STM32MP15 PWR internal peripheral
  • briefly introduce the PWR peripheral and its main features,
The PWR peripheral is used to control the device power supply configuration.
It has 6 input pins (named wakeup pins) which can be programmed to wake the system up from low power. The wakeup pins are listed with WKUP prefix in the STM32MP15 Datasheet.
These pins can be used by the Cortex®-A7 non secure (via Cortex®-A7 secure services) or the Cortex®-M4.
The PWR peripheral provides 2 output hardware lines named PWR_ON and PWR_LP:
  • In STPMIC1 configuration, PWR_ON allows to select the register bank (active or low power). PWR_LP is not used.
  • In STPMIC1L configuration, all 3 lines are used and may control regulators state depending on STPMIC configuration.
  • In the power discrete solution they drive VDDcore which feeds the Cortex®-A7, the Cortex®-M4 and the peripherals. They also control the DDR power supplies (VDD_DDR, VREF_DDR, VTT_DDR).
3.1.1. On STM32MP15x lines More info.png[edit | edit source]
The PWR is closely configured together with RCC by all the boot components: the ROM code, the FSBL, the SSBL and up to Linux® kernel. Its configuration is carried by the device tree.
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Power & Thermal PWR PWR
3.2.1. On STM32MP15x lines More info.png[edit | edit source]
non-secure
Cortex-M4
Below are listed the software frameworks and drivers managing the PWR peripheral for the embedded software components listed in the above tables.
The configuration is applied by the firmware running in the context in which the peripheral is assigned:
STM32MP1 Power overview shows the usage of PWR drivers in OpenSTlinux power management.
The PWR is interfaced with the hardware debug port (HDP) of the STM32MP15. This link offers the flexibility to observe the main PWR state signals on debug pins.
Please refer to STM32MP15 reference manuals for the exact list of signals that can be monitored.
