CRC device tree configuration
The purpose of this article is to explain how to configure the CRC using the device tree mechanism, relying on the bindings documentation, that is the description of the required and optional device-tree properties.
The peripheral can be assigned to different contexts/software components, depending on the final product needs. Refer to How to assign an internal peripheral to an execution context for guidelines on this configuration .
The CRC node is located in the device tree file for the software components, supporting the peripheral and listed in the above DT bindings documentation paragraph.
This device tree part is related to STM32 microprocessors. It should be kept as is, without being modified by the end-user.
The objective of this chapter is to explain how to enable and configure the CRC DT nodes for a board.
Peripheral configuration should be done in specific board device tree files (board dts file).
&crc1 {
	status = "okay";
