- briefly introduce the DBGMCU peripheral and its main features,
On STM32MP15x lines only, the DBGMCU peripheral is used by the boot chain and by OP-TEE to get the device ID and revision, to adapt their behavior accordingly. On other devices this information is obtained through SYSCFG.
The DBGMCU peripheral is also used to configure internal peripherals behavior when one of the available cores enters in debug mode.
During a debug session, the DBGMCU can be accessed via the debug access port (DAP) to configure the expected behavior on break, typically to get a watchdog (IWDG) frozen when the Cortex®-A enters in debug mode (via a breakpoint or JTAG break) and to avoid getting a watchdog reset during a debug session.
On STM32MP25x lines only, each peripheral freeze bit inherit the permissions that are set on the same peripheral it controls.
3.1.1. On STM32MP13x lines [edit | edit source]
Cortex-A7 secure (TF-A BL2) |
Trace & Debug | DBGMCU | DBGMCU | ⬚ | ⬚ | ⬚ |
3.1.2. On STM32MP15x lines [edit | edit source]
Trace & Debug | DBGMCU | DBGMCU | ✓ | ☑ | ☑ |
3.1.3. On STM32MP2 series[edit | edit source]
Check boxes illustrate the possible peripheral allocations supported by OpenSTLinux BSP:
- ⬚ means that the peripheral can be assigned to the given boot time context, but this configuration is not supported in OpenSTLinux BSP.
- ☑ means that the peripheral is assigned by default to the given boot time context and that the peripheral is mandatory for the OpenSTLinux BSP.
Cortex-A35 nonsecure (U-Boot) | |||
3.2.1. On STM32MP13x lines [edit | edit source]
3.2.2. On STM32MP15x lines [edit | edit source]
Cortex-M4 (STM32Cube) | |||
Trace & Debug | DBGMCU | DBGMCU | ☑ | ⬚ | ⬚ |
3.2.3. On STM32MP21x lines [edit | edit source]
- ⬚ means that the peripheral can be assigned to the given runtime context, but this configuration is not supported in OpenSTLinux BSP.
- ☑ means that the peripheral is assigned by default to the given runtime context and that the peripheral is mandatory for the OpenSTLinux BSP.
Domain | Peripheral | Runtime allocation | Comment | ||||
Cortex-A35 nonsecure (Linux) |
Cortex-M33 secure (TF-M) |
Cortex-M33 nonsecure (STM32Cube) | |||
Trace & Debug | DBGMCU | DBGMCU | ⬚ | ⬚ | ⬚ | ⬚ |
3.2.4. On STM32MP23x lines [edit | edit source]
3.2.5. On STM32MP25x lines [edit | edit source]
Cortex-M0+ (STM32Cube) | |||
Trace & Debug | DBGMCU | DBGMCU | ⬚ | ⬚ | ⬚ | ⬚ | ⬚ |
There is no software dedicated to the DBGMCU internal peripheral delivered with STM32MPU ecosystem. Nevertheless, debuggers like STM32CubeIDE and OpenOCD can use the DBGMCU to freeze DMA and timer execution during step by step debugging.
