1. Peripheral overview[edit | edit source]
The HASH peripheral is used to compute a message digest.
The HASH peripheral is also able to give the HMAC[1] used for authentication using the same algorithm support.
1.1. On STM32MP13x lines and STM32MP2 series[edit | edit source]
Secure Hash algorithms supports:
- SHA-1 [2]
- SHA-2 [3]:
- SHA-224
- SHA-256
- SHA-384
- SHA-512
- Truncated output SHA-512/224, SHA512/256
- SHA-3 [4]:
- SHA3-224
- SHA3-256
- SHA3-384
- SHA3-512
- SHAKE128 and 256
- Keccak-based functions
- HMAC support for all supported algorithm
1.2. On STM32MP15x lines [edit | edit source]
2. Peripheral usage[edit | edit source]
2.1. Boot time assignment[edit | edit source]
The HASH instance is used as boot device to support binary authentication when device is in secured locked state.
2.1.1. On STM32MP13x lines [edit | edit source]
Cortex-A7 secure (TF-A BL2) |
Security | HASH | HASH | ✓ | ☑ |
2.1.2. On STM32MP15x lines [edit | edit source]
Security | HASH | HASH1 | ✓ | ☑ | ||
HASH2 | not used at boot time. |
2.1.3. On STM32MP21x lines [edit | edit source]
Check boxes illustrate the possible peripheral allocations supported by OpenSTLinux BSP:
- ⬚ means that the peripheral can be assigned to the given boot time context, but this configuration is not supported in OpenSTLinux BSP.
- ☑ means that the peripheral is assigned by default to the given boot time context and that the peripheral is mandatory for the OpenSTLinux BSP.
Cortex-A35 nonsecure (U-Boot) | |||
Security | HASH | HASH1 | ✓ | ☑ | ☐ |
2.1.4. On STM32MP23x lines [edit | edit source]
Security | HASH | HASH | ✓ | ☑ | ☐ |
2.1.5. On STM32MP25x lines [edit | edit source]
2.2. Runtime assignment[edit | edit source]
2.2.1. On STM32MP13x lines [edit | edit source]
Security | HASH | HASH | ☐ | ☐ | Assignment (single choice) |
2.2.2. On STM32MP15x lines [edit | edit source]
Cortex-M4 (STM32Cube) | |||
Security | HASH | HASH1 | ☐ | ☐ | Assignment (single choice) | |
HASH2 | ☐ |
2.2.3. On STM32MP21x lines [edit | edit source]
- ⬚ means that the peripheral can be assigned to the given runtime context, but this configuration is not supported in OpenSTLinux BSP.
- ☑ means that the peripheral is assigned by default to the given runtime context and that the peripheral is mandatory for the OpenSTLinux BSP.
Domain | Peripheral | Runtime allocation | Comment | ||||
Cortex-A35 nonsecure (Linux) |
Cortex-M33 secure (TF-M) |
Cortex-M33 nonsecure (STM32Cube) | |||
Security | HASH | HASH1 | ☐OP-TEE | ☐ | ☐ | ☐ | |
HASH2 | ☐OP-TEE | ☐ | ☐ | ☐ |
2.2.4. On STM32MP23x lines [edit | edit source]
Security | HASH | HASH | ☐OP-TEE | ☐ | ☐ | ☐ |
2.2.5. On STM32MP25x lines [edit | edit source]
Cortex-M0+ (STM32Cube) | |||
3. Software frameworks and drivers[edit | edit source]
Below are listed the software frameworks and drivers managing the HASH peripheral for the embedded software components listed in the above tables.
- Linux®: crypto framework
- OP-TEE: HASH driver and Cryptographic Provider API (CP API)
- STM32Cube: HASH HAL driver and header file of HASH HAL module
- TF-A BL2: HASH driver
4. How to assign and configure the peripheral[edit | edit source]
