IWDG internal peripheral
  • briefly introduce the IWDG peripheral and its main features,
The IWDG peripheral is a watchdog unit that can be used to protect application frameworks running on Cortex-A7 from endless loops. This peripheral supports an independent clocking source in order to be able to continue running even when the rest of the system is in low power mode (STOP, STANDBY). Another important feature of this block is the early interrupt feature that allows to trigger an interrupt at a given power supply threshold before reaching the final reset: this gives the opportunity to run a recovery mechanism that will try to revive the system with minimum impact.
Pay attention to the fact that IWDG can be configured to be automatically active at startup (without any software intervention) via BSEC. When this is the case, the watchdog is anyway frozen during ROM code execution but it will start to decrement its counter as soon as the ROM code is left so it is important to reload the watchdog from the boot chain in this case. This behavior is implemented for IWDG2 only in STMicroelectronics distribution.
Notice also that BSEC features some freeze bits that allow to freeze IWDG during platform Stop and Standby low power periods, avoiding to have to wake up (via RTC) for the only purpose of reloading the watchdog.
(ROM code)
(TF-A BL2)
non-secure
(U-Boot)
Core/Watchdog IWDG Any instance
3.1.2. On STM32MP21x lines More info.png[edit | edit source]
Check boxes illustrate the possible peripheral allocations supported by OpenSTLinux BSP:
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
Core/Watchdog IWDG IWDG1
IWDG2
IWDG3
IWDG4
3.1.3. On STM32MP23x lines More info.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
IWDG2
IWDG3
IWDG4
3.1.4. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(ROM code)
Cortex-A35
(TF-A BL2)
Cortex-A35
nonsecure
(U-Boot)
IWDG2
IWDG3
IWDG4
IWDG5
IWDG1 can be allocated to the Cortex-A secure, which can export it to non-secure through SMC.
IWDG2 can be allocated to the Cortex-A non-secure. In this configuration, the secure monitor (from OP-TEE or TF-A) is able to receive IWDG early interrupts that can be used to save some logs before reset or, on STM32MP15x lines More info.png only, in a tentative to reset the Cortex-A7 without interfering with Cortex-M4 execution.
non-secure
IWDG2 Shared (none or both):
  • Cortex-A7 non secure for reload
  • Cortex-A7 secure for early interrupt handling
non-secure
Cortex-M4
3.2.3. On STM32MP21x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Core/Watchdog IWDG IWDG1 OP-TEE
TF-A BL31
IWDG2 OP-TEE
TF-A BL31
IWDG3
IWDG4
3.2.4. On STM32MP23x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
TF-A BL31
IWDG2 OP-TEE
TF-A BL31
IWDG3
IWDG4
3.2.5. On STM32MP25x lines More info.png[edit | edit source]
Instance Cortex-A35
(OP-TEE /
TF-A BL31)
Cortex-A35
nonsecure
Cortex-M33
(TF-M)
Cortex-M33
nonsecure
Cortex-M0+
TF-A BL31
IWDG2 OP-TEE
TF-A BL31
IWDG3
IWDG4
IWDG5
Below are listed the software frameworks and drivers managing the IWDG peripheral for the embedded software components listed in the above tables.
