-INVALID.
- On STM32MP15x lines
- On STM32MP21x lines
- the SRAM1
- the SAES, CRYP1/2, HASH1/2 peripherals when POTTAMPRESETMASK = 0 in SYSCFG
- PKA SRAM
- On STM32MP25x lines and STM32MP23x lines
- the SRAM1
- the SAES, CRYP1/2, HASH, OTFDEC peripherals when POTTAMPRESETMASK = 0 in SYSCFG
- PKA SRAM
Information |
On STM32MP2 series, TAMP is a RIF-Aware peripheral |
The TAMP is used at boot time to share data between the ROM code, FSBL and SSBL: see STM32MP13 backup registers, STM32MP15 backup registers or STM32MP2 backup registers for further information.
3.1.1. On STM32MP1 series[edit | edit source]
Cortex-A7 secure (TF-A BL2) |
Security | TAMP | TAMP | ✓ | ☑ | ☑ |
3.1.2. On STM32MP2 series[edit | edit source]
Check boxes illustrate the possible peripheral allocations supported by OpenSTLinux BSP:
- ⬚ means that the peripheral can be assigned to the given boot time context, but this configuration is not supported in OpenSTLinux BSP.
- ☑ means that the peripheral is assigned by default to the given boot time context and that the peripheral is mandatory for the OpenSTLinux BSP.
Cortex-A35 nonsecure (U-Boot) | |||
Security | TAMP | TAMP | ✓ | ☑ | ☑ | Shareable at internal peripheral level thanks to the RIF: see the boot time allocation per feature |
The below table shows the possible boot time allocations for the features of the TAMP instance.
Feature | Boot time allocation | Comment | ||
TAMP resource 0 | ⬚ | ⬚ | ||
TAMP resource 1 | ☑ | ☑ | ||
TAMP resource 2 | ⬚ | ⬚ |
TAMP is seen as a system peripheral. The tamper detection and management is, after configuration, non modifiable. TAMP is configured in OP-TEE to manage tamper events.
3.2.1. On STM32MP13x lines [edit | edit source]
Security | TAMP | TAMP | ☑ | ☑ |
3.2.2. On STM32MP15x lines [edit | edit source]
Cortex-M4 (STM32Cube) | |||
Security | TAMP | TAMP | ☑ | ☑ | ☐ |
3.2.3. On STM32MP21x lines [edit | edit source]
- ⬚ means that the peripheral can be assigned to the given runtime context, but this configuration is not supported in OpenSTLinux BSP.
- ☑ means that the peripheral is assigned by default to the given runtime context and that the peripheral is mandatory for the OpenSTLinux BSP.
Domain | Peripheral | Runtime allocation | Comment | ||||
Cortex-A35 nonsecure (Linux) |
Cortex-M33 secure (TF-M) |
Cortex-M33 nonsecure (STM32Cube) | |||
Security | TAMP | TAMP | ☑ | ⬚ | ⬚ | ⬚ | Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature |
The below table shows the possible runtime allocations for the features of the TAMP instance.
Feature | Runtime allocation | Comment | |||
TAMP resource 0 | ☑OP-TEE | ⬚ | ⬚ | ⬚ | |
TAMP resource 1 | ☑OP-TEE ☑TF-A BL31 |
TAMP resource 2 | ☑OP-TEE | ⬚ | ☑ | ⬚ |
3.2.4. On STM32MP23x lines [edit | edit source]
3.2.5. On STM32MP25x lines [edit | edit source]
Cortex-M0+ (STM32Cube) | |||
Security | TAMP | TAMP | ☑ | ⬚ | ⬚ | ⬚ | ⬚ | Shareable at internal peripheral level thanks to the RIF: see the runtime allocation per feature |
Feature | Runtime allocation | Comment | ||||
TAMP resource 0 | ☑OP-TEE | ⬚ | ⬚ | ⬚ | ||
Below are listed the software frameworks and drivers managing the TAMP peripheral for the embedded software components listed in the above tables.
- Linux®:
- syscon driver (drivers/mfd/syscon.c ) based on binding syscon.yaml
- NVMEM framework for TAMP Backup Register access (using TAMP Backup Register Driver ).
For details on Backup register usage see How to use TAMP Backup Registers
- OP-TEE: TAMP driver and header file of TAMP OP-TEE driver + TAMP NVRAM driver using NVMEM API
- TF-A BL2: TF-A backup register access
- U-Boot: U-Boot backup register access using NVMEM API
- TF-M: TF-M backup register access
For the Linux kernel configuration, sysconf part, please refer to TAMP device tree configuration.
For the secure configuration, please refer to TAMP device tree configuration and Tamper configuration.
